I have an LG DLP Projection TV model RU-44SZ51D. I have replaced the projection bulb and need to reset the lamp-burn timer and turn off the "the bulb needs replacing" indicator.
  • wthomson153 May 29, 2009
    Worked great.. Thanks very much for such a quick response. I had called customer support at LG and was told that it couldn't be done without a special remote that a technician would only have.
    You are great!
    Bill
    You are great!
    Bill
  • 3,037 Answers
I believe to do this, press the ENTER button on the TV and the MUTE button on the remote at the same time. After 5 seconds the screen should come up and it will read "Lamp use time...Total lamp use time ....lamp reset" Press the center button on your remote (the circle button right in the middle of the four directional buttons) and you will be reset to -0- again. Your orange light should now be off. If this doesn't work or if you have further questions, please let me know and I will figure out what else may be the solution but as far as I know, the above should work.
Benjamin
Posted on May 29, 2009
How do I switch the bulb in a DLP projection TV model RU-52SZ61D
I just replaced the bulb/lamp on my LG RU-52SZ51D TV. It was fairly simple. Basically you have 2 screws that hold on the cover panel on the right side of the TV. Once you take off the cover, you'll then see a metal tray with a handle. That has 3 screws, you can then pull out the tray and see the bulb/lamp. The lamp has 3 more screws that hold the little brackets that hold the lamp in place. Last you have the 2 power wires. One is connected by a screw on the left of the lamp, the other is attached by a nut and a washer on the back of the lamp, where you would usually screw in a normal light. The two wires are just connected to a single plug to the right of the lamp which you can remove, you get the new lamp with the wires already attached. All you have to do is plug it in after you mount it back up. Here is the info on purchasing a lamp, sorry but I am still in the process of learning how to reset the lamp indicator light...
Website:http://www.partstore.com/ProductDeta...ModelID=491016
Zenith Projection TV Lamp
Zenith Part Number: 6912B22002C
LG Electronics Model: RU52SZ51D
Don't miss your favorite programs, keep an extra Zenith TV lamp on hand. NOTE: THIS PART IS MANUFACTURED BY OSRAM. IF THE OLD LAMP WAS MADE BY OSRAM, USE THIS PART.
Price: $ 273.83
Here is how to reset the lamp timer.
lamp reset on lge :to reset lamp timer press and hold ENTER or OK on tv display and MUTE on remote at the same time for 5 to 10 seconds, lamp reset box will pop up you can then reset lamp.
Aug 27, 2011 | LG RU-52SZ51D 52" Rear Projection...
LG RU-44SZ63D turned off while watching, heard click noise
Problem is either you need to replace Lamp or your Lamp Fan is defective. For Lamp Call Mats 1-800-68-1118
May 13, 2010 | LG RU-44SZ51D 44" Rear Projection...
Where is the projection lamp in an LG DLP TV, model RU-44SZ51D? How easy is it to install myself?
Hi,Lg lamps are usually in the back.This is your part # 6912B22007A you have to choose between the small square lamp with 4 corners and 2 ventilation holes or big and round lamp. Found it here: http://www.discount-merchant.com/SearchResults.asp?Search=6912B22007A Here's instructions to replace it http://www.youtube.com/watch?v=3hoaqR3jt1A God bless you!
Oct 07, 2009 | LG Televison & Video
LG Rear Projection TV won't turn on
Could be your Ballast Board that fires up lamp or Fan is bad that cools Lamp there is also a Fan mounted up under Light Engine if it stops running set will not come on. CK Fan Behind lamp first if it is OK then replace Ballast Go to E-Bay for Best Deal on that part .
Aug 14, 2009 | LG RU-44SZ51D 44" Rear Projection...
LG DLP RU-44SZ51D Lamp Indicator blinks red
44 inch lg dlp hdtv no picture or sound press power button standby light turns yellow and then back to red
Mar 04, 2009 | LG RU-44SZ51D 44" Rear Projection...
Lg RU-52sz30 rear projection tv does not go on
I have an lg dlp projection tv Model # 52sx4d-ub.I replaced the bulb,everything correctly,but no picture. LG says I have to have a tech come out to reset? Can you help.
Jan 23, 2009 | LG RU-52SZ30 52" Rear Projection...
Picture quality of my LG Projection TV is very poor
Bad Light engine call UED for price on rebuilt one if they have it!1-800-648-6657
Dec 19, 2008 | LG RU-52SZ51D 52" Rear Projection...
Best but repleace bulb but red light still on
So far I have entered the service menu (both menus together) then selected Lamp Replace (option 14) and then pres ok to reset. Version and Lamp (option 11) now reads Lamp life (Khr) = 8 and Lamp use (Hr) = 0.
Jan 19, 2008 | LG RU-44SZ51D 44" Rear Projection...
Do i need a new lamp
i have this kind of tv1.gif model ru-52sz30 and same problem which i fixed by replacing the bulb. there is an access door at the back of tv that you can replace the bulb. if you need more help just post reply again.
Sep 23, 2007 | LG RU-52SZ30 52" Rear Projection...
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Electro Med Services...
