Question about Panasonic PT-50LC14 Television
Unable to reset Lamp Hour Meter on Panasonic PT-50LC14
I replaced the Lamp on my Panasonic Wide-screen TV. I am unable to reset the Lamp Hour Meter. I have a Direct TV remote, a Panasonic remote and a Universal remote. I have tried the "hold down the PIP(?) button and the 'down volume' button on the various remotes. Nothing is working. Please help, Al
  • alshobby May 29, 2009
    IT WORKED!!! Thank you so much.
  • Anonymous Mar 21, 2014
    it won't turn on anymore. we had it on charge and now are unable to turn it on again. have tried various power points but nothing. also tried reset button on back. please advice.
    President:
  • 1,077 Answers
Try this, using the Panasonic remote, wait until the notice about your lamp goes AWAY (it wont work with the message still up).
Hold the volume down on your tv while holding the split/play button on the remote.
You will get a notice about 4-5 seconds later that it was reset.
Posted on May 29, 2009
  • Devon Sacco
    Devon Sacco May 30, 2009
    No problem. Have a nice day. :)
I used the pip (same as play) button on the remote and went to the tv and pushed the down volume button. press and hold about five seconds. It worked for me.
Posted on Jun 02, 2009
How do i reset the lamp hour on my panasonc PT-50LC14, the replace box keeps coming on thanks john
all you do is turn your tv on. if mesage appears then push exit on the remote, then hold the volume down button on the tv , and at same time hold split button on the remote for 5 to 10 seconds. then a message will appear that lamp meter has been reset to 0.
Mar 08, 2011 | Panasonic PT-50LC14 50" Rear Projection...
Changed bulb, but cannot get blue" change bulb and reset hour meter "banner off tv
You need to use the remote control that cam e with the TV and press the PIP/SWAP button on the remote and the VOLUME down on the front of the TV simultaneously for more than 10 seconds. Once successful the on screen display will tell you the lamp timer is reset to 0.
Sep 08, 2010 | Panasonic PT-50LC14 50" Rear Projection...
Lamp reset on a panasonic model pt-50lc14-k
This works for mos Panasonics
Turn on Power
Pres and hold the "vol-" button on the front of unit and the "split" key on the remote together for over 5sec.
Screen should say " Lamp time was reset to 0"
Nov 12, 2009 | Panasonic PT-50LC14 50" Rear Projection...
PT-50LC14 TV SHUTS OFF ON ITS OWN. I REPLACED THE BULB, BU THE PROBLEM PERSISTS. DO I HAVE TO RESET A METER?
After you replacing the lamp, you need to check the fan, if it is workinh otherwise it will automatically shut off due to temp rating.
Jul 26, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic PT-50LC13 reset hour meter
on the tv itself push the volume down button and at the same time using the remote control press the pip button. I just did this on my tv - had the same problem. it worked perfectly. Jeanne
Jun 21, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Reseting The Projection Lamp Hours Meter
If you need the original remote, you can order the original Panasonic replacement remote control for this model (PT-50LC14) from a major Panasonic parts distributor at the link below:
Panasonic PT-50LC14 Replacement Part Remote Control
Sometimes there's a way to reset the counter by mashing certain keys on the TV itself in a sequence, but if your owner's manual doesn't specify this option, then you may have to get the original replacement remote to be able to reset it.
Apr 10, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Reset hour meter for replaced lamp
push and hold the PIP (same as play) button in the remote control
push and hold the menu button on the front panel of the tv.
Do both actions simultaneously. Of course you have to be close to the tv to do this: pointing with the remote at the sensor AND holding the menu button of the tv panel.
Do this for some seconds and the screen is going to tell you the timer was reset sucesfull and ask you to push exit in the remote control to finish
Apr 08, 2009 | Panasonic PT-50LC14 50" Rear Projection...
How to reset the meter of lamp
You need to have your Panasonic remote.
1. Make sure the power cord is plugged into a properly grounded outlet and turn on the set with the power button on the projection unit or the remote control.
2. While holding down the (VOL -) key on the projection unit press the PIP or SPLIT key at the same time. Hold it for longer than 5 Seconds. The PIP or SPLIT key is model specific:
PIP for Models:
PT-50LC13/PT-60LC13/PT-50LCX63/
PT-60LCX63/PT-43LCX64/
PT-50LCX64/PT-60LCX64
SPLIT for Models:
PT-43LC14/PT-50LC14/PT-60LC14
3. When the unit resets the lamp timer it will display a screen on the TV indicating it was reset to zero. You press recall on the remote to exit.
You will find a PDF of the instructions at this site:
http://fixyourdlp.com/blog/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
Aug 23, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Lamp reset
This also works for the Panasonic PT-61LCX65. You hold the volume button down on the projection display, then hold down the Split/ DVD button on the remote control at the same time. I just did it after reading the advice posted. Thank you!
Oct 11, 2007 | Panasonic PT-50LC14 50" Rear Projection...
Televison & Video Logo
1,382 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
