Question about Whirlpool LEB6300 Electric Dryer
Dryer sped too fast?
Knit shirts just ride with drum and do not "tumble". They come out slightly wet and wrinkled. Can a dryer speed be slowed up to cause the shirts to tumble?
  • raosao918 May 29, 2009
    Seems like it would work! Thanks
  • 10,865 Answers
Put a couple of clean dry bath towels in with your knit shirts.......problem solved
Posted on May 29, 2009
Why are my business shirts on a gentle cycle or any wash cycle so badly tangled togther?
Hi Stella,
I suspect the tangled shirts coming out of the washer is a result of the differences between the way a front loader vs a top loader clean clothes and can not be avoided. I don't think this is the source of the wrinkles though. I suspect the wrinkles are more a result of how long clothes remain in the dryer *after* the cycle has completed. If you remove the clothes *promptly* from the dryer and use a "dryer sheet" you will reduce / minimize the wrinkling you're seeing.
Mar 28, 2015 | Washing Machines
How can I get less wrinkles in my clothes after wash cycle is finished?
I use the dryer to get the wrinkles out. If i have a wrinkled shirt that is already dry and I need to wear it, I put it in the dryer for a few minutes with a wet wash rag.
Oct 10, 2014 | Kenmore Washing Machines
Too many rpms, how do i slow my dryer down? t731
Welcome to FixYa.
The first thing which comes to mind is this, have you brought this machine into north america from overseas ?
I ask because this is a problem which can manifest from the motor operating on 60hz cycle but designed for a 50hz cycle.
The drum will actually spins too fast hence the items don`t tumble but rather stay pushed to the perimeter of the drum...thus not drying.
If you open the door and run the dryer, the drum on an Asko T731 dryer should rotate at 52rpm. I use a piece of tape on the drum to keep count.
Let me know what you find and we`ll go from there.
Regards,
Macmarkus :)
Sep 16, 2010 | Asko T731 Electric Dryer
Rust colored mark or short line on tee shirts
most likely coming from your washer....when clothes are wet it harder to see marks....washer needs new seals.
Jul 20, 2010 | Maytag PYE2300AY Electric Dryer
Shirts getting stuck on "ledges" inside drum
Try these "dryer balls":
http://www.amazon.com/Dryer-Balls-Original/dp/B000BOBM8O
Apr 07, 2010 | Roper REX3614KW Electric Dryer
Kenmore Dryer won't turn on
Hi...
This are the tipe on how to Troubleshot dryer follow the steps below
IF the dryer is noisy
Level the dryer
Check the drum belt
Check the drum support rollers
Check the idler pulley
Check the glides
Check drum bearings
Check the blower
Check the baffles
If the dryer tumbles, but there is no heat
Check for proper air flow
Test the safety fuse
Test the thermostats
Test the centrifugal switch
Test the timer motor
Test the heating element
Good luck !!!!
Regards
PCmania
Jul 03, 2009 | Kenmore 63942 Dryer
Dryer very loud while tumbling. even empty
There are two rollers that the back of the drum ride on. At times, these rollers wear out and fall off and the drum rides on the back housing or the stem of the roller. You need to pull the front of the dryer off and carefully slide the drum forward (keep the drive belt in place) just enough to expose the rollers... replace if needed.
May 08, 2009 | Dryers
Whirlpool LEB6300 Electric Dryer Logo
103 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
