Question about Dryers
Clothes still damp
I replaced all 3 thermostats,thermal fuse and heating element as well as cleaned out the dryer vent and my clothes are still damp. Any suggestions?
  • rupe45 May 11, 2010
    what brand is the dryer and it definitely sounds like a stopped up vent. Disconnect the vent hose from the dryer run a load of clothes thru and see if it works ok if it does it is definitely the vent
    Genius:
  • 1,122 Answers
Have you checked the dryer vent,wall vent lint trap for cloggs,if clogged it will hold the damp hot air in the dryer much longer and add to your drying time-mike
Posted on May 29, 2009
It takes the dryer 2 hours to dry the clothes. I always make sure lint filter is cleaned after each cycle.
Hello there and thanks for choosing fixya
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Feb 03, 2011 | Dryers
Dryer will not heat up
A clothes dryer can go for years without any problems. We come to rely on our clothes dryer, and we can even begin to take it for granted. Then one day we attempt to use our clothes dryer and it has no heat to it. Now we have entered the world of clothes dryer repair, and it is a world that can get expensive. Before you call out the repairman, try some troubleshooting tips to see if you can get the heat flowing back to your dryer again.
    Lint One of the easiest fixes for a dryer that will not heat up is cleaning out the lint trap and cleaning out the lint from the dryer exhaust. The lint trap should be cleaned out before each usage. Not only does cleaning the lint trap prevent the possibility of a fire, but a lint trap that is filled beyond capacity will cause the dryer to not heat up. If the lint trap is clean, then inspect the exhaust hose and vent next. If the exhaust hose and vent are cluttered up with lint, then the dryer will not generate heat. You can use your hand to clean out the vent, and broom handle to clean out the vent duct in your house. The flexible hose can be detached and cleaned by hand as well. Thermal Fuse A dryer will run on for a very long time, and when the thermal fuse gives up then there will be no more heat. Finding and replacing the thermal fuse is not difficult, but in order to do it you will need the manual for your dryer. Each dryer model is different as far as how to open up the cabinet, and locate the thermal fuse. You may need to purchase the thermal fuse online from the manufacturer, or you may be able to get a universal fuse that fits your dryer from an appliance repair store. Contact the manufacturer of your dryer to see what kind of thermal fuse they recommend. Thermal fuses cannot be repaired, they must be replaced. In most cases it is easy to tell if your thermal fuse needs replacing as you will see the center of it is burned out. Heating Element Another main culprit to a dryer not heating up is the heating element. According to Repair Clinic.com, the heating element is a coil found in the back of the dryer that the dryer uses to create heat. The only way to tell if a heating element is bad is to check the consistency of the current it generates with an ohm meter. If you are unfamiliar with how to do this, you can either replace the heating element and assume it is faulty, or you can have a repair professional test your heating element for you.please comment on these solution by say how helpful.by rate or vote
Jan 10, 2011 | Dryers
My maytag electric dryer wont heat up
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
Apr 28, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
My dryer does not heat. Fuse, thermostats, heat element all have continuity, power chord is good, 240v at plugin... stumped. It is a model # LER4634BQ1 Whirlpool SN# ME4471484
dryer_heating-element.jpg Heating Element
dryer_thermal-fuse.jpg Thermal Fuse
dryer_thermostat.jpg Thermostat
dryer_timer.jpg Timer motor
Feb 06, 2010 | Whirlpool LER4634J Electric Dryer
GE Front loader doesn't dry clothes completely.
Hello there:
f yourdryer won't heat up, it's possible that it is not being supplied withthe proper voltage. Here are three ways to make sure power is gettingto your dryer: First, make sure your dryer is plugged in. Next, checkthe circuit breaker panel to make sure all the circuit breakers are inthe correct positions. Finally, check to make sure no fuses in yourfuse panel are blown. Any of these could explain why power is notgetting to your dryer.
It is possible that your dryer isn't heating because its heatingelement is defective. Heating elements are irrepairable. If yours hasceased to function properly, you will have to replace it. Open yourdryer's cabinet and locate the heating element so that you can test it.
Another possible cause for a dryer not heating up could be attributedto a faulty thermal fuse. Once a dryer's thermal fuse has blown, it isno longer of any use. If your dryer's fuse is blown, you will have toreplace it. Open up your dryer's cabinet and locate its thermal fuse sothat you can test it.
If any of your dryer's thermostats have become defective, they could bethe reason that your dryer is not heating. Open up your dryer's cabinetand test each of your dryer's thermostats. If any are faulty, replacethem.
A defective timer motor could also cause your dryer to not heat up.Test your dryer's timer motor. If it is no longer functioning as itshould, replace either the entire motor assembly, or just its motor.
Jan 23, 2010 | GE DCVH515EF Electric Dryer
DRyer is turning just not drying clothes Maytag
Hello there:
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
Jan 19, 2010 | Dryers
Whirlpool dryer will not heat
Hello there:
There are 5 things that would not make the dryer heat up i will post you them here ok
Jan 17, 2010 | Dryers
There is no heat to dry clothes.what do I do?
My dryer will not heat up.Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not beingsupplied with the proper voltage. Here are three ways to make surepower is getting to your dryer: First, make sure your dryer is pluggedin. Next, check the circuit breaker panel to make sure all the circuitbreakers are in the correct positions. Finally, check to make sure nofuses in your fuse panel are blown. Any of these could explain whypower is not getting to your dryer.
Heating Element
Thermal Fuse
Thermostat
Timer motor
Jan 12, 2010 | Kenmore Dryers
Kenmore Clothes Dryer Model 67902790 has no heat
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.(Thermal cut-off)
Aug 24, 2009 | Kenmore 62882 Electric Dryer
My dryer takes long time to dry the clothes. It
Check the following areas thoroughly to address this issue.
1. Venting
2. Thermostat
3. Heating element
NOTE***(This unit is equipped with a dryness control board. if all points above check out ok, replace this board).
Jul 21, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryers Logo
208 people viewed this question
Top Dryers Experts
