Agitator wont spin
Washer machine wont spin will not turn with hand ,you can here the motor going but it will not spin
  • Victor
    Victor May 11, 2010
    Hi, need clarity. What model # is this unit? Does the washer agitate in the wash cycle at all?
    I want to help, just need a little info.
    Thanks
    Vic
  • 15,935 Answers
Check that the clutch is not failed - and the coupling/drive belt is intact.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Bosch washer won't agitate or spin
brushes are spring loaded you take your motor out of the machine and replace them your machine will work
Jan 06, 2014 | Bosch WFVC3300UC 300 Series Vision Front...
Washer will not spin or agitate
Can you move the agitator freely by hand?
Jun 26, 2013 | GE WJRR4170E Top Load Washer
When I load my washer it will fill with water but wont agitate to wash the clothes. It will however go through the cycle and on to the spin cycle and will drain and spin. It just wont agitate. The...
Thanks for choosing FixYa and welcome to the site. If you have a washer that has a weak agitation or no agitation at all, here are some possible solutions. You need to check your belts. Most washers have one or two belts. Check your lid switch. If a lid switch is bad, it can cause the washer to not work properly. Sometimes, they will not work at all. Make sure you check your drive motor. The drive motor controls the spinning, draining, and agitation. Most washers have the reverse motor, meaning the shaft rotates in both directions, clockwise and counterclockwise. It is possible to lose one direction and not the other. Some washers have a clutch that controls the agitation. If it is bad or worn, it may prevent the agitator to work. Most of these washers come from General Electric. You could have a bad motor coupler. They are located on the side of the motor drive inside the washer. It is also possible that you have a bad transmission. Check the agitator itself. You could have a bad spline or two. The splin accompanies the shaft and allows the movement of the agitator. If you rule out all the parts above, you may have an electrical issue or an issue with the control board. It is very important to test each part and make sure it is getting power. If a part is not working and not getting any power, the power loss may be the reason that it doesn't work. You can test the current in the wires with a voltage meter. Thank you very much for reading this tip and thank you for using Fixya
Feb 25, 2011 | GE WPRB9220C Top Load Washer
Washer motor humms and won't spin after filing up with water
remove the water pump from the motor but not from the hoses and start the washer. if it starts then you have a sock or something caught inside the pump holding the motor. remove the object or replace the pump if needed. if the motor wont start then unplug the washer,remove the motor and turn by hand. if it feels hard replace motor. if it moves then leave motor out and move the gear case where the motor connects by hand. if it wont move then 2 things may happen. 1)gear case lockup or a piece of clothing caught between the tubs.
if the washer agitates but wont spin with the humming sound then I say the later. a piece of clothing caught between the tubs.
Feb 10, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer wont agitate
if it wont agitate,then it's either your motor coupling,transmission,or capacitor
Feb 11, 2010 | Kenmore Washing Machines
Washer wont agitate or spin motor hums i canturn
if the moter hums when working but does not move time for a new moter the torque side of the moter has gone look on ebay or espares
Jul 29, 2009 | Washing Machines
Kenmore Washer No Spin >> Motor problem
It's probably the motor coupling. Same thing is happening to me, but I can not gain access to the motor
Mar 14, 2008 | Kenmore 24032\24036 Top Load Washer
Won't Agitate
If you can hear the motor during the agitate cycle, the the transmission has stripped gears.
Dec 17, 2007 | Frigidaire FWS833A Top Load Washer
Washer will not agitate but will spin
You are correct that motor turns one direction for agitate and the other for spin. The problem you describe sounds serious but there is a chance it is not. First, try to turn the transmission by hand. If it wont turn by hand, remove the agitator and see if something has gotten under it and has it locked to the basket. To remove the agitator, pop off the top cap and look down inside. You will see the bolt that holds the agitator on. After you take it loose the agitator will slide off.
If there is nothing there, the transmission will need to be replaced. If the washer is less than 5 years old, the transmission may still be covered by warranty. Check your owners manual for warranty details. Post back to let me know what you find out.
Oct 21, 2007 | Maytag Atlantis MAV6260AWW Top Load Washer
Washing Machines Logo
89 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
