Question about Garden
Rewind spring installation
Where can I get a diagram showing how to install a rewind spring on my lawnmower?
  • 4 Answers
You might be better off buying a new Pull start assembly. there not that expensive, unless your mower is so old they don't make it any more. under $20 dollars I think. unless its a Honda or something else ***. than maybe a little more expensive.             Jay..............
Posted on May 29, 2009
Instaling rewind spring
I don't know what model you have but when you rewind the spring there is usually a little hole that you can put something as small as a straightened out paper clip, possibly one of those small drill bits you never use, in sometimes 2 holes that you can see from the back side of the housing so when you attach you simply remove them and you're good to go.
Hope I helped
Jan 09, 2018 | Garden
The rope broke when I tried to start the chainsaw. How do I replace it?
Your rewind spring is now sprung. Remove recoil assy ( the part your rope slides into). Remove all old rope remnants and rewind the spring. Install new rope, tie it off and slowly release spring rewinding the rope.
Mar 14, 2014 | Stihl 017 018 Ms170 Ms180 Chainsaw Starter...
REPLACING STARTER SPRING/HUSQVARNA MODEL141
To rewind the spring is a bit of an art, hook the end of the spring into the stub on the starter, now start to wind each coil into the cover, making sure you keep your thumb on the coils you have wound in so as they do not spring out, otherwise order a new spring which will come pre wound in a keeper to make instalation very easy.
Apr 21, 2012 | Husqvarna Chain Saw 20" Bar
The rewind spring for the pull start came out. What is the trick to rewind it???
put the housing end in first, take the spool and hold the spool end against it and wind the spool in the air until the spring is wound tight, then install the spool back into the housing. you have to keep your fingers on each end of the spring and hold the spool relatively close to the housing, obviously, but it's not a hard trick to master.
Sep 06, 2010 | Stihl Garden
Starter cord won't rewind
The starter cord is spring loaded. When the spring breaks your cord won't rewind. Usually the whole starter cord assembly is easily replaced and readily available at your local gardening goods retailer. They might even install it for you for a nominal fee. I hope you find this solution helpful. Please rate it and thanks for using Fixya.
Nov 05, 2009 | Sewing Machines
Installing recoil spring for Poulin P3314
Recoil Spring Rewind
I invert and secure the housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension for it to retract properly.
If you're lucky you can pull the cord out enough for a pretension then slightly raise and add the withdrawn cord to the spool. HTH
Lou
Oct 17, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Rewind pully spring
Lou
Oct 06, 2009 | Poulan Pro Chain Saw 46cc 20"
Strimmer Starter strip
You will need to take the housing off to expose the rewind mechanism. The most likely cause will be a broken rewind spring. Go on the WEB and search for your model and a part list. Locate the spring and order it. Once you install the spring, you will need to pre-tension the spring by by pulling the cord part way out and ciol it on the spool. Good luck
Jan 01, 2009 | Garden
Starter Rope Rewind Problem
I need to replace rope on my lawnmower starter, are there any tips on this?
Dec 11, 2008 | Toro Lawn Mower With Toro Power Tools
Garden Logo
208 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
