Error messages I have been getting the "suds", F02 messages and I took the drain hoses of from inside the washer and the hose on the out side and cleaned them, put them back on did a load of laundry and I'm still getting the Suds, F02 and now I'm getting the F09 error message. Could you please suggest some things that I need to do to fix these problems. Thank you Donna
  • 3 more comments
  • livy05 May 02, 2008
    I have had my Epic just over 1 year. Have loved it. I am now getting errors "F02" and SUD". I have no kinks or clogs in the hoses. I don't know how to check the "drain pump filter" or I would do that. Anything else? I am in the process of doing a couple of loads with no cloths to "rinse" it out. Need help
  • sdunlea Jun 11, 2008
    We have a He(3) kenmore Elite front load washer. Today I had a small load in it and heard a ticking sound when it was on the wash load. Then it smelled like something was burning. Shortly after that, the F02 error appeared. I checked the drain hoses and they seem fine. I tried to start it again, but it won't do anything.
    Any ideas would be very helpful.
    Thanks, Stephanie
  • jlt24dcx Jun 25, 2008
    After one year of perfect washing, we can't go through one cycle without SUDS or F02 errors. I checked the drain hose, the relative position of the hose to the outlet, washing without detergent, unplugging the unit. Apparently someone has found a solution. Please help....
  • masciasofia Nov 07, 2008
    Kenmore Elite HE 3t posts a f 02 error, which is a drain obstruction error. The drain hose has been checked so we assumed the pump was the problem. ran the test cycle and pump worked fine. not sure the pump is the real problem, so waited 1 1/2 hours and the washer drained and spin fine. tryed to use is again and same error appeared. What is it?
  • dunliz Apr 13, 2009
    I need to know what the solution was. I am having the same problem.
I had same problem. Turns out there is a filter for the drain pump on this machine, not mentioned in the user manual. Take off the toe plate (the lower panel on the front). There are three screws. (These screws are not normal heads - you will need a Torx driver, either a T-20 or T-25, from any hardware store, plus a holder). The screws are on the very lowest part of the toe plate. When you get the toe plate off, you will see in the middle a round white plastic cover, which you can twist to the left and remove. Some water will flow out when you do this that has been trapped behind the unbelievable gunk that has been building up there since you did your first wash. Might find something you thought you had lost, in fact. Clean that out and put it back and you should be set!
Posted on Dec 01, 2007
Thank you so much. It worked.!!!!!!!!!!
Posted on May 02, 2008
The solution worked!.....thank you!!! :-)
Posted on Apr 07, 2008
Whirlpool duet flashes F 02
The f02 error code is caused when the unit control thinks there is still water in the tub after it has tried to drain. If the washer is full of soap suds it will also display an f02 error code. You will need to use only name brand HE detergent. If your washer is not draining the water out you will need to clean the pump filter. I have provided the instructions below. Run the washer in a drain and spin to ensure the pump is running. If the washer has no water and no suds the problem will be either the pressure switch or a plugged pressure hose. To check the pressure hose you will need to remove the top and remove the hose from the pressure switch. Ensure the hose is clear by blowing into it. If the hose is clear I recommend replacing the pressure switch.
Jan 30, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F02
Error code HF
Washer displaying code message and tone sounds S "HF" 0Nater Inlet Problem--no water or insufficient water supply) Select PAUSE/CANCEL twice to cancel the cycle. Unplug washer or disconnect power. Check the following: Are water faucets completely turned on? Are screens at inlet hose connection to washer clogged? Are water inlet hoses kinked? Are water inlet hoses frozen? Plug in washer or reconnect power. Re-select cycle and press START. If the problem remains, call for service. "F02" (Drain Problem) Select PAUSE/CANCEL twice to cancel the cycle, Unplug washer or disconnect power. Cl_eck the following: Is the drain hose kinked? ts the drain hose frozen? Is the drain hose clogged? Is the drain hose more than 96 in. (2.4 m) above the floor? = "SUD" (Suds Routine) When excessive suds are detected, a suds routine
Sep 23, 2010 | Kenmore Elite 45986 Front Load Washer
F02 Error message
57f1973.jpgUse a nutdriver (1/4th in) to get that bottom panel off.001354b.jpgaab6887.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code f02 comes up
Mar 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F02 problem. Took drain hose and cleaned that out but it didnt help. Is there another spot to clean out?
if the pressure switch detects either water or suds, it commands the drain pump to continue. After 8 or so minutes, if it's still detecting water or suds, the F02 error is displayed.
try the following :
1. Check Wire Harness connections -
2. Check Drain pump. , as water drains at a rapid rate
3. Check Drain pump motor - , as water drains at a rapid rate
4. Check that the Drain hose and Drain Pump Filter is clear of
foreign objects. – , run a cable through both hose assemblies (exterior and interior) and to check if blocked.
5. Check the CCU –.
6. check for kinks in the hoses, and the height of the pump if beyond what the manual recommends.
if okay then check the Pressure Switch if stuck then run many Rinse and Normal cycles with no detergent and if you still get this F02 error. checked the state of the Pressure Switch’s Empty and Level 1 contacts which intermittently reported correct water level condition (EMPTY and Level 1). In all cases is contacts 11 and 14 (SUDS) continuously made (connected) irrespective of water level, rinse conditions and the use of no detergent.
Iremove the pressure switch and test it by blowing into the inlet and check to hear the switch click, test the switch
blew into the pressure switch hose to clear the blockage,
Oct 21, 2009 | Kenmore Elite 45986 Front Load Washer
I have a Kenomore Elite HE4t Washer. I am getting an F02 error message. I've tried to rerun washer & get SUDS on and off. Fo2 message appears again and cycle shuts down. Door will not unlock. Any...
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Oct 14, 2009 | Kenmore Elite HE4 Electric Dryer
What does the "sud" message mean?
hello fo2 means if the drain time exceeds 8 minutes the water valves are turned off and f/02 flashes. things to check / check the drain hose for any kinks and blockages check the electrical connection to the pump make sure the pump is running / check the drain pump filter make sure its not block if these do not sort the problem replace the pump. to clear the display press pause and cancel to clear good luck
shaun
Mar 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F02 fault on a hot point washer says motor jammed
I suspected suds build up, so I tried both regular wash cycles (e.g. Normal) and Rinse and Drain cycles multiple times to clear suds in the system, but still received the F02 error. Sometimes the SUD error message came up, but not consistently.
I ran the built-in Diagnostics tests. It made it to C:06 then got stuck.
In both scenarios above, the washing machine continued to try to pump water out, despite the fact that all the water had already been drained. After 8 or so minutes, the F02 error came on. As I understand it, if the pressure switch detects either water or suds, it commands the drain pump to continue. After 8 or so minutes, if it's still detecting water or suds, the F02 error is displayed.
I performed the following with no success:
1. Check Wire Harness connections - OK
2. Check Drain pump. – OK, as water drains at a rapid rate
3. Check Drain pump motor - OK, as water drains at a rapid rate
foreign objects. – OK, ran a cable through both hose assemblies (exterior and interior) and not blocked.
5. Check the CCU – appears to function normally.
6. There were no kinks in the hoses, nor was the height of the pump beyond what the manual recommends.
After more diagnostics and troubleshooting, I found that the Pressure Switch was stuck and reported the SUDS state (continuity made between contacts 11 and 14 on the Pressure Switch itself). I ran many Rinse and Normal cycles with no detergent and still got this F02 error. I checked the state of the Pressure Switch’s Empty and Level 1 contacts which intermittently reported the correct water level condition (EMPTY and Level 1). In all cases contacts 11 and 14 (SUDS) were continuously made (connected) irrespective of water level, rinse conditions and the use of no detergent.
I removed the pressure switch and tested it by blowing into the inlet and did hear the switch click, so it seemed to work properly. Given the diagnostics above, I concluded that the pressure switch hose must have been clogged.
Good Luck!!
Thanks
Jul 24, 2008 | Kenmore Elite 45986 Front Load Washer
FAGOR WASHER FAULT FO2 WHAT IS THIS CAUSE
Good Luck!! Thanks for using FixYa!!
Mar 05, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
521 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
