Can I upgrade the wireless card in a Gateway MX6454?
I have a Gateway MX6454 laptop, with a Gateway/ Emachine Wireless Card 802.11g GemTek/BroadCom 104129 installed in it. Can I replace this card with a compatible 802.11n wireless card?
  • greree May 29, 2009
    I was actually looking for a more specific answer. The wireless card is an internal OEM. Can I replace that card with an 802.11n card? If so, where can I get it? Specifically.
  • 6,487 Answers
What you can do here is to get a new wireless card for your computer , you can get those new wireless card now in the market which uses the N standard already, You can check them from this manufacturer Linksys, Netgear, Belkin and Dlink....
Posted on May 29, 2009
  • Mark Gil
    Mark Gil May 29, 2009
    Since that is a built in wireless card you cannot replace it with another built in wireless card. if you really want to go and use a wireless N card you need to buy a external wireless N card and just disable the built in wireless......
Gateway 600yg2
I may not be understanding what you are stating, so bear with me;
1) The Wireless Modem antenna wires are up in the Display Assembly,
http://www.mundocorp.com/shopexd.asp?id=1160
In otherwords they should already be there.
2) The 802.11 Mini PCI Card, is a Wireless Module.
It goes in the Mini PCI Compartment, under the Mini PCI Compartment Cover, located on the bottom of the laptop.
It's made by Broadcom,
(Gateway 6002672 part number)
http://support.gateway.com/s/Mobile/NETWORK/Wireless/6002672/6002672mv.shtml
See at the Top right where it states Main, and has a white Side Arrow?
This terminal is where the Black wire (Lead) of the wireless antenna connects to.
The other terminal, AUX, is where the White wire connects to.
http://www.laptops-we-r.com/prestashop/gateway-6000-parts/418-gateway-dell-broadcom-bcm94306mp-b-g-mini-pci-wifi-card.html
Here is the Service Manual, (PDF file form),
http://support.gateway.com/s/Mobile/Gateway/600YG2/8508798.pdf
Page 13.
REMEMBER, remove ALL power. Remove the AC adapter (Charger), and Battery, before working on the laptop. Also follow Anti-Static Precautions.
Regards,
joecoolvette
Aug 20, 2012 | Gateway Computers & Internet
Unable to detect wireless card
Did you install the drivers for the Broadcom Wireless Card? If you did and it's not showing up the card is bad.
Mar 25, 2012 | Computers & Internet
How enable wifi on gateway laptops
The Fn+F2 should enable the wireless. If you don't have wireless enable after all, reinstall the drivers of your wireless card. You can download it from here:
http://support.gateway.com/product/default.aspx?partNumber=1013943R
Scroll down the page until you see wireless, and download the driver.
Feb 11, 2011 | Gateway MX6454 Notebook PC
My gateway laptop cant connect to the internet. _When I plug a cable, the red light in the port does not respond _ The WIFI does not respond
Hello John,
It seems that: 1. Your LAN controller and the WiFi controller could be disabled in your BIOS setup.To re-enable them, if applicable,
  • Press the F1(or F2 ) key repeatedly after restarting the computer to enter the BIOS setup.
  • Navigate through your BIOS and locate the settings for LAN conroller and wireless, and select Enabled to enable them.
2. You may not have the appropriate drivers installed on your laptop for your network controllers. Upon further investigation, your laptop runs on the following network hardware:
  • ActionTec IEEE 802.11b network card installed in Mini PCI expansion slot
  • Broadcom BCM94306 IEEE802.11g network card installed in Mini PCI expansion slot
  • Broadcom BCM94300 IEEE802.11a/g network card installed in Mini PCI expansion slot
Download and install your drivers for the hardware above from: Wireless Drivers(Broadcom BCM94306) from http://www.soft32.com/download_175098.html Broadcom BCM94306 10/100Mbps LAN drivers from http://www.broadcom.com/support/ethernet_nic/downloaddrivers.php
Hope this solution helps.Good day.
Jan 14, 2011 | Gateway M305CRV Notebook
Is ddr upgrade to 1 gig for gateway mdw 500s? Is there a way that I can install a nic/ wireless card to pick up signals?
we need model number of the laptop please mdw 500s i cannot find listed. If its the same as the nx 500s then ddr 333 is required (200 pin sodimm modules)
for wireless they installed
Intel® PRO/Wireless IEEE 802.11b/g network card, Mini-PCI Pentium® M models only)
-OR-
Broadcom IEEE 802.11b/g network card, Mini-PCI (Celeron™ M models only)
  • FN+F2 keyboard combination toggles wireless networking
  • Antenna: Uses factory-installed internal antenna assembly
  • Operating channels: 11 selectable channels
  • Security: 128 and 64 bit WEP encryption
  • Operating Frequency: 2.4 GHz Direct Sequence Spread Spectrum
  • Maximum Data Rate:
    54 Mbps (IEEE802.11g)
    11 Mbps (IEEE802.11b)
I am not sure where you will find a mini PCi card to suit i would just use a slot in pcmcia card or usb adaptor
Jan 10, 2010 | Gateway Computers & Internet
Broadcom 94309mp from a gateway laptop not installing on a dell.
go to DRIVERGUIDE.COM,this is the file that you need i just got it last night BCM4306MP_BCM4306KFB.zip if you check the wireless card you will see this letters in the chip, good luck
Jul 12, 2009 | Broadcom BCM94306MP - IEEE 802.11b/g...
Desktop recovery disc for laptop
Courtesy of Gateway here is your driver for the network card:
http://support.gateway.com/support/drivers/search.asp?ref=step&st=browse&platform=10022&model=11417&os=10406&type=10095
Now here is where it gets tricky. I'm not sure what wireless network card you have there but on that page is a section that says other available downloadsm click on where it says "click here to view these results". There will be drivers for different network cards. I believe it will be the first one in the list, the broadcom one, if not then try any of the other wireless card drivers. Hope this helps you and sorry for the delay.
Feb 20, 2009 | E-Machines (T2958) PC Desktop
Problem with installing wireless card on a Emachines G520 with xp
by the device id your device is
DELL WIRELESS 1395 WLAN MINI-CARD for this go here
but emachine G520 xp sp2 driver are
here
and injoy
Jan 21, 2009 | Computers & Internet
Wireless Router Advice
what kind do you have right now? verizon fios offers some great wireless routers that are very strong
Dec 06, 2008 | Computers & Internet
Computers & Internet Logo
206 people viewed this question
David Payne
David Payne
