Question about Biostar P4M800-M7A Motherboard
Is my motherboard defective?
Hi, evrytime i turn on the power of the pc, my pc wont start but harddisk led stays lighted all the time, cpu fan works, is there something wrng with my motherboard?
  • rianne809 Nov 18, 2007
    oops, i think you posted on my own post, anyways, i suggest to download the drivers for your video and sound card through the net, just use google to search your hardware specs.
I have accidently deleted video and sound drivers , and i dont have a cd to install that ,i have a biostar motherboard model p4m800-m7a i have tried to search the appropriate drivers but coudnt find them could please help me out
Posted on Nov 17, 2007
Go to http://www.biostar.com.tw/app/en-us/mb/driver.php?S_ID=92
Posted on Sep 03, 2008
  • 3 Answers
Hi. I know that this is an old question, but let me share my experience with this motherboard in case that it helps someone with the same problem. I had exactly the same problem, the fans worked and the harddrive light was on, but the motherboard did not start. The motherboard did not even beep; even when I took the memory modules out it did not beep at startup. The fans just started and then it sat there doing nothing! I wasted hours on this and was convinced that the motherboard was faulty... but then I thought of trying the following and it worked:
On the motherboard JCMOS1 has 3 pins; pins 1 and 2 are closed in normal operation. Closing pins 2 and three instead puts the motherboard in clear CMOS memory mode. So that is what I did, I moved the jumper from pins 1 and 2 to pins 3 and 4. I pressed power a few times, but I don't think that was required. After 30 seconds or so I put the jumper back on pins 1 and 2. And then when I pressed power the motherboard FINALLY beeped and continued starting up. On first startup it gave a message to the effect of "BIOS checksum error"', so I went into the BIOS, loaded the default settings, saved and went out. (Oh, and removed the floppy drive in the BIOS too, as I did not have one). After performing these actions, the motherboard started up normally and has been working fine for the last few days... here is hoping that it continues that way!! :)
So that is how I solved this problem... hope it helps someone. :)
Posted on Mar 02, 2010
Your motherboard id ok , but your videoboard is not :| try changing it
Posted on Sep 28, 2008
I have a toshiba m3 laptop, it was going then it froze, so i turned it off, now it wont start up, ac power and the on LEDs light up, if i remove and replace the battery the battery light goes momentarily...
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
4. The motherboard could be defective & needs to be replaced
Sep 10, 2010 | Toshiba Tecra M3 Notebook
I have a emachine el1200 desktop and the power led light is staying on but I have no power to the fans or anything. The computer will not come on at all and the blue light stays on. I tried unplugging it...
hi gregrobinhol,
check if the psu fan is working if not then the psu is the problem if the cpu' fan is not working unseat all the memory, clean the metal contacts underside of the memory with an alcohol and a cotton let it dry for 5-10 mins then put it right back. if this does not work you have a defective motherboard.
hope this helps
thx
banaple
Sep 02, 2010 | E-Machines eMachines Desktop PC
Have a Dell Latitude D600 will not boot. All LED
LEDs indicate a memory error
Reseat RAM and try modules one at a time. If ony 1 module, replace it
Dec 16, 2009 | Dell Latitude D600 Notebook
Computer wont turn on
First open cpu cabinet then pull cmos cell from motherbord for 10 minutes.
Refix RAM memory.
Reattch ATX power connector to motherbord.
Reattch power cable and SATA or ide cable to harddisk.
Clean dust from all parts of motherbord.
Open processor fan and processor.
Then reattch both.
Make sure motherbord is not ground with cabinet.
When you power up the computer press F1 or F2 or "del" key then enter in bios .
Make sure in bios your harddisk is detected.
If not then change SATA or IDE cable of harddisk.
Then check .Go to boot menu nof bios then set first boot device as your harddisk.Then save settings and exit.
Let me know if you need further assistance.Thanks.
Nov 21, 2009 | HP Compaq Presario S5200NX (DM173A#ABA) PC...
Amd phenom faulty
Replace cpu fan , failed cpu fan might have caused CPU stoped working. If you are sure about the CPU fails then replace the CPU. If the problem seems continues after that too, then PC might have failed to boot due to other reasons. What shows on the screen once you power on the computer? There could be , motherboard , or harddisk faults too. Try unplugging other parts and see if the computer boots from CD or USD flash or floppy drive!! Once you know that motherboard works then replace the CPU. There could be BIOS setup problem. Did you check the BIOS for harddisk is set properly.
Sep 17, 2009 | AMD 2.1GHz Phenom X3 Tri-Core 8450 AM2+...
Hipro HP-d3057f3r computer power supply broken?
I have the same problem. I found this:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=bph06788&product=12455#bph06788_section_2
  • Replace the side panel, plug in the power cord, and examine the light on the back of the power supply:
  • If the LED is on solid and is not flashing, the power supply is probably good and the problem is most likely caused by a defective component (processor, memory, PCI card) or a defective motherboard. Have the computer serviced, or remove the components and replace them, one at a time, to find and replace the defective component.
  • Aug 16, 2009 | Hi-Pro Computers & Internet
    CPU not boot up
    First of all what exactly do you mean by "changed the CPU"? If its the processor? Is only the display not working, since you have said that the fan runs, it means the PC is starting. Check the Keyboard & mouse PS2 jacks. If there is any bent pins in the jacks? If so gently straighten with a pair of tweezers. Also try using a working Keyboard & Mouse from any other PC. If that still does not work, do you see the led lighting up on the MB? Does the MB make beeping sounds? How many? ALso mention the processor you have so that we may be able to help...............sodeep
    May 08, 2009 | Foxconn P4M800P7MA-RS2 Motherboard
    Compaq Presario 4400us
    Either the new power supply you purchased is not functioning correctly. But, assuming it is now that you are getting some form of power to your PC, it is very likely the motherboard. Whatever fried your old power supply (or it could have just been the power supply itself) most likely fried your motherboard in the process. Probably not the CPU since the MB can't even post.
    Jun 21, 2007 | Compaq (388746-001)...
    P4MBMS Motherboard Problem
    look for the reset jumper on the board and then reset it then try again
    Jun 03, 2007 | Mach Speed P4MBMS Motherboard
    Biostar P4M800-M7A Motherboard Logo
    208 people viewed this question
    Top Biostar Computers & Internet Experts
    Jayburt
    David
    David
    Jerry Umali
    Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
