Question about Vivitar V4000 50MM 35mm SLR Camera
Light meter on my vivitar v335 ( film) doesnt show up
I just got a vivitar v335 from my friend, and when i look through the viewer there doesnt seem to be a light meter.
  • leeann_dimoc May 29, 2009
    Im not really sure if its suppose to have one or not i have only use to working with two other 35 mm cameras and the both had them so i just assumed ( plus it doesnt say automatic any where and it has apature) and i did just chage the batteries and nothing changed
    Thanks =)
  • 256 Answers
If there is supposed to be one in the camera, you may need to install/replace a battery.
Posted on May 29, 2009
  • John Moore May 29, 2009
    It may do the exposure automatically so it doesn't need a light meter. Shoot a roll of film through it to check for results. Best of luck.
Do I need to buy film to use this kind of camera?
Vivitar makes many cameras. Some use 35 mm film and some are electronic. I believe yours is an XM 1K type:
Product description Product Information The Vivitar XM1K is an APS point and shoot film camera, designed to capture photographs with dazzling colors and record the memorable moments of your life. You can click brilliant outdoor photos even in low-light condition aided by the f/4.5 aperture of this Vivitar film camera. Moreover, the Vivitar XM1K point and shoot film camera effectively removes the red pupils from the subject's eyes caused while using the flash, thanks to the red-eye reduction feature. Further more, this Vivitar film camera, supporting autofocus, lets you focus erratically moving objects with precision. What's more, with a four-mode electronic flash, this Vivitar camera lets you choose the flash mode to suit your requirement.
Jan 04, 2013 | Cameras
When you put the film in the meter thats shows you how many exposures you have left stays on the s instead of going to one. The film is being pulled properly and is acting normal but even the sound doesnt...
I would definitely be concerned that the film is not advancing. I have a Minolta that has the same problem. I missed many a picture because I didn't pay attention to the meter showing the film advancing. I would just make sure the film is advancing by taking a couple shots with the back open before closing it.
If you are positive the film is advancing, it really doesn't matter what the meter says as long as the film is stopping after each exposure.
Finally, if the film is advancing , but the meter is not, and you want it to, you will need to see an experienced repairman to correct it.
Good luck.
Thanks for using Fixya.
Apr 27, 2011 | Minolta Maxxum 7000 35mm SLR Camera
How do i take 12 dark, 12 light and 12 perfect pictures with 400 black and white film on a vivitar 3800n camera?
For normal exposure, set the ISO dial to 400. Meter normally, adjusting the shutter speed and/or lens aperture until the green LED in the center lights up.
For dark pictures, you want to underexpose about two stops. One way is to meter as above, then stop down the aperture two stops (larger F/numbers) or increase the shutter speed two stops (larger number) or a combination of the two. Alternatively, set the ISO dial to 1600 and meter normally.
For light pictures, you want to overexpose about two stops. Meter normally then open up the lens two stops (smaller F/numbers) or slow the shutter speed two stops (smaller numbers) or a combination. Alternatively, set the ISO dial to 100 and meter normally.
You can also experiment. Over/underexpose one stop, then two, then three, then four, and even five. You might want to take a notebook with you and write down what you're doing. Record both the setting and how many stops over/under it is. When you get the film back, you can refer to your notes and see what happened.
Jan 25, 2011 | Vivitar Photography
How to work a atlas warner super 8 film editer model 500
My Atlas warner dual 8 editor is mot showing pictures. Everything is there, light, mirrors, magnify. all in place, still no light on screen. Please help. Sincerely. H. Amit
Apr 26, 2009 | Kano Technologies Atlas (K752HCDR) DVD+R...
Vivitar Instant Slide Printer
I asked a friend who has used a Land camera how to insert the film.
Jan 04, 2009 | Polaroid OneStep AutoFocus Instant Camera
Film = no light meter
jackson rook,
the speed of the film may be to high if your camera has dx coding contacts in the film chamber. otherwise---- film in camera or not it has no effect on meter operation. move the advance lever to the right slightly and push down on the shutter release button slightly to turn meter on.
Sep 10, 2008 | Vivitar V4000 50MM 35mm SLR Camera
Taking photos
jeep111
be sure batteries are good. pull up on the rewind knob to open film door. load film ,push down rewind knob. pull enough film to connect to take-up spool. close film door. advance film to counter # 1. look through finder and set meter ( push shutter button to turn on meter ) focus subject and fire shutter repeat to end of film. push rewind button ( bottom of camera ) rewind film.
remove lens by pushing button and turn lens left to remove.
Apr 28, 2008 | Vivitar V3800N 35mm SLR Camera
Vivitar v335 35mm
ATI Radeon 9200 SE 128M DDR AGP 8X VGA with TV+DVI for driver
Apr 17, 2008 | HP ATI FireGL V3350, PCI Express Graphic...
Buttons
S would be 'Start' IMHO, A carry over from the earlier days when paper rolled films had the numbers on the paper rather than the camera having a frame counter.
Feb 23, 2008 | Vivitar V3800N Zoom 35mm SLR Camera
Turn it on
Actually, you don't have to "turn on" the Vivitar V3800N. Just be sure it has working batteries in it (takes two small alkaline button cells, unscrew the cover on the bottom with a coin--put new cells into the holder with the + side up). If the batteries are working, when you press the shutter button halfway down, you should see an LED light up in the right side of the viewfinder. This is the readout for the exposure meter: a red + indicates overexposure, red - is underexposure, a green dot means you've got the exposure correctly set. You just change the shutter and aperture settings until you get the green light, then shoot. When you load film, you also need to set the ISO film speed setting. Pull up on the outside ring of the shutter speed dial and turn it until the number in the window is the same as the ISO number on the film you are using. The batteries, by the way, only power the exposure meter. The shutter is fully mechanical (just like in the good old days), so you can use the camera without batteries if you have a separate exposure meter, or if you can estimate exposure. Film loading is about like any other 35mm manual camera: pull up on the rewind knob to open the back; insert the new cassette of film on the left and pull the film leader out a couple inches and hook the film to the takeup reel on the right. Move the film advance lever a bit to be sure the film is firmly hooked onto the reel, then close the back. Wind and shoot three shots to get the exposed film leader out of the way, and then start shooting. When the film is finished, press in the rewind button on the bottom of the camera and rewind the film into the cassette before opening the back of the camera. Good luck--these are pretty good little cameras. We buy a lot of them for the photography program where I teach, and I've only ever had one with a problem (meter was bad). The lenses are quite good, and they are "K-mount," which means that any Pentax bayonet lens, and gazillions of others with this mount, will all fit. --Michael R. Sawdey
Sep 03, 2007 | Vivitar V3800N Zoom 35mm SLR Camera
Vivitar V4000 50MM 35mm SLR Camera Logo
396 people viewed this question
Top Vivitar Photography Experts
JP Services
JP Services
JOHN TOPLISS
Are you a Vivitar Photography Expert? Answer questions, earn points and help others
