Question about Minn Kota Maxxum 55 Freshwater Bow Mount Trolling Motor
Minn Kota power drive trolling motor will not steer to the right **** huard my minnkot will only steer left. I do not have a foot pedal, use the wrist remote control. even goes left when pressing down control to go right. Any help would be appreciated. Thx!
  • 3 Answers
There is a good chance that he control board is bad. This is a common problem with these units. I have replaced my control board twice.. When the control board goes out, the some function of the unit will not work correctly while other functions work fine. The first time mine went out, the prop motor would not work. The last time the board went out, the unit would only steer right.
Posted on Jun 04, 2009
  • fishing4fun Jun 06, 2009
    If you have the Auto Pilot feature on your trolling motor, you will have two control boards. The Auto pilot control board is likely the one causing the problem.
I have a minn-kota Endura 45 trolling motor and I lost my prop. Model 135446. I need to know what replacement prop will fit my trolling motor. S/N K019mk00612. Thank you
Trolling Motor Replacement Props - Minn Kota
https://www.minnkotamotors.com/.../Trolling-Motor...Props/Replacement-Props/
Minn Kota builds the world's toughest and most innovative trolling motors, ... MKP-38 WEEDLESS WEDGE 2 PROP ... MKP-24 WEEDLESS WEDGE PROP.
[PDF]Prop Selection Guide - Minn Kota
https://www.minnkotamotors.com/WorkArea/DownloadAsset.aspx?id=3275 Sep 30, 2016 - Prop No: 2091160. Service Part No: 1378131. Motor Diameter: 3-5/8". Prop Nut ... All Trim-N-Troll Kits. Part No: ... All Terrain 30, 33, 36, 40, 42, 44; Edge 40, 45; Endura 30, 34, 36, 38, 40; Endura Pro 32, 38; Maxxum. Transom ...
Minn Kota Motors
https://www.minnkotamotors.com/Products/MKP-9-PROP-NUT-KIT-A/ Quickly, easily remove or replace your prop with this kit. ... Search. TROLLING MOTORS. SHOP ALL ... MKP-3 Vanishing prop (part number 2061151 / 1865004)
Minn Kota Prop Compatibility Chart - TrollingMotors.net
https://www.trollingmotors.net/blogs/.../86967623-minn-kota-prop-compatibility-char... Minn Kota Prop Charts Determining which Minn Kota Prop you need can be ... Minn Kota Endura (non-C2) Motors ... 30, 36, 38, 40 & 45 lbs Models, MKP-2 ...
Minn Kota Props - Walmart.com
https://www.walmart.com/c/kp/minn-kota-props Minn Kota EDGE 45-42 Bow Mount Trolling Motor ... Minn Kota Endura Maxx 55 lb Thrust Freshwater Trolling Motor with Bonus Power Center Value Bundle. minn kota endura 45 trolling motor propeller Google Search
Oct 23, 2017 | Boating
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    On a Minn Kota All Terrain trolling motor, what should the MOM/OFF/CON switch be set to when using the foot pedal manually?
    You should only use the MOM (or momentary) setting when using the push button the foot pedal. Con will just keep the motor running and your foot control will only allow for direction and speed!
    Jul 06, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
    How do you operate the motor? I have no details as to how the motor operates. Its a minn kota trolling motor that mounts on the front of my boat. I need to know how to operate the foot peddle.
    The pedal has generally four functions:
    1) Forward and back on the pedal make the motor go left and right (push forward to turn the motor right, push back to turn it left)
    2) Momentary power - the little 'button' towards the top will engage the motor as long as you press down on it.
    3) Selector Swith - on the side of the foot pedeal there is a switch with the following settings Con - Off - Mom (Continuous - keeps the motor going all the time, Off - well it's off and Mom - will only go when you press the momentary button).
    4) Speed select - the knob on the left controlls how fast the motor goes.
    It takes some getting used to but offers tremendous control and hands free operation!
    Jun 25, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    I cant adjust foot tension on minn kota edge
    Hi!
    Flip the foot pedal over and tighten the set screw where the cable enters, this should help out.
    Here's a schematic:
    Edga 40
    Best of luck!
    Mike
    Jun 06, 2009 | Minn Kota Edge 40 Freshwater Bow Mount...
    Prop spins slow on any speed on the foot pedal
    There is a good chance that the control board is bad. This is a common problem with these units. I have replaced my control board twice. When the control board goes out, some function of the unit will not work correctly while other functions work fine. The first time mine went out, the prop motor would not work. The last time the board went out, the unit would only steer right.
    May 27, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    It is the circuit board in the foot pedal. You will have to replace the whole foot pedal. This is a very poor design. The thin plastic which protects the contacts gets a little hole which allows water to enter and consequently the contacts corrode. Has happened to me two times in past four years. It might be OK for operation in a dirt-free water-free environment; but not under actual fishing conditions.
    Apr 29, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    Where can i get a circuit board for my minn kota foot pedal Part # is 9901-200c
    http://www.northlandmarine.com/MinnKotaQuickRef.htm
    You need your serial number of the trolling motor, length of shaft, and thrust poundage.
    or you could call Minn Kota direct and give them the same information at 800-227-6433.
    Apr 22, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    Minn Kota Maxxum 55 Freshwater Bow Mount Trolling Motor Logo
    1,997 people viewed this question
    Top Minn Kota Boating Experts
    Mike Marcotte
    Mike Marcotte
    Andrew Taylor
    Andrew Taylor
    Colin Stickland
    Colin Stickland
    Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
