Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
Ryobi 700r gas trimmer, replace old fuel lines
I need to replace the tank assembly on my Ryobi 767r gas trimmer. There is nothing in the manual showing how to do that?
    Master:
  • 969 Answers
1-800-345-8745 US
1-800-265-6778 Canada
Posted on Aug 23, 2009
The primer bulb is broken on my 700r 2-Cycle Gas Trimmer and I would like to replace it
not difficult at all to do , first obtain Ryobi primer /fuel line kit from your local distributor , then remove air cleaner cover (pops off with fingers) then drain all gas from fuel tank back into storage tank , locate the two Phillips head screws next to primer bulb and remove them , careful not to drop them !! remove old bulb from ring and replace with new bulb from pkg. then using a clean cloth , carefully wipe out sealing grove where bulb seats down (I guarantee its dirty) when all clean , place bulb down in grove and make sure it seats well then secure with ring and replace screws (don't over tighten) you might as well replace the fuel lines as they come in kit , instructions are on pkg , I do suggest doing one at a time to not forget how they go , and do use the new fuel filter that's inside pkg too
May 13, 2016 | Ryobi Garden
Need part for ryobi trimmer no.700r
There are parts and part number listed on page 20 of the manual. Here is the link for the Ryobi 700R trimmer manual.
Jan 07, 2013 | Ryobi Garden
Ryobi 700r gas trimmer. Leaking fuel from the fuel return line...what is the best way to fix this?...seems to be leaking where the tube goes up into the fuel tank. thanks.
There is no nipple. The fuel line is just pushed through and holds itself tight against the hole in the tank.
This is the return line from the primer bulb, right?
Just replace the line and you should be fine. I think that some of these Ryobi lines are 3/16 OD and 3/32 ID, but I just picked up a Ryobi fuel line kit at Home Depot today, and the black line seems to fit nicely here. (My trimmer still won't start, but at least it doesn't leak gas any more.) Be careful to note which line comes from where on the orimer bulb.
Steve
May 12, 2010 | Garden
Need manual for Ryobi 700R
You can go to safemanuals.com and download a free copy in PDF format. Good luck!!
Sep 29, 2009 | Garden
Replacing fuel lines on ryobi 767r trimmer
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
Jul 03, 2009 | Ryobi Garden
Ryobi 725r 31cc
Ryobi is Japanese for "Piece of ****" My suggestion is to throw it out!
My 767r has had fuel line and carb trouble from day one. I'll never buy another Ryobi or Craftsman tool again.
Jun 13, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
1,122 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
