Question about Kenmore 64802 Top Freezer Refrigerator
2001 top freezer won't defrost
Refridgeratyor wont defrost
    President:
  • 1,136 Answers
Hi, You will need to check three different parts of the defrost cycle. The most common problem is the bi-metal switch. UNPLUG the refrigerator and remove the rear inside freezer panel and locate the bi-metal switch attached to the evaporator coil in the upper corner. You will need a voltage/ohms meter for this test. Check the switch to see if it has continuity. Note: This switch has to be cold in order to test it! If it tests open circuit, you will need to change the bi-metal switch. If the bi-metal switch tests ok, then test the defrost heater the same as you tested the bi-metal switch.
IIf both of these parts test ok, you will need to change the defrost timer.
Please get em a model # and I can assist you on locating the timer.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on May 29, 2009
  • 52 Answers
Replace the defrost timer, behind the plastic panel in the back of the freezer. small button-looking device on the coil lines with wires going to it. very easy job.
Freezer works fine but top refridgerator won't cool
HI.TRY DEFROSTING IT ALL FIRST.IT MIGHT WORK.GOOD LUCK.ALI
Jun 25, 2012 | Maytag Refrigerators
This is for a kenmore top mount Refrigerator/Freezer Model Number 25363712302. Refrigerator was not cooling properly - was warm. Freezer was working, but after a couple of days, freezer also started to...
Since you say that is isn't cooling properly, I would first start off by cleaning the condenser grill that is located under the cabinet. While this won't correct your problem entirely, it will help!
Most likely you have a defrost system malfuntion. The defrost system consists of the defrost heater (p/n: 5303918208) which is the long tube like thing that sits directly below your evaporator behind the panel in the back of the freezer (inside the freezer). It also consists of the defrost thermostat (p/n: 5303918202), which is located next to the evaporator. Both the defrost heater and defrost thermostat can be checked with an ohm meter - a non-open/infinity reading is good. If both of those check out and are good then it has to be the defrost timer (p/n: 215846602) which is located behind the plastic shield (with the light bulb).
Suggest you defrost the unit (making sure no ice or frost is behind the freezer panel then plug the refrigerator back in. If everything cools down then my diagnosis is correct and one of the components of the defrost system is bad.
Oct 03, 2011 | Kenmore Top Freezer Refrigerator
Frigidaire Refrigerator FFTR1814LW bottom fridge not cooling properly 50 degrees. The top freezer is rock soild Thx
That is the classic symptoms of a defrost system failure. Suggest you look behind the rear panel on the inside of your freezer and see if it is iced up. If it is then it is a defrost problem which could be the defrost heater, defrost thermostat or defrost timer. If it isn't iced up, then check to make sure the fan is operating. If it isn't then it won't push cold air out of the freezer into the refrigerator section.
Sep 14, 2011 | Refrigerators
I noticed our top freezer door was left open approx 8-9 hours overnight. Now it seems it won't shut off? Is the motor burned out?
It will probally have to go thru a defrost cycle before everything goes back to normal. keep the doors shut and wait 24 hours and check it. hope this helps.
Aug 08, 2011 | Gladiator Freezerator Top Freezer...
What a mess. The instruction manual (really lacking in detail) does not have part numbers or model description. Excess moisture dripping in refirgeration portion of unit (top freezer; bottom...
Yes it could, you will have to check your defrost water drain, if its plugged defrost water won't go to condensate pan under unit, instead will make its way down to refrigerator section
Jun 29, 2011 | Maytag Refrigerators
The freezer keeps defrosting.....starts to cool down then back in defrost mode again. Also the bottom of the fridge is not keeping things cold anymore. Could you please help me on what could be...
the defrosting mode could a problem with the defroster timer. as for the bottom one if the top is not cooling the bottom one wont either. the freezer fan is what also keeps the bottom frig cool. the defrost timer should be on the bottom frig close to the ligth.
Jan 19, 2011 | Whirlpool ET8FTEXM Top Freezer...
Frosts up wont get cold MCBR1000S
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 17, 2009 | Magic Chef CTB1821AR Top Freezer...
3 year old kenmore top freezer, won t defrost ''no ice'' buildup behind the freezer panel I removed. no clicks on the defrost test, same result for method #2. The ice maker works ok when freezer is at...
your freezer had a heater and a bi metal behind its pannel. if they won't work properly than you would face problem like this.......contact your service authority. it cannot be solved by your own
May 14, 2009 | Kenmore Refrigerators
Kenmore 21 refrigerator not getting cold - freezer still pretty cold (top) - perhaps not all the way
you have a defrost prblem or a leak in the sealed system.if you see frost built up on back freezer wall then it is a defrost problem also check evaporator fan motor to see if it is running.if machine is in defrost you wont hear it.so when compressor is running see if fan is running.
Mar 06, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Frost on back wall of freezer, side by side, wont freeze
It's most likely a defrost issue. One or more of your defrost components have failed. Defrost components are defrost thermostat, defrost heater, and defrost timer or board depending on model
Nov 21, 2017 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore 64802 Top Freezer Refrigerator Logo
122 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
