Question about Panasonic Televison & Video
Picture appears neon and saturated/Video channels are white w/cascading black bars
Colors appear glowing neon or saturated. Video Input channels have small black horizontal bars cascading down the entire screen with a white background, even when all of the cables are disconnected from the TV.
    President:
  • 814 Answers
This unit has had a problem with the mainboard of the television. This is the board that controls all the televisions functions.The problem you are having is with the tuner section of the mainboard, this problem may be a with cold solder joints from heat expansion or it could be a problem with component failure.The unit should be taken or sent in to a service center for a complete testing and service.The element customer support telephone number is 1-888-935-8880. The customer support website is http://www.elementelectronics.com/support.html Just tell them the model number of you television and the problem you are having with the tuner. They will be able to help you find a service center to take your television to for repair. I hope this information helps you with your problem.
Posted on May 29, 2009
Installed a new set top box last night and all the channels are black and white - no colour at all - confused!!
vron63
Check your cables between the receiver and your TV to make sure the colors match. If you are using a component cable (green, blue, red, white, red), not matching colors at both ends will give you what appears to be a black and white picture. I hope this helps.
Ray Calo
DISH Network
Mar 09, 2011 | Televison & Video
The picture is black and white and the color won't appear
I would go to Menu-Picture and slide the "Saturation" or "Color" UP (if it has that kind of control)
Feb 28, 2011 | Durabrand PDV-705 Portable DVD Player
Mitsubishi WD5725 DLP set. Picture is Ok before
The set has over 150 capacitors that could be causing the problem but it is at least 1 doing this. Contact Mitsubishi. Some people have been able to get new replacment TVs because of this problem
Mar 04, 2010 | Mitsubishi Televison & Video
Connecting hd cable box to philips 60 rear projection
So, You have Five cable leads, The rgb get plugged into there corresponding colors and the other two are your Red and White Audio Input ------Correct? You do not use the in4, that is for a pc with horiz and vert sync. You use input 1 rgb and plug the red and white into the audio input.....your done!
Jun 06, 2009 | Philips 60PW9363 60" Rear Projection...
My componet/av only shows black and white on my vizio vp422
The 37" Vizio I just bought has a very confusing feature where the same input can be used as either the Y channel of the component or the full video channel for composite. If you plug a component source into the TV and then select the composite input ("AV" on the remote), you will see a black and white version of the full component signal (makes sense as the Y channel is just the luminance component). As sad as it is, I was stumped by this for a while until I happened to hit "COMP" and got full color. FWIW, the manual warns about this, but it really doesn't emphasize the point. I wonder how many returns they get because of this.
Mar 16, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Black and White Only
I had a similar problem when I first connected my son's xbox using the Audio/Video cable (red, white, & yellow connectors). I connected the cable to the TV correctly, but incorrectly selected "component" as the input on the TV setup. Result was black and white display. Switch your TV input mode to "AV" or "Audio/Video" and you will get color.
FYI, "component" TV mode is only used with devices that use the red, green, & blue connectors.
Jan 30, 2008 | Microsoft Xbox Console
Hitachi pj-tx100 black and white picture when using s-video
s-video carries luminance and chromanance. In simple terms, luma provides a a black and white picture, chroma the color data. without chroma, you get no color. Either - the cable is bad (usually in the form of bent/broken pins in the connector ends - the source device is bad - the projector input is bad
Sep 21, 2006 | Hitachi PJTX100 Multimedia Projector
Televison & Video Logo
140 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
