Question about Logitech Harmony 670 Advanced Universal Remote with LCD Screen
Battery cover on back is stuck on. no way to get open without breaking it
  • 864 Answers
Press on it with both thumbs in the depressed area and push down and toward the end.  There is a small latch behind the depressed area.  By pushing down as well as toward the end of the unit you should be able to get the latch to release and the cover will slide toward the end.
Posted on May 29, 2009
How do i remove the battery on samsung galaxy tab 2?
Replacing the battery is trivial once you manage to remove the Galaxy Tab's back cover. However, that is the catch: the back cover snaps on the case using roughly twenty rather fragile plastic fins and it is very easy to break them off in the process.
I do not recommend to attempt this without some experience and proper tools - forget about prying the case open with a screwdriver, you'll nick the plastic badly and you may break off the lot of the fins.
If you're going for it: you have been warned. You will need to order a battery replacement kit, you can find them, for example at Amazon, for about USD 50 plus shipping.
Watch this video: Samsung Galaxy Tab 2 7 0 Battery Replacement for the opening procedure and the kind of tool you need, note how careful the presenter acts and how it takes even this expert several minutes to remove the cover without breaking it. I also assume the case used in the video was opened and closed before and by slight wear, it comes off more easily compared to a virgin immaculate case.
The actual battery replacement is done by removing six screws and a connector and after changing the battery, putting the parts together in reverse order.
Jun 14, 2014 | Samsung Galaxy Tab 2 7.0
How do you get the battery out of the Dodge Journey remote without breaking the case?
Step 1:
Using a small flat bladed tool, carefully remove the battery cover on the back of the fob.
Step 2:
Remove the battery one at a time by slightly lifting up and sliding out from the fob.
Step 3:
Replace the battery with the same type of battery cell.
Step 4:
Install the battery with the positive side up.
Step 5:
Install the battery cover and snap into place.
Step 6:
Test for fob operation.
Jan 25, 2013 | 2009 Dodge Journey SXT
I need to open my dsi battery withawt a screwdriver
DSi screws are very small. There's not really much you can do, but you CAN use a sharp knife or scissors to get the screws to budge. This doesn't work all the time, though. I only managed to get one screw out. The other one is still stuck. And you probably shouldn't do this anyway, even with a screwdriver, because the battery cover is very thin and could break easily. Also, you might damage the screw, which will prevent you from being able to screw the cover back on. The battery is also definitely something you wouldn't want to damage. Try this, but be careful!
Hope I helped ^_^
Oct 20, 2012 | Komodo Rechargeable 3.7v Battery Pack w/...
When attempting to print, the printer window gives me the message Back Cover is Open Checked the back, opened it, removed the paper that was stuck on the roller and tried again. Same message comes up. What...
hello, when you are looking at the back end of printer, open up cover, the cover will open and stop, look further in and you will a black guide, or black plastic, open that up, if it does not open on its own, there is a piece of plastic that might look like a stick, sometimes this will get stuck, use a flashlight, and you will see haw this thing works, if it does not move freely, it will trigger rear door open, be carefull with this piece of plastic, it does break. again it will trigger an open rear door error.
Sep 27, 2010 | Brother HL-2070N Laser Printer
Cannot open the battery compartment on my suunto x6 without breaking it....any ideas?
  • Turn the Suunto over to view the backside. Insert the quarter in the coin slot located on the battery compartment cover. Turn the coin counterclockwise to the "Open" position marked on the back of the case.
  • Remove the battery compartment cover. Remove the old battery from the battery compartment. Make sure the o-ring and all surfaces are clean, dry and not damaged. Do not stretch the o-ring!
  • Place the new battery into the battery compartment (negative side down, positive side up). Make sure the o-ring is in its place, as to keep the Suunto waterproof. Place the battery compartment cover back onto the backside of the watch.
  • Insert the quarter back into the coin slot and turn the coin clockwise to the "Close" position marked on the back of the case.
  • If this doesnt work take to a jeweler who has tools.
    Jewel
    Aug 31, 2010 | Suunto X6 (black) Wrist Watch
    Canon s5 is battery cover will not open
    Unfortunately there is only two solutions for your problem:
    1. Gently but firm, press the battery cover lid down and at the same timemove the button to open it, and at the same time, slide to the side the battery cover.
    Try it as much as times are needed.
    2. If still is stuck, then you will need to disassembly it, or pay at a repair service for it.
    If is stuck, and force to open it with a tool (pry tool or similar), you have the risk of break the slide plastic channels in the camera body, or break the battery cover, or break a switch located in the mainboard that senses when the camera door is closed, or everything at the same time, making worst the problem and causing you to spend more on repairing it.
    Of course that if it has warranty, I do recommend you to make it valid prior to try in send it to repair.
    If is out of warranty, Canon charges $120.00 for any repair (or so), so you will need to find a cheaper repair shop for it.
    Best regards,
    Jul 19, 2009 | Canon PowerShot S5 IS Digital Camera
    Can't get the battery cover off t439
    have you checked the manual? http://support.t-mobile.com/knowbase/root/public/tm30195.pdf
    Jun 24, 2008 | Samsung Cell Phones
    I have a 3 year old Sony DCR-DVD202E Camcorder which has worked perfectly up until yesterday, when the lens cover refused to open. Other thsn this the camera powers up normally and the LCD screen shows a...
    Sounds like the gears are stuck, the motor is bad or that the potmeter is bad. The only way to fix this is that the camera has to be opened. If you are sending it to repair make sure that it is not to costly to fix. Most times spending a hundred extra dollars would buy you a new camera then repairing the old one.
    Jun 09, 2008 | Cameras
    Logitech Harmony 670 Advanced Universal Remote with LCD Screen Logo
    646 people viewed this question
    Top Logitech Televison & Video Experts
    Jerry Umali
    ka4iup
    ka4iup
    Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
