Question about GE Spectra JGBP35 Gas Kitchen Range
Error Code F@ on GE XL$$ Range
I keep getting an F2 error code on the display. If I unplug the unit it will reset and not show for about 3 hours and then it displays F@ again with the beeping.
Suggestions???
GE Model JGBP35GEP3WG
Thanks
Brian
  • Collin Clark
    Collin Clark May 11, 2010
    fix "f@" to "f2" more ppl will try to help lol =]
  • 530 Answers
Usually f02 means you have a shorted keypad. does it randomly beep at you if so this is a symptom. you need to replace your keypad
Posted on May 29, 2009
Haier Wine Cellar, Dual model, displays EE error code and was heavily iced on the interior back.
If the refrigerator or freezer displays error code, request a technician to check, please call the service
Different series display different error codes.
The error codes for the refrigerator: F1, F2. F3, F4, F5, F6, F7, EO, E1, E2, E6, Er, Ed, an so on
The error codes for the wine cellar: F1, F2. F3, F4, F5, H1. H2, A1, A2, E1, E2, EE, HH, LL, and so on
Notice: If you power off then power on, maybe the error code disappear, but it will display again after a few hours.
Mar 27, 2018 | Haier Refrigerators
Display reads F2
have you tried a hard reset and left unit powered off for few hours?
Jul 10, 2008 | Whirlpool Kitchen Ranges
Getting a PF7 code with beeping on my stove. Reset breaker, didn't fix it. Any help would be appreciated.
GE oven error code "F7" and how to fix it ' AskGene.com
www.askgene.com/.../oven...codes/ge-oven-error-code-f7-and-how-to-fi...
Jun 23, 2007 - The error code "F7" will be displayed along with a beeping sound if the ERC (Electronic ... We have a GE Spectra Oven - GAS - we keep getting F7 errorcodes and the oven will not heat. ... In my case it was the keypad.
Why is my GE Range model number JBP80SM2SS making ...
www.shopyourway.com > Manage My Life > Questions
Apr 6, 2010 - Get shopping advice from experts, friends and the community! I was boiling water on back burner of ceramic stove top GE range Model ... When anyappliance picks up an error code or starts beeping the problem that caused it ...
Jan 08, 2016 | GE Profile 30" Self-Cleaning Slide-In...
F2:E1 ERROR CODE
Hello Cjarboe,
I understand that your range is given you F2:E1 code this code states that the keypad cord is unpluged. If you find that it is plug in and the error code comes up again you will need to replace the keypad. Here are the dirrections to check/replace the keypad.
1. Unplug, shutoff power to the unit
2. Remove the knobs from the top of the control panel
3. Remove the endcaps
4. Unscrew the control panel
5. Locate the serial cable comming out of the keypad do the jiggle and make sure wire is tight on the keypad and control board.
6. Reassable in the revearse
7. Check to see if error code displays again if it does you will need to replace the keypad.
This range has been discontunuied by whirlpool and parts are hard to come by. Here is a link that I have found the keypad for $243.42 at the followign link http://www.appliancepartspros.com/partsearch/model.aspx?model_id=254959&diagram_id=28176301#d28176301
Thank you for choosing FIxYa.com
Justin
Mar 30, 2011 | KitchenAid KGRT607HBS Gas Kitchen Range
I have a kenmore gas range and on the display is says EO F2
The "F2 - E0" error code means "Shorted keypad".
Remove power from the range, open the control panel and unplug the membrane switch ribbon from the control board.
Reconnect power to the range and observe for an hour.
If the error code reappear - replace the control board.
If not - replace the membrane switch.
If I get the model # I can help you pind the right parts.
Good Luck and please rate 4 thumbs for the free answer
Apr 17, 2010 | Kenmore 30 in. 32384 / 32385 / 32389 Gas...
GE spectra JBP66 electric oven that displays the F2
f 2 code states that oven has exccded 590 deg w/door in unlocked position or 990 f in locked . either the themp prop is bad or the relay in the EOC ( clock ) is welded closed . I would replace the prob first ( less expensive ) then the clock if needed .. **** ..
Dec 23, 2009 | GE Spectra JBP78 Electric Kitchen Range
F2-02 Error on Imagistics ZB35 machine
Sharp AR-5620N getting f-2 error. What is the solution
Mar 03, 2009 | Sharp AR-M237 Copier
Display shows error code "F1"
F1 Failed Thermistor Control Replace Electronic Range Control (ERC)
Good Luck and Please Rate Fixya!
Jan 06, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
May 23, 2008 | Sharp AR-M237 Copier
Error code
All the information I could find on GE ranges indicate that an F-7 error indicates a problem with either the Electronic Range Control (ERC) keypad having a stuck key, or the ERC itself being defective. You can unplug the ribbon cable on the ERC and wait at least 32 seconds before plugging it back in to see if the problem clears. If the problem persists you will have to replace the ERC. Make sure you UNPLUG the range and/or turn off the main breaker to it BEFORE servicing. Remove the back panel of the range to access the ERC. If you cannot get the fault to clear and wish to replace the ERC, post back with comments as to your model number (usually located on the frame of oven door opening or lower drawer opening) and I will research to find a part number for you. Keep in mind, most ERCs do not come with the overlay (plastic piece with the number and keypad displays). I would advise you to replace both if you decide to repair the range. i hope this info helps you.
Nov 06, 2007 | Kitchen Ranges
GE Spectra JGBP35 Gas Kitchen Range Logo
293 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
