Question about Maytag Dryers
Drum squeals or grinds
Squealing dry drum
  • 52 Answers
Access the bottom of the dryer by sitting it on its side, and re-grease the wheels that the dryer drum rides on.
Posted on May 29, 2009
My dryer won't spin and is squeeling
It sounds like either the belt is loose or the drum is frozen. Try the following links to see if they help.
Appliance411 Home Service Appliance Repair Manual for Whirlpool Kenmore...
This will help if you have never repaired a dryer.
User Manual Downloads
Feb 05, 2016 | Kenmore HE2 6.7 cu. ft. Gas Super Capacity...
My dryer is squealing and have to run it twice to get my clothes dry
the squealing/squeaking noise is more then likely your drum rollers:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
the drying twice is a venting issue:
http://www.partselect.com/dryer+wont-dry-clothes+repair.htm
Feb 16, 2011 | Whirlpool LEW0050P Electric Dryer
MAKING SQUEALING NOISE
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
fgsj
Oct 19, 2009 | Whirlpool GGW9250PL Gas Dryer
Squealing noise
it sounds like your drum guides that go around your drum they may be worn now. or your bearing in the back of your drum
Jun 11, 2009 | Amana DLE330RAW Electric Dryer
When activated the drum makes a low pitched squealing sound. drum seems to wobble
please replace felt around drum thank you for useing fixya RATE ME
May 16, 2009 | Dryers
Loud squealing noise from Drum belt looks fine other solutions
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the drum.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
If dryer is not cooling, check that the noise is not coming from the ventilation fan.
Rollers and belt tensioner can also make noise.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
May 06, 2009 | GE Dryers
Load squeal
if you can take your dryer apart, you'll have to take the drum out and lubricate the bearing that is located in the center under the drum while there check wellness of your heat element if located there. Anyway use high temp grease on this bearing looks more like a ball
Feb 21, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Frigidaire LEQ332DSO Squealing Noise
sounds like rear bearing is dry you will need to remove drum to get to it pop clips in top and raise 2 phillips scews 1 in each side remove front remove belt from drum lift drum up in rear and remove ck to make sure plastic bearing is not worn down to metal bracket if it is it will need to be replaced
Jul 07, 2008 | Frigidaire GLER341A Electric Dryer
Squealing!!
the noise is coming from the drum axle bushing that allows the drum to spin on it's axle. Gain access to the rear of machine and apply some high temperature grease that is found in automotive parts stores to the bushing. run it while observing spinning drum at rear for any possible other problem where squeal can be found such as drum slides.
Dec 26, 2007 | Frigidaire GLEQ2152ES Electric Dryer
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
