Question about Kenmore 56549 / 56542 / 56544 / 56546 Side by Side Refrigerator
Where is the defrost timer kenmore side by side 596.52679200
Where is the defrost timer on a kenmore side by side 576.52679200???
  • 1 more comment
  • knowleswhole May 29, 2009
    That is the model # inside the fridge. We bought it in 2002 or 2003. I have researched a little more and I think it has adapt defrost board??? We are changing the defrost thermostat right now but I read that the timer should be changed also. I am trying to not go through this again for a while! Luckily we have a second fridge in the laundry room to move all the food to! !
  • Victor
    Victor May 11, 2010
    Ok, If the bi-metal switch you are changing tested bad, you really don't need to change the board. The timer board is located inside the control board in the fresh food section.
  • Victor
    Victor May 11, 2010
    Hi, I tried looking up this model # and it does not show up. Can you please look it up again?
    Vic
  • Kenmore Master
  • 4,654 Answers
Adaptive Defrost Control will be your timer, Good Luck, Sea Breeze
Posted on May 29, 2009
3 Suggested Answers
SOURCE: Kenmore Fridge #596
i found the defrost timer for my Kenmore 596.62239200 / freezer on bottom. it was in the top of the refrigerator compartment behind the light bulb console. had to remove the light bulb cover and then there are two visible screws that hold the defrost timer to the light console. the timer is up on top of the console and is not easily seen. ordered parts on www.repairclinic.com.
Posted on Jun 13, 2008
woodchuck789
  • 4059 Answers
SOURCE: How to check defrost timer on Kenmore side by side
You don't have a defrost timer, you have an adaptive defrost control which determines when to defrost based on how often door is opened etc. If you have a defrost problem check , defrost heater, defrost thermostat
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the heater and thermostat are ok it’ll be the control.
Posted on Sep 08, 2009
Testimonial: "Thank you"
Defrost timer
The defrost timer is part of the electronic control baord located on the back of the refrigerator. If the freezer is not defrosting check the thermistor on the evaporator(freezer) coils. It can cause the control board to thing it doesn'y need defrosting. a common problem
Mar 22, 2014 | Kenmore Side by Side Refrigerator
Kenmore fridge leaks water on floor and then stops cooling. Tech said it needed heater/defroster and would cost $500. Does this sound right.
Ah no. If the fridge was not defrosting then water would not be leaking out.
It sounds like the defrost timer is not completing it's cycle. You may need a new defrost timer.
The cost of a new timer, call out, fitting and testing could be around $375
Mar 31, 2011 | Kenmore Side by Side Refrigerator
Replacing defrost timer,needs manuel
I check there is no free manual for Kenmore, I find. Better follow these steps to replace defrost timer.
Unplug the refrigerator. Locate the defrost timer. The timershould have four metal terminals coming from the bottom of the unit. It isusually situated behind the refrigerator, in the refrigerator's control panel,the freezer compartment toward the front of the cabinet or behind a metal kickplate on the bottom of the refrigerator. Older Kenmore models may have it builtinto the ice maker. Remove the defrost timer by takingoff the kick plate (if there is one) and removing any screws attaching it tothe refrigerator or freezer. Carefully pull the timer out from the wall of theunit so you can disconnect the wiring from the connectors. If removal isdifficult, try wiggling the connectors back and forth to help loosen them andpull on them firmly. Plug the wire connectors into thenew defrost timer and replace the timer in the refrigerator. Secure with screws, replace coverand plug in refrigerator.
Thanks and helpful?
Jan 23, 2011 | Kenmore Side by Side Refrigerator
Refrigerator will not defrost
Remove the kick plate grill at base of refrigerator and turn the timer clockwise slow until compressor stops. That should be beginning of the defrost cycle. After a few minutes look inside freezer or listen for crackling or hissing noise. That should indicate defrost. After 25 minutes if it does not restart then turn again until it restarts. Replace defrost timer. Let me know what happens, Thanks Sea Breeze
May 16, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
How to check defrost timer on Kenmore side by side 596-52673200?
Sep 08, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore won't cool down.
I you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 15, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Kenmore model 57029 side-by-side refrigerator not working
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
Aug 12, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore Fridge Defrost fan wont stop running
Hi, The defrost timer is located in the control panel. There should be 2-4 screws holding the control panel. Remove the screws and lower the panel to see the defrost timer. There are 2 screws holding the defrost timer in the control panel.
Please let me know if this helps you at all or if I can assist yyou further.
Vic
Jul 21, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Side by side Kenmore refrigerator /freezer is not defrosting. Heater has continuity, thermo disc is closed,defrost timer is electronic. Question can defrost timer be put into defrost ( like old fashioned...
i cant post no links on here but i can help you with the technical questions and send parts. my website can easily be found on google for like whirlpool dryer heating element 4391960 im a few spots on top.
Mark
Whirlpool Parts Surplus
Jun 30, 2009 | Kenmore Refrigerators
Kenmore 56549 / 56542 / 56544 / 56546 Side by Side Refrigerator Logo
992 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
