Question about Kenmore 63652 Microwave Oven
Metal in oven.
My young daughter placed a travel mug with liquid in our oven for about two minutes. The mug is made up of some metal, plastic, chrome, etc. Could she have damaged the oven because of this? Also now the oven has a burning smell when used. Any Ideas??
  • 3,037 Answers
Yes, most likely she damaged the magnetron and so the cheapest method once the unit dies totally is to get a new microwave. The scientific reason of what happens can be found below.
  1. If a metallic container is heated up in a microwave, many reflected waves are generated by the metal. The reflected waves return to the antenna of a magnetron, causing an increase in temperature. This causes the deterioration of the magnetron and generates electronic discharge easily, resulting in microwave failure.
  2. If a metallic container is close to the wall of a microwave, electronic discharge occurs between the wall and the metallic container, causing microwave to develop problems. Also, if this happens, users are surprised at the noise and the light, then they complain to the manufacturer. And so, we manufacturers prohibit the use of metallic containers in microwaves.
Benjamin
Posted on May 29, 2009
Changing interior light on GE jvm1790
1. Unplug Oven
2. Unscrew 2 screws on top front of oven
3. Pull of front vent (might need a little force the
first time but not to much or you will crack
plastic)
4. Unscrew screw facing you near the front that is
attached to metal plate on bottom of opening
behind the vent.
5. Pull out metal plate (box) carefully not to
damage any wires.
6.Bulb is in this metal box, pull out old one and
press the new one's prongs into holes (be
careful and gentle the bulb breaks easily,
don't try to pull it back out to see if it's all
the way in or you will most likely pull a
prong out of the bulb)
just firmly press bulb
into place.
6. Screw metal plate back in place.
7. Plug in oven and test bulb.
8. Unplug oven again and put vent back on with
the 2 screws.
9. Plug in, set clock and your done.
The first time I opened it up was to look for the bulb. The vent needed a little pulling to come off. The second time (to put in new bulb) it came off easier and whole thing took about 5 minutes.
Hope this helps.
Just in case: I am not a professional nor claim to be. This is based on my own experience. Yours may differ. Unless you feel totally comfortable you should contact a licensed electrician or an authorized service agent.
Oct 18, 2010 | GE JVM1790 Convection / Microwave Oven
My ge profile spacemaker oven is leaking water(?) i removed the metal filter and the liquid appears to be coming from inside. there is a metal "plate" about 1 inch above the filter and the liquid is coming...
unless something strange happened (like a spill) then the only component that has fluid in it is a large capacitor that is used to drive the magnetron ... if its case is ruptured then it will leak a few teaspoons of electrolyte .. thats a clear water or oil based liquid .. the failure of the aluminum case will cause a pop one time ... then its likelly the oven will quit working .. its also possible, if you have an outside vent for your microwave, that water is blowing into that vent down into the microwave .. check the exhaust to make sure its outside louvers are not damaged ..if it goes to the roof then make sure the rain cap is in place ..
Jul 02, 2010 | GE Profile Spacemaker 1.8 Cu. Ft....
Arcing while using micro wave
Quite often this is due to grease or food particles stuck somewhere in the cavity of the oven or stuck on or behind the waveguide cover.
The waveguide cover (also called a spatter shield) is usually about the size of a playing card and often held in place by a plastic rivet.
In some models it is a larger stirrer cover type made of thicker plastic in the ceiling of the oven.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced. It provides important protection for the magnetron.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Nov 25, 2008 | GE Advantium 120 Convection/Microwave Oven
Second oven with the same problem
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
The best place to order Sharp parts is Tritronics.
Oct 08, 2008 | Sharp R-353 Microwave Oven
Sparks coming in side the micro oven. when I start the micro oven sparks are coming in side the oven.
The waveguide cover is usually about the size of a playing card and often held in place by a plastic rivet.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
Aug 04, 2008 | Sharp R-930AK Convection/Microwave Oven
The microwave is arcing and we have checked to make sure nothing metal is in or around the microwave. Food was catching on fire.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 26, 2008 | GE Microwave Ovens
Put in food and then started pooring out? smoke smells like plastic??
Please write back with your brand and model number if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 10, 2008 | Emerson Microwave Ovens
Sparks fly when I use my microwave!!!
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
May 11, 2008 | Frigidaire FMV156D Microwave Oven
My jes1290sk oven flashes over when I turn it on
In some models it is the plastic ceiling.
Please reply back with more details if you need further help.
Apr 24, 2008 | Microwave Ovens
My sharp r-510hw flashing like crazy
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean.
You can order Sharp parts from Tritronics at http://www.wehaveparts.com
Mar 22, 2008 | Sharp R-510HW Microwave Oven
Kenmore 63652 Microwave Oven Logo
270 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
