Question about Maytag Dryers
Drum is noisy when turning - squeals or creaks or groans
  • 52 Answers
If you can turn the dryer on its side to access the bottom, you should re-grease the wheels that the drum rides on.
Posted on May 29, 2009
Yellow Cartridge Motor Squealing
Toner Drum might be bad. Some times the cleaning blade stack against the drum and become noisy.
Jun 30, 2014 | HP CP3525N Color LaserJet Printer
Creaking noise from front left when turning
check the wheel bearings and adjustment. check cv joints.
Mar 26, 2014 | 2006 Ford Mustang
Whirlpool dryer model LER562KQ1 continues to make groaning/lo-pitched whining noise as drum turns even after installing preventive maintenance kit(rear seal not included).
follow this steps and fix it. God bless you
Rollers
Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. You will need to disassembly dryer to check these. Some dryers use rollers in both the front and rear.
Belt
The Belt should be replaced if you hear any noise coming from it or if there is any cracking, glazing, or grooves worn out. Replace it along with the idler pulley.
Idler pulley
Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides
Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace it if necessary. Put hand inside drum near front and push up there should be no play.
Rear drum bearing
Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace it when they're worn. Put hand inside drum near rear and push up there should be no play.
Blower wheel
Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermosta ts, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it Many times the blower wheel is making the noise and it is commonly mistaken for the motor.
Motor
The motor may be making noise. The easy way to check is to remove the belt and turn the dryer on if it is noisy replace it
Oct 01, 2013 | Whirlpool Dryers
LG dle3777w emitting a high-pitched squeal
Hello there and thank you for choosing fixya
If your dryer is making a squealing sound or a high pitch noise please look at the following
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them. Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn. Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
May 17, 2011 | LG DLE3777 Electric Dryer
I have a maytag performa dryer model #pdet920ayw and when i turn it on it squeels.
Below are some links, courtesy of www.repairclinic.com, that will assist you in diagnosing/repair of your dryer. You may have to enter your model number in the search box to access some of the information.
Below is a parts breakdown/disassembly procedure for your dryer.
http://www.repairclinic.com/Dryer-Electric-Maytag-Style-Appliance-Diagram
The most common cause of a squeal is the drum roller, of which there are 2. It is usually a good idea to replace both rollers, roller shafts and drum belt at the same time, as they have a tendency to wear at the same rate. You must also use the proper lubricant on the roller shafts, (Syl-Glide), or you will have a recurrence of the squeal.
1. Drum Roller Image
http://www.repairclinic.com/SSPartDetail.aspx?s=t-pdet920ayw-%3d%3di966673&PartID=966673
If your dryer is noisy, check these:
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
You can also obtain more appliance information at my website, www.homemanagement.services.officelive.com
Aug 27, 2009 | Maytag Dryers
Dryer squeal @ start up; access
It sounds as if you have a dry rear drum roller. Check the above link first for parts and teardown.
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Sqealing
If your dryer is noisy, check these: Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
May 12, 2009 | Dryers
When our dryer is turned on it has a very high pitched noise as if some metal is rubbing on the drum. It is model number DBXR453GVOWW.
It's noisy If your dryer is noisy, check these:
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Mar 07, 2009 | GE Dryers
Groaning frig
BFULLAWAY had the answer, I believe. My ice maker does the same thing, groaning and creaking for a few seconds, stopping briefly, then starts creaking again. This is due to ice stuck inside and it will make no ice as a result. Usually I see a piece of ice protruding and knock it out. Happened recently, but I saw no ice. Took a cup of hot tap water (not boiling) and poured it into the compartments where cubes form. (Made sure ice tray was in place to catch water.) I banged on the side and a misshapened cube fell out. Creaking/groaning stopped and unit began to function normally.
Apr 28, 2007 | Jenn-Air JFC2089HE French Door...
Dryers Logo
94 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
