Question about Fellowes Office Equipment & Supplies
Full basket light keeps coming on even though basket is not full
Full basket light comes on even when basket is not full. Comes on regularly
  • 105 Answers
You need to clean or replace bin full sensors.
Posted on Jun 02, 2009
1998 Dodge Ram heater air flow not working
check and test blower --possible motor failure
Aug 29, 2017 | 1998 Dodge Ram 1500 4WD
We have a CR220 fellowes shredder. It will shred 1/2 of a peice of paper, then the basket full light comes on even tho the basket is empty.
you can try cleaning the "bin- full" sensors. they are located on the inside of cabinet, on the bottom of the shredder "head". one will be to the left side of basket and one to the right. they kind of look like little glass eyes mounted inside of black rubber casings. paper dust on these will do this sometimes. if that doesn't do it then it sounds like your "bin-full" sensors are bad. a known problem with these shredders. fellowes has come out with modified sensors. if it was purchased within 2 years, it should still be under warranty.
hth,
razors
Mar 10, 2011 | Fellowes Office Equipment & Supplies
The basket full light comes on even when the basket is empty. if you hold the shred button down it will shred as long as it is pressed
needs bag full retorfit kit available from fellowes if under warranty or we have the part for sale if not under warranty cooksmobileshred@bellsouth.net
Mar 19, 2010 | Fellowes Powershred 220CC Shredder
No cool air comes out of our unit even though it's running. System is about 2 years old-a little less. Filter regularly changed. The pan underneath is also full of water.
are the unit is upflow (on the closed) or horizontal (most like it on the attic)
if is horizontal and the drain pan is full seems the main drain is clogged can you blow air thru drain?  make sure you dont have a flow swith on the drain pan that prevent the condenser to come on
Sep 27, 2009 | Carrier Heating & Cooling
The empty basket light stays on all the time
Try cleaning the bin full sensors. located on both sides of your machine, inside the bin,under the cutter head. If that does not solve problem, you need to replace bin full sensors.
May 04, 2009 | Fellowes Powershred 320 Shredder
Basket full light on
without seeing the product, there are 2 (two) things to check.
First, unplug the shredder and go underneath where the bin full flap is. Sometimes paper debris gets stuck between the flap and switch. Check to ensure the switch is not out of adjustment. you'll have to remove the top cover to perform this. Otherwise, your PC Board is defective.
Mar 02, 2009 | Fellowes 2200 Cross-Cut Shredder
The "bin full" keeps on coming on
first off, fellowes has had problems with the bin full sensors that sometimes, can only be corrected by replacing them. however, there are two things to check. make sure it doesn't have a bunch of shredded paper hanging down from the cutters. that can trigger the bin light as the sensore are located under the head, but above basket. last, but not least, clean the sensors. they get paper dust on them after awhile causing same indication. if those two things don't fix it, it will have to have sensors replaced.
good luck,
razors
Jan 20, 2009 | Fellowes Manufacturing Powershred C-220...
CANON FAX L100 COMES UP MEMORY FULL
We had the same memory full problem. Just unplug the main switch and it will automatically reset the printer and you will be able to send and receive faxes after.
Feb 05, 2008 | Canon FAX-L1000 Plain Paper Laser
406 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
