Question about GE GSH22SGRSS Side by Side Refrigerator
GE side by side. Freezer cold, fridge kinda cool
The GE fridge is 3 years old. Last year motherboard was replaced due to problems with ice dispenser and other issues (howling). Been working great. All of sudden, freezer goes from freezing to cold and fridge goes from cold to cool. Found massive amounts of frost in freezer! Defrosted fridge for 2 days and all of the frost was melted. Plugged it back in. Things seemed to be relatively back to normal (fridge still didn't seem to be as cold as it was before) but reloaded fridge. Within two weeks or so, back to the frost in the freezer and cool fridge. Checked seals around door to eliminate issue of outside moisture being the cause of the moisture. Everything looks good. Oh, by the way, I checked and the water dispenser doesn't work now! Don't know when that happened! The model of the unit is a GE GSH22JSRE SS.
Please help!
I had a similar problem, i found that the small mast on the motor turning the fan was just spinning and the fan was spinning just a little bit because it sits on there. I took the plastic fan off and put tape around the mast of the fan motor and placed the fan back on so it sat on there tightly. The fan blew cold air again because it was able to **** up the cold from the coils again, compared to when it was very loose.
Posted on Jul 07, 2009
  • 52 Answers
Your defrost timer is bad. this device is dual purpose, it is a small heater/solenoid that calls for the compressor to turn off so the lines can defrost (usually does it once every 48 hours or so). it looks like a round button clipped to the coil lines in the freezer behind the plastic paneling where the cold air comes out. you need to replace that part, which is actually very inexpensive compared to a new fridge. it will unclip from the coil line and the two or three wires will either disconnect or you may have to cut them and splice on the new ones from the new defrost timer. either way it is a job that will take anyone with basic hand tools less than an hour to do.
Posted on May 29, 2009
2 Suggested Answers
  • 56 Answers
SOURCE: GE side by side. Freezer cold, fridge kinda cool
Generaly the control board controls everything sometimes you have a bad thermister GE has a help line I beleive it costs 20.00 bucks but you will need a meter and know how to use it and they willl talk you thru the repair .
Posted on May 30, 2009
Ice forming on the back of side by side 17 yr old fridge
You have a bad defrost heater . To access , you will have to remove the inside rear freezer panel . The heater is located at the bottom of the coils . Take your model number when ordering the part so you get the correct part .
May 02, 2010 | GE Refrigerators
Freezer is cold but not keeping icecream frozen.
If, the fresh food section is 34- 38 degrees, then the freezer should be cold enough to keep ice cream solid. All of the cooling capability comes from the freezer section. I, personally, would not waste time or money on a ten year old box. Ten years ago it cost $1000, so, the outlay is $100 per year. Dump the old refrigerator and get a new one.
Aug 27, 2009 | Refrigerators
May 30, 2009 | Refrigerators
Fridge isn't cold
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
May 28, 2009 | Refrigerators
Refrigerator side won't cool
its iced up and needs to be thawed. you can use a hair dryer and make it fast in say 2 hours. the freezer side is blocked from admitting cool air to the fridge side. your defrost timer may be defective or you had a real humid situation that caused it to ice up.
Dec 08, 2008 | GE GSH25SGRSS Stainless Steel Side by Side...
Water does not dispense from door
I found that the door on the GE side by side doors are not accessable and cannot be repaired if a water line inside the door is defective. The entire door must be replaced at a cost of almost $370. The problem, which seems to be quite common relative to the lack of water at the dispenser, is the result of the water tube in the door freezing due to excess cold levels in the freezing compartment. This is probabley due to poor insulation around the water line as in exits near the ice dispenser gate. The solution is simple, lower the freezing level and use water frequently to keep it from freezing. Also, keep the lines clean by changing the filter often if the local water source is laden with particulates. I think GE should foot the bill for changing doors or re-engineer the doors to access the area where the water line makes contact with the cold surface of the inside panal.
Nov 11, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile PSC23MGNA too cold on frig side & icing up on freezer side
Check your thermostat if it is still functioning well.
May 02, 2017 | Refrigerators
Ice dispenser not working
Ice auger in freezer compartment not working. Common problem with GE side by sides I know of at least 3
Jan 21, 2008 | Amana ACD2232HR Side by Side Refrigerator
Ice doesn't dispense and both freezer and refrigerator aren't cold enough
yes. pull out the frig and look on the back. facing the back on thr right hand side there a rectangle metal plate. under that plate is the main computer board that controls the whole thing. they have been causing alot of problems one of which is the one your having. replace that board and your problem is solved
Nov 26, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
GE GSH22SGRSS Side by Side Refrigerator Logo
336 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
