Model 15e604d won't come out of standby mode
Use my lcd tv as a computer monitor when i turn on my computer the monitor does not get a signal but when i press the power button it shows a picture for a second then goes back to standby
    President:
  • 814 Answers
This television is having a problem with component failure. The reason you can tell this is you do see the video information on the screen before the unit goes into the protection mode.The protection mode protects the circuits from doing more damage to themselves.Seeing the the video shows that the television is still functioning. The television needs to be tested and serviced at a service center. The service center will have all the service information to analyze the problem and do the repairs.I hope this information will help you with your problem.
Posted on May 29, 2009
When i plug up the L1975NW lcd monitor what should show up ?
"no input" means that there is no signal from computer or the monitor cable is unplugged. When you first turn on monitor it usually does a self test and then looks for signal. Not connected to PC will give a no signal. If it is connected but PC is off (not unplugged) then it should go into standby as you vid card will be sending a standby signal to any monitor connected. Sometimes the Plug and Play monitors need to register before it will recognize a standby signal from PC, so plug it up and boot up PC. Then shutdown normally, your monitor should go into standby when the PC shuts down.
Nov 11, 2013 | Westinghouse L1975NW Monitor
I have sony LCD Tv klv-32bx300.when turn on the tv sutenly power getting standby.what is the resan?
I have a tv sony lcd klv32bx300 when turning on works for about 15mins then sfhuting down and blinks 3times the red led on standby signal . Then stop for 2sec and again blinks 3times. I bought this tv in the middle east but we are h ere now in phils. I br ought this problem here in sony service center but the cost to repair this problem is half of the price when i bought. Any one can help to fix this problem
Aug 31, 2013 | Sony KLV-32BX300 SERIES BRAVIA LCD...
Monitor standby won't stay on /pioneer 424mv
What is the source of the TV signal? I know many monitors have a "power-saving mode" that returns the unit to standby if there is no signal coming in.
Check that the signal cables are working (try swapping cables). Make sure the source is on before turning on the TV. Press the Input button to select a different source. Make sure that the source signal is not refreshing (or synching) at a rate that is incompatible with the TV. (If your source is a PC that was previously connected to a CRT monitor, the refresh rate should be reset to 60 Hz before connecting the computer the the Pioneer 424MV.)
I hope this helps.
(Pioneer TVs usually give a blink code if there is a hardware problem that prevents it from turning on.)
Mar 17, 2013 | Pioneer Televison & Video
No signal everythings plugged in and turned on still says no signal in goes to standby mode.
1. change the VGA cable and test.
2. Plug to another PC or notebook and test.
if still no signal, it might be the display board inside the LCD is faulty.
You need to get a certified technician to fix it.
If cost is higher than 1/3 of a new 18.5" new :LCD monitor; I think you need to think of purchasing
a new LCD already. As new LCD will cover you with 3 years warranty.
take care.
Jan 03, 2011 | Acer AL1916W 19" LCD Monitor
Monitor won't turn on power button blinks blue
Your computer is not POSTing and the monitor has gone into standby mode as it is not receiving a signal from your computer. My published guide entitled My Computer is not turning on!!! Is it dead!!! No POST!!! will get your computer working again!
Happy testing!
damnor01
Nov 27, 2010 | Gateway FPD1975W 19" LCD Monitor
How do i get my lg tv out of standby mode
It's happening to me also,I have an LG TV and I turned it off before unplugging it and now it will not turn back on. I need help!
May 19, 2010 | LG 22" FLATRON LCD Monitor
Does not receive signal. Power saving Mode appears and that it switches to standby,
have you tried turning it on in safe mode? The F8 key at the top of the keyboard should give you that mode. Once you turn the computer on, continuously press F8 until it switches to safe mode-then go into 'control panel' and check settings for your monitor.
May 18, 2010 | LG L1717S-BN 17" LCD Monitor
Acer monitor 19"
It sounds very normal; when the video signal from the computer disappears, most late monitors will go to standby mode but most will also tell you it's going to sleep with some kind of message.
Turning the main system off doesn't normally disconnect the AC from the monitor so what you describe is that the monitor is plugged into a receptacle of its own, not one that you are turning off with the PC.
BTW, PCs and TVs (including monitors) aren't really 'off' when they are off. They have a small amount of current drain that serves to keep alive certain circuits so they can respond to, for example, the return of the video signal or, in the case of a TV set, a command to power up from your remote. They could not respond unless they can interpret the signal to wake up.
Sep 18, 2008 | TDV Vison F173 17" Flat Panel LCD Monitor
Televison & Video Logo
377 people viewed this question
Top Televison & Video Experts
Electro Med Services...
