Question about Linksys Wireless-G Broadband Router
No power to my router - Linksys Wireless-G Broadband Router
  • 192 Answers
This is most likely caused by a break in one of the paired wires leading from your plugin transformer to the plug in the back of the unit. You can confirm this by using a voltmeter to measure the transformer output where it plugs into the back of the unit. Set the voltmeter on DC volts. Pull out the small power plug from the back of the unit and insert the positive (red) lead from the voltmeter into the middle opening of the small power plug. Make sure it touches the inside metal wall. Touch the negative (black) lead to the outside metal wall of the small plug. The voltmeter should read around 12 volts. If you don't see any voltage you probably have a break in one of the wires. If you can track down where the break happened you can rejoin the wires using solder. However, I don't recommend trying this if you're not experienced with a solder iron. You may just want to buy another generic transformer to replace the one that's gone bad. Make sure the new transformer has a 12 volt output setting and is capable of putting out at least the same amount of current as the original. The current capability of the original transformer should be listed on it's side. I expect it will be something in the range of 500 mA (milli Amps) to 1 Amp. If you get a new transformer make sure the positive voltage is in the middle and the negative voltage is on the outside of the plug.
Posted on May 29, 2009
  • 256 Answers
Check the wall outlet for power, using a lamp or such. If you can get a multi-meter, set the meter to Volts-DC between 12 and 20. Plug the power supply into the wall outlet and test the other end for voltage. The power supply should tell you its output so the reading should be more than a couple of volts. If it is less or ZERO the power supply is dead. If it has power, then open the router and check for a fuse. If the fuse is dead, replace. If there is no fuse or the fuse is OK then the router may be dead. Best of luck.
Wireless router will not power up?
Capacitors in the power supply have gone bad. Might be time for a new router.
Mar 06, 2016 | Belkin Connect N150 Wireless N Router
Linsys ea6500 blinking
If the Power or Diag LED (Light Emitting Diode) on your Linksys router is blinking, it means the firmware is corrupted. If this happens, you won't be able to do the following:
• Access the router's web-based setup page
• Assign IP addresses to computers connected to your router using its DHCP capabilities
NOTE: This also applies if your router's LED is dimly illuminated.
Listed below are the things that you can do to solve this issue:
Powercycle the router
Assign a static IP address to your computer
Ping the router
Reset the router
Update/Re-flash the firmware using the TFTP utility
Jun 27, 2014 | Linksys EA6500 Dual Band AC Gigabit...
I unplugged my router while on vacation and now, my laptop sees the wireless, but the router does not connect to the internet. PLEASE HELP!
power off the system power off the router power off the cable/DSL modem WAIT 3 Minutes Power on the Cable/DSL modem once it resets, power on the router, let is resets Power on the system, see if you now have internet
Sep 25, 2010 | Linksys Wireless-G WRT54G Router
My router does not seem to be working right; the power light is flashing very quickly and the signal is not being transmitted. how do i get my router to work again?
Press the reset button on the router. Hold it down for 30 seconds. release the reset button. Wait for 1 minute. unplug the power cable to the router and plug it back in.
Wait for 1 minute and check if the power light is Solid on the router.
If the power light on the router is flashing then the router is not working. Try to reset the router again. To press the reset button on the router use a paper clip or ball point pen.
If the power light is still flashing then try to reset the router again. If still the same thing then you will need to new router.
If the power light is sold then you can try to reconfigure the router.
Click Here for step by step by instructions
Sep 03, 2010 | Linksys Wireless-G WRT54G Router
I have a netgear wireless router wgr614-6vguks and when i switch my pc and the router on it takes at least 30 mins to 45mins for the router to power up. Any ideas why?
This could be because of a bad power supply or leaky capacitors in the power supply that takes this long to charge themselves up before full supplied power is applied. I suggest changing the AC power pack first, if after doing this and it still does the same symptom then the routers power DC to DC converter IC is faluty in the router, Cheaper to just buy a new router at this point.
Dec 15, 2009 | NetGear WGR614 Wireless Router
WRT610n router power led light blinks and i cant
If the power light is blinking on the router , then it might not be working properly.
You will need to press the reset button on the back side of the router for 30 seconds. release it. unplug the power cable. plug it back in. wait for a minute and check if the power light is solid.
If not then try to reset the router again.
do the same thing and check if the power light is solid.
If the power light is solid then you will need to set up the router again.
If the power light is still blinking, then connect the computer to the router and check the IP address on the computer. If the IP address is 192.168.1.100 then try to open the set up page of the router and check the settings of the router.
Click Here for step by step instructions
Dec 01, 2009 | Linksys WRT610N Wireless Router
Router will not turn on at all - power lead checked and OK. Before total loss of power router would come on briefly then turn itself off
Make sure that you are using the power adapter that came with the router.
Unplug and replug the power adapter from the router.
If there is still no power on the router, then you will need to replace the router.
Oct 23, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
My belkin router wont light up?
  1. Try plugging the router to a different power outlet.
  2. Reset the router.
  3. Check the power adapter specification of your router and if you have another power adapter that has the same specification then try that power adapter to your router.
  4. If using another power adapter and your router will not power on still, it is possible that your router is faulty already.
Hope this helps!
Nov 10, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin problem
Try other power outlet first. If the router have a power off and on button, then switch it on. Check the router power specs. If you have other device with the same power specs, try it out. If it is still within the warranty of Belkin, try to have the router replaced by them.
May 05, 2008 | Belkin (F5D7230-4) Router (587009)
If the power light on the router is Blinking very Fast .
Then Reset the router fro 30 sec and then leave the power cable unplug for 1 min .
Then plug the power plug back in and then check ............if the power light stop light stop blinking then the router can be reused or else the router has gone bad
Mar 09, 2008 | Linksys Wireless-G Broadband Router
Linksys Wireless-G Broadband Router Logo
156 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
