My week old Dell has been shutting itself down after I leave it for a few hours. I never use it for very long, so it is not a fan/overheating problem. Also, it is constantly plugged in, so it is not a battery problem. I cannot find out where the power settings are because I am unused to Windows 8. I cannot turn the laptop back on unless I first unplug the power cord. Also, the lights all turn off. (Meaning that it can sleep w/ the lights on and wakes up, but it is completely off when this happens.) I have never had a Dell before, so I am unsure if there are more settings that I am not finding. Thanks for any and all help. Have a great day!!
Call DELL support. Doesn't sound normal. There is Standby and Hibernate modes; neither of which would require you to unplug and plug-in the power cord in order to start the machine.
Dell support will have you run the Dell diagnostic at startup which will detect hardware problems. Or you could run it without calling...
Unplug power and remove battery
Press and hold power button 20 seconds
Replace battery, plug power cord in
Hold down the "Fn" key (to left of space bar)
Turn power button on while still holding Fn key
When diagnostics begins, let go of Fun key
Note any errors; let Dell know your findings
SOURCE: overheat?
It sounds like an overheating problem. When it is booted, does it run ok other than just being slow? Check your cooling fan and make sure it is running and not stopped up. That is a number one symtom of overheating is freezing and rebooting by itself. There is a free program called "Motherboard Monitor 5" that will monitor the temp for you and set off an alarm when it is getting to hot. Check that problem first. Hopes this helps!
SOURCE: medion laptop shuts down itself
Medion MD 96015 Notebook shuts down.
Other searches you may want to try:
If Computer runs Hot or Shuts down for no reason:
Repair4Laptop: How to Repair the Cooling Fan of a Laptop or Notebook
t
SOURCE: Dell Inspiron 8600 - overheating and shutting down
Start by cleaning the fan and heat sink. Dirt or dust build up can cause them not to work as efficiently as they should. If cleaning doesn't fix it, you might consider replacing the fan and heat sink or purchasing a cooling pad.
SOURCE: Dell Vostro 1000 shut down and won't turn back on
nope, it is your dc power regulator board. you will note this happens if the battery is in or out of the laptop. that is the key test. some regulators are on the main board and some are seperate for this reason. I think the vostro though is on the main board. A little board re-work will resolve this issue after replacing some components, but this is way beyond a home user's ability.. trust me on this. Sorry for the bad news. Thanks!
mrstan
Testimonial: "Thanks for your answer. I guess I will check what the repair costs may be, and if too much, just get a new machine."
SOURCE: My sony VGN-CS115J Laptop shuts down by itself.
this laptop is know to have a fan problem you might need to have it replaced, http://esupport.sony.com/US/perl/news-item.pl?news_id=299&mdl=VGNCS115J
