Question about Dishwashers
HI i have an electrolux dishlex dishwsher that is brand new and just installed. Ive used it a few times an dhave noticed that there is water at the bottom of the dishwasher, thats not draining, I thin
HI i have an electrolux dishlex dishwsher that is brand new and just installed. Ive used it a few times an dhave noticed that there is water at the bottom of the dishwasher, thats not draining, I think i have to check the spigot trap on the s bend under the sink , but not entirely sure how to do this. Ive got a diagram that ill follow. however any advised would be great. thanks
  • Victor
    Victor May 11, 2010
    Hi, Do you have this hooked up to the drain or a garbage disposal? Dis the water totally release at any time or has water always stayed in D/W?
    Just need clarity.
    Vic
  • 56 Answers
There is always a little water in all dishwashers. Sounds like to me that you may have a kinked drain hose or maybe the way you have hooked the drain up. The drain hose should go to a vacuum break that is mounted on the sink flange and then another hose goes to the disposal. If you have the hose hooked directly to the disposal you may be getting water back from the sink to the dw. raise the hose up as high as possible and attach under the sink so there is a high loop in your hose so water cannot drain back from the sink
Posted on May 29, 2009
I just posted the same problem with our new electrolux Dw last night, Today I pulled the dw out and sure enough the hose had a kink in it. I am running a test wash right now, I am confident the problem will be solved. I will post again if it doesn't do the trick. Thank you to the pros here for the info by the way!
Posted on Jun 02, 2009
Electrolux EIFLSI5IIW1 stops at 1 min left in cycle
I have solved same problem with washer Electrolux EWS1066. All cycles stops after starts with 1 min left on display and open inlet water valve. I think that was bad door interlock but it was a defective main controller. No damage visible on board than I heated PCD with heater gun mainly pointed to SMD parts. Now washing machine work good.
Oct 14, 2014 | Washing Machines
Dishlex 302 leaks from underneath
Good Morning Friend,
This appears to be a UK Electrolux dishwasher; however, if you have a US Electrolux model, here are a few tips you can attempt to troubleshoot the issue: First, Use only fresh detergent designed for automatic dishwashers. Measure detergent carefully. Possibly try a different brand of detergent. Secondly, spilled rinse aid can cause foam and lead to overflowing. Wipe up any spills with a damp cloth. Lastly, check to see if your dishwasher is level. If your dishwasher is still leaking, after trying the above solutions, I suggest contacting the manufacturer for further assistance. Hope this is helpful.
-Best regards-
WP
May 19, 2014 | Electrolux 18 in. ESL4114 Slim-Line...
Hello - I have an Electrolux Dishlex DX302 dishwasher. The washer works okay - but it doesn't always empty the contents of the dishwashing powder in to the dishwasher. It is often wet and stuck in the
If you have hard water, you should reduce the amount of detergent you use. Here's a map showing water hardness in the USA. http://www.citriclean.net/why-citriclean/
Nov 23, 2013 | Dishwashers
My dishlex dx103sk won't start at all. How do I fix it?
Hi Daniel,
model dx103sk Electrolux
I am getting water hammer through copper pipes
every time dishwasher water valve opens and closes
I have changed 3 types of anti hammer washers on supply tap.
also changed the one way water valve at hot water service
next I am looking at changing the pressure valve next to the dishwasher as this problem really on happen when I changed brands of dishwasher.
? kpa rating do you think I should use?
Am I going down the right path here?
thanks David Desira
Jul 19, 2012 | Dishwashers
I have a Electrolux Dishlex DX302 and the last few washes I have notice that on the ususal cycle it is not heating (steaming) at the end. The dishes are still coming out half clean. I am not sure why the...
Doubble check the settings on your machine.
It is a long way from my heater to the washer. Hot water is essential to the operation of any model machine. I always get hot water to the sink (by running the hot water, of course) before I start the washer. I can tell when I fail to do this.
Just a thought, I hope this aids your situation.
Of course your washer heater may have failed ... You can check it using a volt/ohm meter.
Thanks for your question this morning @ FixYa.com
Jul 12, 2011 | Electrolux Dishwashers
Hi, My Dishlex dishwasher DX 302WB ia showing 10
check this
1)blockage in boiler tank.(cleaned)
2)water pressure is less.(check solenoid filter)
if it's programmed in timer mode within the period it must reach the water level in the tank due to this also it may happen.
Jan 06, 2010 | Electrolux Dishwashers
User manual for electrolux dishlex DX302
Go to http://www.dishlex.com.au/SupportCentre and then search by the model description DX302WB. I downloaded a pdf file no problem.
Nov 12, 2009 | Electrolux Dishwashers
Electrolux dishlex dishwasher
www.nzherald.co.nz said it affects Electrolux dishlex machines with serial numbers 70700000 to 72400000
Jul 25, 2008 | Electrolux 23 in. ESL624 Built-in...
I have a dx302. its not heating the water or drying.
My six year old Electolux Dishlex DX 403 dishwasher stopped heating the water. I found comments on the internet about burnt out solder joints in the control box. A friend opened the control box and found a blackened area on the back of the circuit board. Once the connection was re-soldered the water heated again. We also found that quite a few wires leading to the control box had overheated and the insulation had melted. Considering that this dishwasher was the top model from Electrolux at the time, I was not impressed. I had previously had a Vulcan Dishlex for almost 20 years.
Thanks to those people who previously posted information about this fault.
Feb 10, 2008 | Electrolux 24 in. EDW5505EPS Stainless...
Dishwashers Logo
262 people viewed this question
Top Dishwashers Experts
