Question about Kenmore 20.6 cu. ft. Top Freezer Refrigerator
Dripping water from freezer compartment into refrigerator compartment
    President:
  • 1,136 Answers
Hi, Could I get the model #? The defrost drain is plugged and I can get you through this with the #
Some newer models need an after market drain heat strip added.
Vic
Posted on May 29, 2009
Dripping water
Mine had the same problem today. I found the drip tray under the screwed on panels in the freezer was full.
There is an evaporative tray above the compressor in back, and feeding that was a drain pipe that was blocked with crud. Removing and cleaning the cap made it flow freely again. Hopefully that fixes it.
Jan 23, 2014 | Sanyo SR-1030W Top Freezer Refrigerator
Refridgerator side-by side dripping water drips to floor and freezing on bottom of freezer compartment
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 06, 2011 | Crosley CRFF16 15.9 Cu. Ft. Frost-Free...
JDC2389GES side by side fridge Water is leaking inside the freezer and pooling at the bottom.
Hello and Welcome to FixYa!
Actually the leaking water is from the evaporator coil unit....(it is located at the back wall or underneath the freezer compartment). Under normal conditions,Self-defrost refrigerators usually dispose the water generated during the defrost cycle through a tube or channel that directs the water a pan (Known as Drip pan), commonly below the refrigerator unit....
The channel or tube is clogged and the water is leaking to the refrigerator/freezer unit, so you need to clear that blockage/contamination....Once the blockage is removed, the generated water will move through that channel/tube directly to the drip pan and there will no water on the floor in the refrigerator/freezer compartment. This is all you need to do....
Best of Luck,
Your token of appreciation in form of rating would be highly obliged,
Concerned.
Aug 25, 2010 | Jenn-Air Refrigerators
Water dripping in the refrigerator and freezes on the top shelf. It seems to be coming from the freezer compartment. There is a square piece of metal missing from the top of the main compartment. One can...
Removed everything from the freezes. Removed a false bottom from the freezer floor, 2 screws. There was an ice build up under this plastic bottom. I let the ice melt with the de-frost cycle (or frost free cycle). No more water dripping into the refrigerator compartment.
Dec 15, 2009 | Whirlpool Refrigerators
Water weeping out vents in lower back of freezer compartment
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Jun 29, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
WATER DRIPS DOWN FROM INSIDE TOP REFRIGERATOR BELOW FREEZER
Not an original solution - but a good one. Remove panels at the back of the freezer compartment to expose the heater unit or heater wire that defrosts the freezer coils and wrap a solid copper wire gently around the heater/ heater wire and place the loose end in the drain. This will conduct heat to the freezer drain and help keep it open. I did see a manufactured part in one of the appliance parts websites but it did not match my unit.
May 29, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water is dripping from freezer into refrigerator and freezeing
your drain line in the freezer compartment is clogged up, you have to clear by taking the freezer bottom panels off and then flushing the drain line out with something like a turkey baster.
Jan 25, 2009 | Refrigerators
Water drips into refrigerator
sounds to me that maybe your draain lin is clogged up in your freezer compartment above your refrigerator. Look for a clear tube that should be runnig down either on thre outside or on the back wall and clear it out after you make sure that its not frozen. if it is then use either a light bulb or hair dryer to thaw out. Thanks for using FixYa.
Dec 25, 2008 | Refrigerators
Water dripping at top of refrigerator compartment
Try to blow air through the defrost drain hose from the bottom of the fridge to make sure the line is clear for defrost water to drain.
Aug 26, 2007 | Frigidaire FRT17G4B Top Freezer...
Kenmore 20.6 cu. ft. Top Freezer Refrigerator Logo
164 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
