Question about Maytag Neptune MAH5500B Front Load Washer
My machine make too much noise
Hi my name is vicy, I have problem with my washer machine, my machine make too much noise. product name; neptune tligh efficiency 3.3 cu. ft capacity front load washer. MPN= MAH 5500BWW. kakhaphong@hotmail.com
  • 530 Answers
Does it sound like a 747 about to crash in your house? if so you might as well through your washer away because you have a bad bearing and the cost to repair that is about the same for a new one. let me know if this helps
Posted on May 29, 2009
  • 58 Answers
If the noise that you are referring to occurs during the spin cycle (sounds like a turbine or jet taking off) then that would be the outer tub bearing and would mean that you would need to replace the outer tub assy. If however it is a churning type of noise and occurs intermittently throughout the wash cycle then the drain pump would be suspect and in needed of cleaning or replacement...Hope this helps... Bill
What does samsung washer error code dc mean?
Product: Home Appliances > Washers & Dryers > Washers > WF218ANW
dc = Unbalanced load prevented the washer from spinning.
What Do the Information Codes Mean on the Front Load Washing Machine
Jan 03, 2015 | Samsung WF218ANW 4.0 cu. ft. High...
Samsung washing machine wobbles on spin.
The feet of the machine have to to be leveled. When reading the instructions, leveling is important for the very reason you are having difficulties.
Sep 19, 2014 | Samsung 3.5 cu. ft. High Efficiency VRT...
Samsung washer make noise and smoke
sound as rear bearing. have you used soap for front load washer?
May 28, 2014 | Samsung WF218ANW 4.0 cu. ft. High...
What size washing machine is this
Your Maytag Neptune MAH6500A Front Load Washer has dimensions:
Width : 27"
Depth : 29"
Height : 42 1/2"
Capacity : 3.34 cu. ft.
http://www.ajmadison.com/cgi-bin/ajmadison/MAH6500AWW.html
May 22, 2014 | Maytag Neptune MAH6500A Front Load Washer
Its not spinning at all
These washers are out of production. The balance on the spin is the problem...probably not a serviceable issue. Sorry
Mar 09, 2014 | Samsung WF218ANW 4.0 cu. ft. High...
Make loud noises on spin cycle and smoke when we open door
The loud noises seem to be a feature of newer front loading machines. We bought a Maytag and have had similar issues since day 1. We were told the bearings are the problem. They don't last and make major noise as they wear.
Oct 28, 2013 | Samsung WF316BAC 3.79 cu.ft High...
Samsung washer wf209 makes vibration like noise from pump when starting spin cycle
pump clogged. Remove clean out from pump and then remove any debris inside.
Jan 31, 2010 | Samsung WF218ANW 4.0 cu. ft. High...
Kenmore 3.5 cu. ft. I.E.C. Super Capacity High-Efficiency Washer
took the plate of just under the door removed 2 screws then took the black rubber boot that hooks up to the pump and cleaned out the **** that was stuck in there, pluged washer back in after a little crunhin noise everything was back to normal
Feb 02, 2009 | Electrolux Kenmore 3.5 cu. ft. I.E.C....
Maytag neptune mah3000aww tub size
The answer is:
CAPACITY 3.1 Cubic Feet
The reference for this answer can be found here:
http://www.servicematters.com/maytag_library/docs/16010061.pdf
Seach in this document for "capacity".
SECTION 1. GENERAL INFORMATION Page 1-4
Nov 20, 2008 | Maytag Neptune Washer
Maytag Neptune MAH5500B Front Load Washer Logo
274 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
