Question about Nokia 7100 Cellular Phone
How to insert a sim card in nokia7100 .tere is no slot .what can i do? I pushed the sim in, but it was really hard. the cut off corner was in the right place. Still does not say that there is a sim there when I turn it on.
  • tradepro285 May 29, 2009
    Went and got a new sim. The old one was too thick. Thanks for your help. The instructions are not to clear about the amount of force required to put the sim in. I think a photo would be better.
  • tradepro285 May 30, 2009
    Yes Thanks
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 80 Answers
Extract from nokia 7100 user guide:
Always switch the device off and disconnect the charger
before removing the battery.
The SIM card and its contacts can be easily damaged by
scratches or bending, so be careful when handling,
inserting, or removing the card.
1. Slide the release button (1), and remove the back cover
(2).
2. Remove the battery (3), and insert the SIM card (4).
3. Insert the battery (5), and replace the back cover (6).
Posted on May 29, 2009
  • Tualiapz
    Tualiapz May 29, 2009
    So did it work for you? are you able to get your phone connected?
    I hope it all works out ok.
    Please rate my solution thanks!
How to insert sim
sim card has cut edge on one corner.
this side goes in forward.
cut edge is always top left corner.
SIM logo is top of sim card,
Mar 27, 2017 | Cell Phones
How do I install SIM card?
remove the battery as most sim cards go underneath it
there is a corner cut off the card so it will only go in one way
line it up and push it in the slot
Oct 21, 2015 | Cell Phones
Moto g was no sim insert slot what I do?
Hi Seeni Vasan,
You need only micro sim for this. One(minimum) or else two(maximum) micro sims for this.
Remove the back cover of your Moto G.
  • Now keep the mobile with the screen facing down on a table.
There are two micro sim slots for Moto G (2014)
1st Sim slot is at the top right corner and the 2nd sim slot is at the bottom left corner.
  • Insert the first micro sim, with its ports facing the table into slot one. (The bevelled corner should go inside).
For more details, please follow the link.
If you find my review helpful then please rate me high, or you can contact me back.
SIM for your Moto Google Play edition
Tanveer Ahmed
Jan 05, 2015 | Motorola Mobility GOOGLE 8GB MOTO G XT1032...
How do i install sim on a kyocera c653 phone
Did you mean the Hydro-life C6530N phone? There is no C653 listed on the Kyocera USA web site. The following is copied from page 9 of the manual for the C6530N:
Insert the SIM Card
1. Insert your thumbnail or fingernail into
the slit and lift the battery cover.
2. Grasp the white pull-tab extending from
the battery pack and pull the battery out
of its compartment.
3. Use your fingernail to carefully pull out
the SIM card tray.
4. Place the SIM card into the tray, with
the gold contacts facing down and the
cut off corner on the top left. Insert the
SIM tray back into the SIM card slot and
push until it clicks into place.
Note: Make sure not to insert the SIM
tray in the opposite direction.
5. Insert the battery, contacts end first, and
gently press into place.
If the tiny type is too hard to read, you can view the manual with a PDF reader at http://www.kyoceramobile.com/hydro-life/Hydro_LIFE_User_Guide_T-Mobile_en.pdf
There is a different manual for the MetroPCS version of the phone, but the SIM card installation is the same.
Jan 03, 2015 | Kyocera Cell Phones
How do I put my sim card in my phone
hey,
all you have to do is remove the back, the little tab at the bottom. Pull out the batter and insert the SIM card in the middle slot. Insert the SIM card so the cut corner is facing top left. Follow the picture. Then re-insert the battery and backplate.
Mar 31, 2013 | T-Mobile My Touch Cell Phone
How to open sidekick and get my simcard out
The SIM card door is covered by a rubber casing that peels back. Pull back the rubber flap to access the SIM card door. The flap that needs to be pulled back is the top left corner of the Sidekick above the Menu key.
Insert the SIM card into the slot with the gold contacts facing up and the cut corner facing out. When you release the SIM card, make sure it is locked into position behind the catch so it does not spring out. Replace the bumper, and then turn on the device.
It appears that inserting the SIM into a Sidekick is a rather tricky process. If the above does not completely solve your problem, here is a link to more details on inserting the SIM card. http://support.t-mobile.com/knowbase/root/public/tm50134.htm?
Nov 26, 2009 | T-Mobile Sidekick II
My lg phone
There are several reasons for this message. Has your sim been activated by your servide provider? If not, you must call them.
Has your sim expired or been damaged in some way? If so, it must be replaced.
Have you inserted the sim correctly? The gold contacts of the card must be facing down, and the cut corner must be facing out of the card slot, pointing to the right hand side.
Do you have the right sim for your phone's cellular service provider? If your phone is locked to one provider you can't use a sim card from another provider, unless the phone is unlocked.
Hope one of these helps!
Aug 04, 2009 | LG Vu CU920 Cellular Phone
Sidekick 2
Sorry, the sidekick II doesn't have a battery that can be pulled out. You need to pull back the bumper on one side to access the sim card slot.
    1. Follow these instructions to remove your operator-supplied SIM card from your device:
    2. Turn off your device by pressing the power on/off key.
    • Expose the SIM card slot by peeling back the bumper from the top-left edge of the device: t02005-2.jpg
    • Press down on the silver "catch" and the SIM card will spring out of its slot. Remove the SIM card carefully. (Always handle your SIM card carefully since the card and gold contacts can be easily damaged by scratches or bends. Be sure to keep SIM cards out of reach of small children.)
    1. Now insert the SIM card containing the contacts you want to import:
    2. Insert the SIM card into its slot with the gold contacts facing up and the cut corner facing out. t02005-1.jpg
    • When you release the SIM card make sure it is locked into position behind the catch so it doesn't spring out.
    • Replace the bumper and turn on your device.
    GrinningFool
  • www.repairmysidekick.org
  • May 09, 2008 | T-Mobile Sidekick II
    Changing the sm card in my side kick 1 How?
    is it not on the shoulder the same as with the side kick2? check there there should be a spot where u can press down on the sim card and it will pop out
    Jan 26, 2008 | T-Mobile Sidekick
    Nokia 7100 Cellular Phone Logo
    245 people viewed this question
    Top Nokia Cell Phones Experts
    Computer Repairing
    Computer Repairing
    IT Solution
    IT Solution
