Question about InFocus ScreenPlay 4805 Multimedia Projector
Turning off the machine
How do you turn off the projector safely?
    Problem Solver:
  • 4 Answers
Buy the remote from there you can put it into standby and then if wanted turn the switch off. you can find the remote at infocus.com
Posted on Jun 18, 2009
How do I turn off the machine safely?
Do people still use those?
OK. Dim the lamp, leave the fan on for about 10 minutes.
Turn off unit and LEAVE UNTIL COOL.
Feb 13, 2015 | Apollo Ai-1000 Overhead Projector...
Bulb not turn
bulb should stationary, not fault.
make sure bulb proper fit, push in hard, screw up, all covers on and screw, all cables correct insert, hours reset if exceed safe limit.
then google viewsonic pjd6251 projector manual
Jan 29, 2014 | ViewSonic PJD6251 Projector
Turn off on screen message
follow this steps and fix it. God bless you
  • Secure the lamp cover and the air filter cover of the projector body if the projector does not power on. Ensure that the power cable is firmly connected to the projector and an active power plug. If the projector was turned off and then on quickly--let it sit for 90 seconds before trying to turn it on.
  • 2
    Replace the projection lamp if the projector will not power on or if the lamp indicator is flashing. Turn off the projector and let it sit for at least 30 minutes. Locate the lamp cover and remove or loosen the lamp cover with a screwdriver. Carefully remove the projection lamp from the projector housing using the handle, if available.
  • 3
    Place the new projection lamp into the projector housing and secure it to the projector. Replace the lamp cover and reset the lamp timer. Power on the projector to ensure the new lamp is working correctly.
  • 4
    Remove the projector from the enclosed area to allow air circulation if it constantly overheats. Place the projector into an open area and make sure there is no blockage for the ventilation holes. Unplug the projector for at least 45 minutes to allow it to soft reset.
  • 5
    Clean the air filter to allow the projector better air circulation. Turn off the projector and unplug it from the outlet. Remove the air filter cover and use a vacuum to remove dust from the area. If the filter is unable to be cleaned correctly or is damaged, then replace it. Pull the air filter from the projector and place the new one in the now empty slot. Close and secure the air filter cover.
Oct 28, 2013 | Dell 4310WX Projector
Blinking red light. projector won't turn on
The lamp life may have exceeded its safe limit, check your manual as you may have to press a specific button on the unit/remote for a length of time to reset it.
Good luck
Aug 03, 2011 | InFocus ScreenPlay 5700 Multimedia...
Hello, i have a sharpe PG-M20S, and just replaced the bulb. I accidently threw the power cable away; I found another in a drawer; i plugged that in; I power the projecter on, and it stays on for 1 second...
There is no problem with the cable as the voltage ident on it is the maximum safe voltage that may pass through it without risk of electric shock.
I would imagine that you have to find your instructions and reset the lamp life now.
Hope that helps.
Feb 17, 2011 | Sharp Notevision PG-M20S Multimedia...
Panasonic PT-AE900E Projector not working???
I have this exact problem too, so anyone out there that can help it would be great!
Mar 03, 2010 | Panasonic PT-AE900U Multimedia Projector
Comp screen to projector, bulb light turns on
Try resetting the lamp hours it can go into a safe mode if you exceed the expected life of the lamp. It can be done even if there is no image have a look at the infocus website all models vary on the procedure if not try a firmware update to wipe its brain but you will need the leads it was shipped with.
Feb 11, 2010 | InFocus Work Big IN32 DLP Projector
When the SONY VPL - ES1 projector is turned, the lamp cover opens , no light and after a while lamp cover closes. Mounted on the ceiling, it has happened after it was working well previously. Lamp has...
definately a lamp problem, for some reason the projector doesnt seem to accept or recognize the new lamp and switches to "safe mode". usually the projector turns off before the bulb explodes...
Jun 11, 2009 | Sony VPL-ES1 Multimedia Projector
InFocus ScreenPlay 4805 Multimedia Projector Logo
88 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
color wheel light...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
