Question about LG DLE2512W Electric Dryer
Clothes are taking 3 cycles to dry and cooling light on front wont shut off
Hi there, just recently our dryer has started to really take a long time with its cycles.  Some of our loads of laundry are taking up to 3 cycles to dry completely.  I was kind of checking it out and noticed that the cooling light on the front is on at the same time that the dryer is running but I cannot remember if this was always the case or something new.  Is there a way to shut this light off and what else should I be checking.
Thanks
  • 4 more comments
  • Anonymous Jan 25, 2008
    We are having the exact same problem.  The dryer has worked flawlessly since we have owned it up until now.  Does anyone have some solution ideas to this issue?
    Rich & Lynn
  • hpcarr Feb 09, 2008
    We have the same problem with the cooling light remaining on during the drying cycle.
  • Anonymous Mar 12, 2008
    same issue.taking too long to dry cool light staying on
  • Anonymous Mar 31, 2008
    Same problem here, I thought the vent may be clogged, but I cleaned it and still takes forever to dry. I'll check it out again, but the dryer worked great for 2 years until now.
  • mrhandyman4 Apr 19, 2008
    same problem here my dryer is only 7 monthes old, cooling light on and no heat , clothes will not dry
  • kidd1970 Apr 21, 2008
    Same issue - The dryer tries to cool, and not well at all, the cooling light remains on while the dry light blinks..... WHAT TO DO??
    Father of three childeren??
  • 489 Answers
The vent is clogged.  To make sure, disconnect the vent from the dryer and run the dryer normally.  If your clothes dry normally, then have a professional vent cleaning company take care of the vent.
The cooling light will always stay on during the run.  When it is blinking, the heat has stopped and is in the cooling process.
If there is no heating, you have a problem with the high limit switch or something else electrical and needs to be addressed by a qualified LG technician.
Posted on Apr 28, 2008
Cooling light stays on during dry cycle. no heat is to dry clothes. I've switched the circut breaker numerous times and unplugged the unit many times also to "reset" . What's next..
Try a timed dry cycle instead of an automatic cycle. If that works, then you will need to clean off the moisture detection bars inside the dryer to get the auto cycle to work again. Look for two curved metal bars, about 3/16 inch wide and 4 inches long, about an inch apart, located just inside the front of the dryer, near the right side of the lint filter. (you'll have to stick your head in the dryer drum to see them) Often times, use of dryer sheets will result in a waxy coating forming on these bars, preventing the dryer from detecting the moisture in the clothes. The dryer sees no moisture, it goes into the cool down mode and then stops. Clean the bars off, and you should be back in the laundry business.
Feb 05, 2011 | LG DLE7177 Dryer
I have a Kenmore 80 Series Gas Dryer. We replaced the motor and blower wheel in October of 2010. Recently the the dryer has been stopping while drying clothes. No matter what cycle I put it on, it almost...
Hi, In looking at your problem please do the following. Go behind the dryer. The vent hose that is attached to the back of the dryer has to go straight to the wall outlet. It must not have any bends whatsoever. Its a straight shot to the wall. This should take care of it shutting off and being too hot. You may need, after the above, to change out the cycling thermo. Thanks for your inquiry and hope this helps. Have a Good Day!
Jan 18, 2011 | Dryers
Neptune glass front takes 4 hours to dry clothes.
make sure the vent system is clean. any restrictions can cause the safety switches to activate and turn off heaters. When it cools, the switch resets and starts heating. Unit will continue to cycle the heat off and on. Make sure all elements are working.
Start there.
Jun 07, 2010 | Maytag Neptune MDE6700A Electric Dryer
Clothes not dryin
clean out the exhaust vent tubes thoroughly. the moister sensor will shut down the high heat if clogged full of lint
Jun 06, 2010 | Estate EED4100SQ Electric Dryer
My dryer used to shut off before the clothes are dry - now it wont start at all
Ok, the light will not come on if the door pressure swicth is damaged and, the dryer will not start if this switch is damaged as well. replace the door pressure switch asap.
Ok, concerning the interuppted drying cycle due to high heat, this can be cuased by two issue. It coudl be a venalation issue. if the dryers vent duct and exuast hoses are clogged, thsi will cuased the element to reach unsafe tempreturs, in return, tripping the high limit thermostsat and shutting the dryer off in the middle of the load cycle.
Another problme spot woul dbe a fualty high limit thermaostae. Although this is highly unlikey, this coudl be your issue.
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
Jun 02, 2009 | GE DBSR453EBWW Electric Dryer
2 to 3 cycles to fully dry clothes
if the clothes are warm after the cycle then you need to make sure the vent to the outside of the house is not plugged if they are not warm then it is in the heating circuit of the dryer wether it be the element or a fuse will have to be tested. to dry clothes it takes heat and air flow if you dont have one of the two they will not dry correctly
May 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Dryer starts drying and thinks clothes are dry, but they aren't
Check the timer, and the sensor. Sounds like it is having a problem with the timer or sensor no noticing that the clothes are still wet. Please rate if satisfied. Thank you
Feb 12, 2009 | Kenmore Elite HE4 Electric Dryer
Clothes wont dry but gets really hot
Hello, sounds like your cold water feed hose has got a kink in it. The machine needs cold water to condense the steam. Just pull out the machine and slowly slide back into place.
Oct 21, 2008 | Hotpoint Aquarius WD63 Front Load...
DBXR453ET3WW Electric Dryer Won't shut off unless on timed cycle.
hi thanks for the question in the ge dryer theres 2 elements so if one is not working you only get half heat i would check the heater thanks the appliance doc
Jun 18, 2008 | GE DBXR463EBWW Electric Dryer
LG DLE2512W Electric Dryer Logo
2,238 people viewed this question
Top LG Dryers Experts
Mike
Mike
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
