Question about Panasonic PV-C2541 25 in. TV/VCR Combo
Hi, when in June there will be thr passage to digital I'll can countinue to use this tv or I need a converter? Thanks Maria
    President:
  • 788 Answers
According to Panasonic this set is not capable of receiving digital signals, therefore will require a converter box.
You can get a coupon from the government for $40.00 towards the purchase of this box at the following address.
https://www.dtv2009.gov/
You will need an antenna that is capable of receiving UHF signals. Not rabbit ears, but the loop type of antenna that sometimes comes with rabbit ears.
I always encourage everyone to get the coupons from the government, because they are free and you can request two per household. (That’s $80.00)
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Posted on May 29, 2009
Does my Toshiba 65H14 TV need a digital converter box
If your TV is an older TV, everything changed when DTV (now meaning Digital TV) became the default on Friday, June 12, 2009. Older TV's (are analog, newer digital) require a converter box.
Jack
Apr 05, 2015 | Toshiba Televison & Video
We are in Ghana we need frequency and we update to get more channel
Your flat panel TV is probably factory set to receive ATSC signals (Hi-def DIGITAL TV), whereas
Ghana may not have converted from analog TV (NTSC) yet.
Digital TV's cannot receive analog signals. I'm just guessing about whether or not Ghana supports
Hi-Def broadcasts - you'll have to check with (any) TV channel in Ghana. The Analog-to-digital
conversion is an expensive one at the broadcast end, and may not have happened yet in Ghana.
The US conversion took place by FCC mandate June 12, 2009.
There are available $65 (USD) digital-to-analog converters, but what you may need is an
analog-to-digital converter, which doesn't exist. Your Flat-panel TV amy have to wait until Ghana
begins broadcasting a Hi-Def TV channel.
For a HD antenna, a regular old rabbit ear-type antenna will do.
Oct 15, 2010 | Televison & Video
No getting digital reception
With this model tv, if you are using the coaxial connection on the tv to receive local stations you will not get any. The tv is digital, but not the tv tuner. As of June or July 2009 that tv will no longer receive analog channels from local stations as they are now all digital. You need a digital cable converter box to convert the signals to analog. *** This is if only if you are using the coaxial input.***
Mar 08, 2010 | Protron PLTV-32 Television
Hi! just need to know if my tv is ready for digital tv i have the sony kp-57ws520. i've hooked up my antenna and i still dont get a picture thanks for any info.
Your Sony KP-57WS520 television has an analog tuner, so you may need a digital tuner or a converter box to continue to receive over-the-air programming.
If you subscribe to a cable or satellite service, your television viewing should not be affected by the June 12, 2009, cut-off date for full-power analog broadcasting. Please contact your service provider for complete information.
Go here for more info:
http://esupport.sony.com/US/perl/model-home.pl?mdl=KP57WS520&LOC=3
Jul 07, 2009 | Sony KP-57WS520 57" Rear Projection...
Can't get digital converter box to work with Toshiba TV/VCR Combo
You will need to rescan your stations. On the June cutoff date, they reshuffled and renumbered most of the stations.
Jun 16, 2009 | Insignia Digital-to-Analog Converter for...
I have an rca flat antenna. June 12 I rescanned
you probably need a digital converter box
Jun 15, 2009 | Televison & Video
IS THIS TV ANALOG OR DIGITAL?
Hello,This set is Analog and will need a converter boxThank you,Shuttle83http://www.electron-age-technologies-llc.com
Jun 10, 2009 | Sharp 13VT-K100 13 in. Combo
Is it digital? will I need a converter box?
The conversion to digital affects off air reception. Since you have Comcast analog cable, you will not be affected until Comcast decides to discontinue analog cable, which is not likely any time soon.
When that day comes, your old VCR will probably grace a landfill anyhow, and you will need a converter box from Comcast.
May 13, 2009 | Mitsubishi HS-U446 VCR
Will set be campatable after June with the new high def?
Your set is HDTV-ready....
With an HDTV-ready set you’ll need an external digital tuner to watch HDTV programming.
However, if you have high-definition cable or satellite service you can watch those HDTV stations right now on your HDTV-ready set, no extra tuner needed.
which means you will still need a converter box if you use an antenna signal.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 26, 2009 | Televison & Video
Mitsubisi tv CS- 40307 digital capable ?
If you are subscribing to cable or satellite TV, then the answer is no; they will continue to send an analog signal to your TV. However if you are using an antenna to receive your broadcast, then you will need a converter. Broadcast TV (over the air) has switched to a digital signal for most of the channels as of June 12th.
Feb 22, 2009 | Mitsubishi CS-40307 40" TV
Panasonic PV-C2541 25 in. TV/VCR Combo Logo
207 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
