Question about Ruud Matching Split Air Conditioner
Wont Turn on at breaker or fuse box.
I purchased a home that has a Rudd 10 seer airconditioner. It does not turn on. No sound,fan not even trying to turn. How can you tell if it's a fuse, condensor or ? I have taken off the casing and there is really nothing to tinker with. Help, it's warm outside.
  • divewmn May 31, 2009
    I now have AC - Yes! it turned out to be that thermostat. The cheap thermostat that was installed when I purchased the house from previous owners wasnt the correct voltage. I purchased a digital and now it works great! Thanks for all the assistance
Check the braker box, and also there shold be a togle switch by the furnace that could be turned off.it sounds like you don't have any power at all
Posted on May 29, 2009
Rudd acheiver 10 heat pump wont stay cool
did you change the air filter and do not set it below 70,the tstat is not a gas pedal its works like a light switch, on or off, also please don't use your breaker as a switch its a safety device and will be damaged over time,If the unit starts to form ice (and it should never do that)
set the tstat from cool to off and the fan button from auto to fan on,this will speed up the thawing
Jul 02, 2013 | Ruud UBHC Air Conditioner
Minka ceiling fan
Replace batteries in remote,if still not working,go to fuse or breaker box and see if fuse or breaker switch is off or fuse blown,if good there,then it could be a bad switch on fan or remote is bad.If switch is bad,turn power off at box,remove, take to Home Depot or Lowe's and match up.
Nov 20, 2012 | Minka Dryers
Amana air conditioner wont turn on. not even fan. has power as we checking the circuit breaker. suggestions?
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Apr 26, 2011 | Heating & Cooling
Intertherm 13 SEER split air conditioner fans wont turn on?
OUTSIDE FAN OR INSIDE FAN OR BOTH. IF BOTH CHECK THERMOSTAT WIRE HOOK UP. IF YOU INSTALLED NEW TSTAT CHECK FOR JUMPER ON RH-RC TERMINALS ON TSTAT BACK PLATE. IF INSIDE FAN COMES ON WITH FAN IN ON SETTING AT FAN ON AUTO LEVER THAN PROBLEM IS AT OUTSIDE UNIT. CHECK FUSES IN BOX ON OUTSIDE WALL. SHUT OFF BREAKER FIRST.
Apr 21, 2010 | Intertherm P3RA-060K Air Conditioner
The furnace wont turn on even though it says it is
not all digital thermostats are compatible with the manufacturers circuit control boards in the furnace. Hunter has had this problem several years ago. Other than that you may have miss wired the unit. usually the furnace is used as backup heat (during defrost) or emergency heat if your heat pump konks out. Are you switching to emergency heat for a furnace call?
Nov 24, 2009 | Hunter Fan Company 5/1/1 Programmable...
I recently bought a 4 ton 14.5 SEER Rudd Spilt system using R-410 and matching Rudd furnace. This system replaced a Lennox 10 SEER 4 ton unit. Now that it has gotten hot in Baton Rouge LA 90-93 degrees....
Sounds like the Unit might be low on charge.But without correct readings not sure.
The new unit with 410 will actually cool better due to higher boiling point temp. of freon type.Poor air circulation could also cause problem.Such as dirty filter, too slow fan speed,dirty coil.Also could have obstruction in freon lines either at pump,in line set,or in coil.
Get someone u trust to check it out and ask for their Rudd Dealership Training Credentials.
Jun 15, 2009 | Heating & Cooling
Fan
Ifs its a small humming sound,then its the contactor pulling in. But if it a loud humming sound then its the compressor kicking in. and the fans not, try to take something long and turn the blades on the fan, if it takes off and run then your capacitor is shot or swollen at the top,which was cause by power surge. Take-off and replace with the same mfd. writings ,on the outside of can. Also check for blown fuses or tripped breaker . the fuses should be in the disconnect box on the wall, or the breaker in the breaker box.. Older house has fuses instead of a breaker box!
Sep 01, 2008 | Bryant Heating & Cooling
Ruud Matching Split Air Conditioner Logo
157 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
