Question about Hitachi 60SBX78B 60" Rear Projection Television
Hatachi 60sbx78b powers up then shuts off
My hatachi 60sbx78b powers up only momentrarily when plugged in, all the green leds turn on except for one, this one then powers up and then shuts downs followed by the other all fading off at the same time. If I unplug it wait 10 seconds then plug it in I get the same failure mode all over agaun. I am trying to determine which component is defective? Is it E991?
    Problem Solver:
  • 3 Answers
I think it might be E994 and C707
Posted on Aug 16, 2009
My Hitachi 60sbx78b popped and then shut off. It will not power back on, I plug it up and it sounds like it is getting power, the green led lights come on for a few seconds and then they go off and the...
On this model there is a common failure with some capacitors and fuses. Its a simple fix if you know which parts to use/avoid and how to do the repair. You can get complete instrucitons and parts for your model from www.TvRepairKits.com . Their kits include step by step color instruction guide as well as the correct parts to fix this issue.
Oct 17, 2010 | Hitachi 60SBX78B 60" Rear Projection...
Hatachi 60sbx78b 60 in. rear projection. Won't power up
set is in shutdown--some of these sets have problems with Glycol leaking out of one of the picture tubes---look and carefully check the first few inches from the front of the circuit boards--it will be a clear liquid or look like model airplane glue--it shorts things out--if you see the liquid do not touch it---it is like anti-freeze but much more concentrated and toxic---each picture tube has a sealed area full of the coolant--if it is Glycol---forget about it and get another set----this set is also prone to the High Voltage Transformer going bad---unsolder it and the Horz output transistor and see what happens.
good luck, Steve
Aug 09, 2009 | Hitachi 60SBX78B 60" Rear Projection...
Hitachi 60SBX78B No sound or Video
replace pico fuse E994 and capacitor C707. You have to disconect alot of wires and remove the screws holding the boards. you DON'T have to remove the large high voltage wires. You have to stand the board on it"s edge to unsolder the components from the back side of board. Good luck it worked fine for me. fcs0998@aol.com gene
Apr 27, 2009 | Hitachi 60SBX78B 60" Rear Projection...
Tv won't turn on.
If you have Hitachi model number 50UX58B, 60UX58B, 50UX58K, 60UX58K, 50SBX78B or 60SBX78B and you have the following symptoms you may want to grab a repair kit from www.TvRepairKits.com. They have put together a kit that includes the parts and instructions to fix these models. This is a fairly common problem with the above model numbers. It is typically caused by a blown capacitor and pico fuse. Again, you can get a kit from the above address.
Here are the symptoms...
Primary Symptom: No Audio or Video. Power light will come on briefly then shut off.
Other Possible Symptoms : The green LEDs on the circuit board light up for a few seconds then turn off.
Hope this helps,
Oct 07, 2008 | Hitachi 60SBX78B 60" Rear Projection...
Hitachi Projection Color TV 60SBX78B
Hope this helps,
Oct 03, 2008 | Hitachi 60SBX78B 60" Rear Projection...
Hatachi 60 inch big screen test port e994 open high voltage shutedown
You can get the parts from www.TvRepairKits.com. They have put together a kit that includes the parts and instructions to fix the following models (50UX58B, 60UX58B, 50UX58K, 60UX58K, 50SBX78B or 60SBX78B). The kit includes the E994 pico fuse and the C707 capacitor.
Jun 24, 2008 | Hitachi 60SBX78B 60" Rear Projection...
Hitachi 60sbx78b Won't Turn ON...need advise
If cap value is 1000 pf ( 102k ) 2KV, beef it up ! I use Sony part # 1-161-754-00 ....102k 3KV.......Note: sometimes shorted cap
is hiding under dried gob of placement glue............
Make sure pico fuse is correct amperage.......T.
Jan 28, 2008 | Hitachi 60SBX78B 60" Rear Projection...
Hitachi model #60SBX78B
The green led or lights on the board indicate some of the power supplies are working. The key is do you see any come on and then go out. this would indicate which part of the power supply is failing. also there are fuses in the set that do not look like your standard glass fuse. WARNING television generate lethal voltages that will hurt you. extreme care should be used.
Jan 18, 2008 | Hitachi 50SBX78B 50" Rear Projection...
Hitachi 60"(60sbx78b) Will not power on, fuse still good.
Matt, Hitachi`s have a series of green LED`s and one red LED on the main board, un-plug the tv for 30 seconds and then with the back cover removed plug the set back in and watch the led`s while someone else turns on the set, usually the led`s will temporarily light then one or more will immediately go out and then the rest will slowly go out and the red one will then start blinking, each led is a power supply indicator, 130 volt, 12 volt, 5 volt etcetera, find out which one(s) going out first and get back to me, BMW Rider
Jan 04, 2008 | Hitachi 60SBX78B 60" Rear Projection...
Hitachi 50ux58b
Hope this helps,
Jan 02, 2007 | Hitachi 50UX58B 50" Rear Projection...
Televison & Video Logo
169 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
