Question about Mitsubishi WT-46807 46" Rear Projection Television
The red portion of the image jumps away from the other two colors
I've heard several ideas on what to fix when one of the colors separates from the other two on a rear-projection television:
(a) the convergence ICs are bad (STK392-570), or (b) the caps are bad, or (c) some of the soldering around these previous two categories of items needs re-working.
What ever became of the other folks suffering from this problem with their WT-46807 televisions?
Where can I get a manual to help me remove the circuit tray? I took the back off, but I can't even find the convergence chips.
  • Peterc34 Oct 23, 2007
    UPDATE: I haven't tried replacing the convergence ICs yet, but I noticed that a light Fonzie to the side of the cabinet fixes it instantly. The first whack fixed it for ten minutes. The second has fixed it for two hours of viewing spread across 3-4 viewing sessions over several days.
    I suspect that the ICs themselves are fine, but they are in need of being resoldered to solidify the connections. This problem only began after I brought home a new surround sound system and watched movies with 'theater volumes' (which my wife would consider to be 'too darn loud'). Maybe I vibrated and cracked a solder joint which is now getting 'cold' from oxidation?
    If no one considers it a waste of time, I might solder suck the convergence IC pins and lay down some fresh joints without taking anything off the chassis (if that's possible - haven't pulled it out yet to see if there's room to rework them without disassembling other junk around it).
    Does this seem likely to cure it, since a Fonzie fix usually indicates a mechanical issue, rather than electrical?
  • Peterc34 Oct 24, 2007
    Agreed. Resoldering is probably just a short-term fix. But, if I can get this old dog to last another six months, I'll be in a better position to get that new 300-inch MonsterPlex 3-D Eyeball Fryatron 6000 I've been drooling over. I'm hoping the price will come down to below $2000 from the $180,000 it's at now.
    Otherwise, a Mitsubishi 73-inch rear projection would be a good compromise (and just happens to fit with only an inch or two to spare in my recessed TV nook at home). It's under $3K now.
    I'll touch up the convergence IC's solder joints and report back.
    Genius:
  • 1,694 Answers
1)The correct solution is (a)....
2)Concerning pulling the chassis on a 46" Mits...
due to compact size,your set has a higher degree of difficulty.
The 73", 65" and 55" are easier to do the same repair.
3)Begin by removing lower front cabinet,then remove front access
panel.Next provide yourself with plenty of light to see inside....
Remove chassis bolts (3) in rear',unplug as needed,noting location
and routing.Next,locate snap clips on front of circuit tray-Release.
Gently pull back on chassis until clear to remove center board.
Almost must pull all the way.Remove & rebuild center PCB.
Re-assemble,test.
Posted on Oct 22, 2007
  • Vista Electronics Oct 24, 2007
    Intermittant pin connects can certainly be soldered for a temporary fix.Then,in usually some weeks or months,a more advanced convergence failure will force the issue of replacing IC's.In th repair
    business,time is money and warranty recalls are the worst time
    wasters!!.......T
Beamerproblem! I've got a red-color problem with
Take it to GameStop. They can find the problem lickety-split!
May 17, 2013 | Office Equipment & Supplies
I cannot get the tension to set correctly on my Singer 6268 sewing machine. For instance, I'm using red thread on top spool and white in the bobbin. Suddenly, as it always does, the thread is loos
I have solved my tension problems by going to threadmagazine.com. they have solutions to many, many problems you have with your sewing machine. Hope this helps. jdokos95
Aug 01, 2012 | Sewing Machines
Watching our Hitachi Ultravision 57" and the colors seemed to separate, seeing several images, each in it's own color. Ghost-like...any ideas?
yes that is always the same problem.,
that is the convergence module where you have two
ic call stk /but you can try the magic focus button if it work for a while and come back you will have to replace the ic.
hope that give you an idea
have a nice day
Apr 22, 2010 | Televison & Video
GREEN IMAGE AND RED IMAGE DO NOT LINE UP ON SCREEN. SEPARATED BY SEVERAL INCHES.TRIED
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 19, 2010 | Akai PT5598HD 55" Rear Projection...
Colors far out of convergence, and image is warped (bowed)
it sounds like bad solder connections on the convergence IC's if you do not resolder them right away the IC's will blow out then you wil;l have to replace them. Good luck
Larry Dillon
Aug 14, 2009 | Sony KP-57WV600 57" Rear Projection...
Red and green have separated. is this fixable?
yes this can be fixed
it is the convergence IC's that controls each color image alignment ,also other components(resistors , diodes , capacitors , ect..) in circuit with these convergence IC's(STK's) also need testing to see what other component has also failed or needs replacing.
Mar 19, 2009 | Zenith R57W46 57" Rear Projection...
Images: three colors appears separates in the screen: red, green, blue
do they look like these:
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 05, 2007 | RCA HD52W59 HDTV Projection Television
Color
heard a crack & black and white picture is ok please check chroma ic & its related parts of chroma portion of that IC
Sep 23, 2007 | Samsung DLP HL-P5663W 56" TV
Picture separated on 1/2 of screen
This sounds like a convergence problem. This is a common problem that is usually fixed 98% of the time by re-placing the STK392-020 ic or STK392-110, and check the fuse devices on the covergence PCB. I'm sure the actual parts numbers depend on the peticular brand. Good Luck!
Nov 09, 2006 | Toshiba TP43H95 43" Rear Projection...
Mitsubishi WT-46807 46" Rear Projection Television Logo
60 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
