Question about Dishwashers
The seal of the dishwasher is broken and the spot welding on the stainless steel strip that holds the seal has pulled away from the tub.
The seal of the dishwasher is unable to be replaced due to spot welding on the stainless steel strip that holds the seal has pulled away from the tub.
  • cpirie2 May 29, 2009
    Thanks for your prompt answer to my problem! I will try this.
  • Anonymous Mar 15, 2014
    samsung dishwasher tub seal
  • 3,600 Answers
Use super glue to glue in place in spots cut away seal near the weld seams, then make sure the door closes ok then get 5 minute epoxy and glue the seal on where it comes off, it's a permanent fix for a old machine but it will work. so go ahead and replace the seal.
Posted on May 29, 2009
Hole in stainless steel dishwasher tub... How can I patch it?
To make a permanent repair on stainless steel, it needs to be welded. If the hole is small & accessible from both sides, it can be repaired temporally by inserting a machine screw through a tight fitting metal washer, then a tight fitting washer; place the screw through the hole and install another rubber then metal washer on the opposite side. Tighten the washers in place using the proper fitting machine nut.
Oct 29, 2013 | Dishwashers
Tip
Stainless Steel 316 Pipe
Stainless steel type 316 is part of a family of stainless steel alloys (304, 316, 904L). The 316 family is a group of austenitic stainless steels with superior corrosion resistance to Stainless Steel 304. This alloy is suitable for welding because it has a carbon content lower than 301 to 303 series alloys to avoid carbide precipitation in welding applications. The addition of molybdenum and a slightly higher nickel content make Stainless Steel 316 Pipe suitable for architectural applications in severe settings, from polluted marine environments to areas with sub-zero temperatures. Equipment in the chemical, food, paper, mining, pharmaceutical and petroleum industries often includes Stainless Steel 316.
Stainless Steel 316 pipe manufactured at Duplex Supply Inc. are long, hollow tubes that can be used for a number of purposes. They are an integral part of the piping systems. The first methods for producing steel pipe were introduced in the early 1800s, and they have steadily evolved into the modern processes we use today. Pipe systems around the world involve connections which are provided by fittings. Steel pipes are consumed in bulk and provide for onward transmission of liquids and gases. They can be connected to fittings by welding and the structure is supported by connection of flanges. Steel pipes available in two types: Seamless Steel Pipes and Welded Steel Pipes. For both types we first cast raw steel into a more workable starting form. We then make it into a pipe by stretching the steel out into a seamless tube or by forcing the edges together and sealing them with a weld.
Stainless Steel 316 Pipes Duplex Supply
on Mar 22, 2017 | Miscellaneous
Tip
PERMANENT OR TEMPORARY FIX OF REFIRDGERATOR FREEZER DOOR SEAL!!
I picked up a used RV fridge once and the seal around the door had weakened and stayed pulled out and away from the door metal.
There is generally a long strip of magnate inside the seal that helps the door to weld its self closed to prevent outside air from entering.
I was irritated with this because once they do not seal well then the fridge/freezer has a tendency to run more often, not to mention allow moister inside which of course causes freezer burn and ice build up and a higher temperature in the fridge and freezer.
So one day I was looking at it and one of those huge light bulbs appeared over my head.
I went and borrowed my ladies hair dryer and grabbed a pair of pliers.
By holding the seal in the damaged spot and pulling with some force, (But not too much force), and pointing the dryer on the high setting at the pulled out area it will heat the seal up and make it very soft. While holding it and the more it softens let off the pressure a little as to not allow the seal to tear on you. The plastic over the magnates get pretty soft.
After holding it out for a minute or so then move the dryer away but continue you hold the seal pulled out until it cools down. Release the seal once cool and test the door closed.
You may have to do this in several inches of the bad area and you may need to do it several times but with a little patience this will work.
It beats the hell out of having to fight with and replace the hole new seal.
Be sure to clean the seal on the magnate side and the metal it sticks to with some steel wool or a good stiff scouring pad to insure the best seal to take place.
on Apr 22, 2010 | Refrigerators
The door is getting rusty. I believed that stainless steal didn't rust. Is there a way I can remove the spots?
Normally these appliances use brushed steel which gives a stainless steel look.
Get a magnet and run it on the sheet. If it sticks then it definitely is not stainless steel.
However, with wear and tear stainless steel surface does break down causing rust to start.
To remove rust go to this site.
Mar 22, 2011 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Door spring broken
You should have one at the bottom corners of the door. Pull the dishwasher out about a foot and you should be able to see the broken spring and the hooks it connects to. Screws under the counter top hold the dishwasher in.
Apr 22, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Fossil stainless steel earrings needing repair.
Joining Stainless Steel is very difficult, most items being spot welded which is more akin to the engineering rather than the jewellery trade. You might consider affixing a new stem which has a flat plate attached. These can be cemented on and would be hidden when worn and are available widely, I saw them on sale in John Lewis.
Feb 01, 2010 | Fossil Watches
LG LDF8812ST WONT DRAIN JUST INTERMITTENT BUZZ NOISE
Hi, there may be an obstruction in the pump housing that is causing the motor to freeze or, the impeller may be stripped and , jamming the pump. this will cause the hum you are hearing. the best way to inspect is to , extract the drain pump by, removing
the bottom drain filter housing or sump. manually
move the pump impeller to self it is moving freely. if the impeller is stripped, it will not be able to produce the draining surge necessary to pull the water out.
If the impeller is fine and, there are no obstructions visible, this will confirm pump failure.. replace the pump in this case
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
Jun 19, 2009 | LG LDF8812 Stainless Steel Built-in...
Dishlex Global Unable to remove heater element retaining screw
I have a simialar problem with the Dishlex 450 Global model, after searching for the heating element on line, I found a picture of the element (450 model), showing that the Stainless Steel screw is actually spot welded to the element bracket, hence you should be able to remove it by accessing a retaining nut from underneath the dishwasher....(turn power off first!)..
May 24, 2009 | Electrolux 18 in. ESL4114 Slim-Line...
Noisey pump
Take the drain pump apart and look for debris, or broken pump impeller. Remove the lower spray arm and filter assembly, check for debris in the sump and check the drain check vavle to make sure it is sealing properly. While in there make sure the food disposer blade are not clogges with debris.
Jan 26, 2009 | Whirlpool 24 in. GU1500XTLS Stainless...
Vev Vigano Kontessa 4 cup
Any welding shop with a TIG welder should do. It may take a few calls, but ask if they can weld stainless steel.
Good Luck
Mar 09, 2008 | Coffee Makers & Espresso Machines
Dishwashers Logo
434 people viewed this question
Top Dishwashers Experts
