Question about Kenmore 14249 Dishwasher
Motor/relay(?) smells hot, wont do next, after cool runs ok
Kenmore 18in built-in model 587-14249990. Notes: the timer tests fine at all steps and the wiring & contacts to motor relay & motor (cant see actual motor contacts as wires go inside housing) look all good. I also fully disassembled lower arm unit & water gears etc down to just the motor shaft and all were clear & the motor shaft turns freely either way.
BUT the problem is- the dishwasher starts & runs fine (as long as its cool) from anywhere in the cycles I want, but after a few minutes in wash or drain, I notice a "hot" smell from motor/relay area when the motor is running. The next request of the cycle (be it wash or drain), the motor won't kick back on. If I stop the cycle & let the motor/relay(?) cool, then re-start in same place, the motor does whatever is next just fine until it heats up again. I hope its the motor relay & not the motor. Any ideas?? Thanks! Deb
  • 1003 Answers
SOURCE: Kenmore 587 High Temp/Heat Dry lights flashing, cycle not complete
REPLACE TIMER
Posted on Jan 18, 2008
reg501
  • 413 Answers
SOURCE: Kenmore Ultra Wash Dishwasher does not drain
Some Kenmore DW have a check valve attached to the sump that may have a blockage. Remove toe panel, look for a long, white, plastic fitting attached the front, right side of the sump. Remove the drain hose from the valve. Unscrew the valve from the sump and inspect for debris inside the valve.
Posted on Jun 14, 2008
ngfam1
  • 639 Answers
SOURCE: kenmore hydrawash dishwasher
Friend,
ngfam1 At your service!
Drain line from the motor out has a crack or split in it! Sounds simple and an easy repair.
call service below that I gave you!
It sould be a simple repair!
If the appliance is 10 years old or more you may not be advisable to put good money into bad! New applinces are so much more efficient today that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
Posted on Aug 31, 2008
  • 10865 Answers
SOURCE: I have a Kenmore dishwasher that will not pump
Look inside of the dishwasher to be sure that the tubes leading to the spray arms are not disconnected. If those tubes are in place, then the problem is with the main motor/pump in the base of the unit. That Kenmore part is about $150.00 plus labor. That being said, it may be time to consider a new dishwasher UNLESS your dishwasher is less than five years old because there is a five year warranty on the motor/pump. If it is under warranty, call sears repair and they should repair it at no cost to you.
Posted on Apr 18, 2009
  • 127 Answers
SOURCE: kenmore dishwasher has stopped draining.
remove the kick panel below the door, place a pan, etc under where the drain hose connects to the drain extension tube, and slide the clamp back some so you can slide the hose off of the extension tube (white plastic tube) and drain any excess fluid into the aforementioned pan, etc., then unscrew the extension tube and check for plugs, or restrictions.
the sump may also be pluged beneath the strainer assembly, and that requires removing the lower spray arm, the water tube that runs up the inside back of the unit, and the upper parts of the assembly below them to access the drain/pump sump area.
last but not least the impeller is jamed and might be able to be freed by removing whatever has lodged within there..
ya never know...
best of luck,
ttfn
Posted on Oct 25, 2009
I have a Kenmore 70 series dryer. The dryer runs but will not heat. I have had all fuses, heating element, and thermostats tested but it still will not heat. Any thoughts?
Notes: Check all components on dryer with at least one wire removed and all have continuity or 0 ohms.
Have checked circuit breaker and know for sure 240 volts is going in machine (motor runs on 120v heater needs 240v).
Ok the next thing to do is find the heavy red wire going into the timer. Remove the red wire from the timer. Set the timer on heat dry cycle (power if off) Chck from that leg of the timer to any other leg on the timer for continuity. or 0 ohms. if you get nada then the contacts inside the timer is bad. My video:
Sep 10, 2013 | Whirlpool GEQ9800L Electric Dryer
I just washed this morning and may have put alot of clothes in. Everything went through and when wife put in next load. it only filled up with water. and wont start...actually had a faint burned smell. ...
Probably not the main motor. That is a good thing. If you take the bottom panel off under the door, there is a technicians notes package and that has all the tests that you can run. IT will tell you what the problem is.
Aug 31, 2013 | Kenmore Washing Machines
Cooling fan wont come on car running at a high tem
You could verify fan motor is good by using jumper wires from battery to the fan motor. If the motor is good, you will probably need a wiring diagram and at least a test light to start checking the fan circuit. There will be a cooling fan relay that when signaled, will send power direct to the fan. The signaler to relay to turn the fan on may be the engine computer when the coolant temperature sensor tells it engine is getting too hot- or it may be signaled on by a fan temperature switch mounted in the radiator. When coolant reaches a set temperature the switch closes contact, and the relay is energized to pass power on to the fan. One could pull the relay and with key on, use test light to probe the terminals where relay plugs in. The power feed for the fan should light up the test light on one of the terminals, verifying power is still available to turn the fan on. Next one could check if the signaler to turn the relay on is working.
See? So you do need a wiring diagram to see how the circuit is wired. But the first step is to verify fan motor is good. Good luck, Nigel.
Aug 27, 2013 | Vauxhall Cars & Trucks
Kenmore 500 series gas dryer has no heat and no glow. Thermostat fuse has continuity. Replaced ignitor and coils. bypassed flame sensor and still have the same problem.
Having checked or replaced what you have thus far here a few things still to check
Cycling thermostat in blower housing,in addition to thermal fuse it must have continuty to be good
Timer check wiring diagram in control panel and check for continuty that are supposed to be closed when set to a normal heat cycle
Motor switch heat circuit check again with wiring diagram and see which wires on motor switch must be closed when running so dryer will heat.This a built curcuit asurring the dryer will never heat when motor is off
If your model has it check heat relay in control panel for continuty on heating circuit for relay(not the circuit that closes relay)
as far as power to the ignitor the hot side comes from timer to and through the thermal fuse and cycling t-stat, to ignitor.the neutral comes from neutral wire on cord to and through motor when motor is running and motor switch is closed
so on ignotor plug check hot wire to ground(not neutral) if has 120 vac to it timer/t. fuse/ cycling t-stat and flame switch are all good and its the motor switch is the problem.The motor switch can not replaced seperatly and must replace entire motor
Gene
Aug 09, 2011 | Kenmore Dryers
Runs hot air after awhile blow cool air
Model # tells me it is a convection oven. You can't dry clothes in a convection oven. they end up smelling like last nights dinner.
Please check the model #. there may be relay that controls the power to the heating element. this relay could be not functioning correctly, or it could be in the timer. maybe the thermostat that monitors the interior temperature is gone. It could be sticking closed. tough to say with the model number.
Oct 07, 2010 | Kenmore 63942 Dryer
Humming sound and buring electrical smell
yes yes yes .you are absolutely right.its the coils in the motor burning.the motor needs replacement. Often the start relay for the motor sticks and makes the motor get too hot. This can cause the motor to over-heat and shut off on the built in safety sensor inside the motor. You may need to use a amp probe to test the motor properly, check model plate for proper amps.  If this is let go too long the motor windings can also be damaged ( they may look black instead of a nice copper color). The wires on the relay are also bad for burning off the wire terminals.   The wires at the motor should be checked to make sure they have not burned off or you can test the motor continuity with an ohm meter. See two newmotor wiring pictures.....here...and...here. The relay wires often burn off as well.
May 12, 2009 | Kenmore Washing Machines
Kenmore model # 110.20722990
ck all motor connections just lean washer back against wall motor is right at front if motor ckd ok 2 things left motor or timer neither one is cheap but best guess would be timer
Sep 08, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore air cleaner
I just bought the same model and also have the smell. My previous one did not so I returned the first unit and the second units smells the same. I called Sears Customer Support and they told me that it is probably due to the factory smoke test they do on each unit. He said let it run for a few days and it should dissapate. I went a step further and am trying a new filter and if this works he said call the store and they will get me a new filter.
Mar 23, 2008 | Kenmore 85250 Air Purifier
Dryer not turning on
most likely its the timer it has electrical contacts built on the timer that allow it to start its cycle if the timer has bad contacts it wont allow dryer to come on
Jan 21, 2008 | Dryers
Kenmore 14249 Dishwasher Logo
62 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
