Question about Zenith ZN110 Remote Control
Plays records too fast, needle cartridge is loose
I just purchased a vintage Zenith phongraph record player today at a thrift store and every record i've put on plays way too fast even tho it's on 33 1/3 playing time for the 33 1/3 records. The needle seems very dirty and the cartridge that holds it is loose, could this be the problem? so i just need to get a new needle? or can i just tighten the cartridge any way? by the way, the speakers are fine cuz the radio sounds great. thanks
  • kashmirkev May 29, 2009
    So I looked all around the cartridge part and i could not find any screws or anything to adjust it. There is a plastic part that covers the cartridge and could not not see any screws on it.
    What you said about the motor issue and capsan drive mean that it's an interal problem?
  • 10,865 Answers
Many of these old phonographs play a little too fast. one possible fix is to rig up a dimmer switch into an "extension" cord that you plug this vintage phonograph into. The lower voltage will slow it down and you will be able to adjust the speed.
Posted on May 29, 2009
    Problem Solver:
  • 5 Answers
The speed issue w/your Zenith turntable can be traced to the motor spindle. With time and use, gunk forms on the motor spindle making it larger in diameter thus resulting in a faster than normal speed. Easy fix. Remove turntable platter and clean idler wheel and motor spindle with alcohol. It may be necessary to scrape motor spindle then clean. Using the dimmer theory as described by justaskjoe unfortunately is not the cure. In addition, when you reduce the voltage going to the unit it will also decrease the amount of voltage to run the amplifier. That's a dumb solution. Don't even think about that!! If that is the Zenith Micro Touch 2/G Tone Arm, it drops out of the tone arm by removing the top knob [if it's still there] and using a small screwdriver, gently move the cartridge pivots inward; the wires usually plug into the cartridge; sliding it backward releases the wire and plug assembly. If you don't have to remove the cartridge for any reason other than replacement, leave it alone. Your speed problem is not there and the cartridge on this unit is DESIGNED to "float" in the tone arm assembly. Good Luck,
JIMBO
Posted on Dec 20, 2009
  • 864 Answers
There should be some small screws that hold the cartridge to the arm.  You can tighten them.  Clean the needle with a fine brush. Brush in the direction from the arm to the end.  If you do it the other way you could bend the needle back and wreck it.  The speed problem is likely due to a motor issue or drive capstan problem.  (if it is rubber it might be old and dried out. )  Or if the unit can be used for 45's the selector switch may not be working correctly.
  • John Morganti May 29, 2009
    Higher end turntables have removable cartridges with flanges on their upper sides (the side that touches the arm at the top) and the screws go into the arm.  They are very small.  You night need a jewelers screwdriver to tighten them.  Lower end phonographs have molded cartridges that snap into the arm.  Yours sounds like it might be one of those.  If you can remove the plastic part (under the arm) that covers the cartridge you may be able to see the screws up inside the arm.  If you cannot remove it you may be able to tighten the fit of the cartridge with some shims but some cartridges are meant to be loose and "float".  The looseness in not causing the speed problem so you can leave it loose if it doesn't tilt to one side and sounds OK.
    The motor shaft may have a rubber wheel that rubs against the platter (inside).  If the wheel has shrunk with age or wear, it would cause the platter to run faster.  Try the dimmer switch trick first since getting replacement parts may be difficult.  However plugging the unit into a dimmer will also reduce the voltage to the electronic parts as well as the motor and may cause other problems.
Where can I find a NeedLE FOR A 4140 ZENITH TURNTABLE
HAVE YOU TRIED THIS PLACE:
http://www.needlefinder.net/
Dec 01, 2014 | Vintage Audio Players & Recorders
I need phongraph needle
If you look at the cartridge it should have a make and model number on it. If you put that into Google the stylus should show up.
May 22, 2014 | ANDERS NICHOLSON USB Turntable With CD...
Zenith XBR716 DVD Recorder / VCR Combo parental bypass
I don't know if this will work but try entering four 0 (zeros) first. If it doesn't work enter as many 0 (zeros) that you can and see if that works. Hope this helps :)
Apr 20, 2014 | Zenith XBR716 DVD Recorder / VCR Combo
Crosley CR40 playing 33 1/2 too fast? What can I do to slow it just a little bit?
I would get a vintage turntable and not a new one inexpensive one. The new record players do not last.
Apr 20, 2014 | Crosley Stack-O-Matic CR40 Turntable
I have a JVC AL-A158 turntable, just got it from a thrift store for $13. Cosmetically, it's brand new. No scratches, no scuffs, no nothing it's even still got the plastic on the 45 record adjustment, and I...
2 things, make sure the back arm weight is adjusted correctly,, allowing enough pressure to be placed on the record, if that doesn't help, you have a chip in the needle thats not visible to the naked eye,
Apr 30, 2011 | Audio Players & Recorders
Vintage Zenith Turntable starts record in middle.
Check the speed it is set at as the speed setting tells the turntable what diameter of record it will be playing.
Aug 30, 2009 | Audio Players & Recorders
Need new needle casing and needle for record player part of this
I would suggest that you look at the MUSONIC web-site. They specialise in cartridges and styli and will answer any questions by e-mail.
Jan 10, 2009 | Audio Players & Recorders
Zenith XBR411 DVD Recorder/VCR Combo Problem
I have the XBR616 zenith combo.
If your dead set on initializing your dvds, I can try to
do one in my dvd player to see if it works, then send it back to you. I can't guarantee anything, my player is a bit fussy, but I don't mind helping you.
If so, let me know
Oct 28, 2008 | Zenith XBR411 DVD Recorder/VCR
Fisher price 1978 record player
The Fisher Price record player has a device that prevented kids from pressing the needle down and sctratching the record. If you look at the cartridge where the needle is inserted, you will see that it floats up and down. The problem is that this keeps the needle from having enough pressure to play the record. Pennies just make the cartridge recede further into the arm. If you wedge something above the cartridge, the needle won't float and the it will play your records. I've had four of these and none of them worked until I figured this out.
Aug 02, 2008 | Audio Players & Recorders
Zenith ZN110 Remote Control Logo
548 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
