Question about Maytag Neptune MAH5500B Front Load Washer
Will not spin. clothes soaking wet,spin cycle shuts off at 7 mins
I have a front load washer model number 5500bww. the machine works fine until it goes into the spin cycle. it will attempt to run the cycle and spin back and forth a few times. the spin cycle will countdown to 7 mins and then sit for about 20 secs then shuts off. i have checked all hoses and pump for obstrucitons. still the same problem. i checked the control board to see if there was anything burnt out on it and it looked normal. any suggestions?
  • 530 Answers
Is your door lock light lighting up? if not you have a bad board and wax motor in the door lock. if you look at the board and locate r11 and see it burned this is 100 percent your problem. now do you have delay wash cycle? if so set it into delay and then locate your motor control board which is in the bottom you need to oipen the door and remove all four screws. be carefull the door may fall off don't remove the door but do remove the outer piece to locate the motor controller. Locate the jp4 connecter and remove it. make sure the unit is unplugged when openning up and removeing these. Now plug unit in if the unit starts tumbling, you may have to hit start, but if the unit continuously tumbles then you know that your motor and your motor controller are ok. If they do not then you have a bad motor/motor controller. Now if it tumbles freely you have 3 out of balance sensers one of them is bad they have 2 blue wires going to them check the connections and make sure non of them are broken and let me know how it goes
Posted on May 29, 2009
When the cycle is done my clothes is still soaking wet
Hello becca_m2012 ,
Is the machine a FAV6800A or FAV9800A. If it is one of those models are you failing in Spin Cycle of the Wash Cycle with a dC or Uc error code to the display? Lets nail down the model number and I will try to point you the repair path......Rich
Nov 16, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washer will spin while in rinse mode, but does not
this could be a main control board problem.how ever i would check the drain pump for any kind of foregin object that may be causing the drain but to stop functioning.last resort bad drain pump
Sep 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire gallery front load won't spin
Does the washer spin after the wash cycle? It sounds like the door switch. This is a common problem with frigidaires. 90% of the time a door switch fixes it.
Jul 01, 2009 | Frigidaire Washing Machines
Will not spin, clothes are soaking wet.
Are you sure washer is level? I solved our problem that simple and I had worked on solving it for weeks until I double checked the level and found it a little off. Now it works wonderfully.
May 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
Cloths Soaked after Spin Cycle
If the motor has a transmission, it could be stuck in 1st gear. I think the agitator running is normal.
Jan 17, 2009 | LG WM1814CW Front Load Washer
GE Front Loading Washing Machine seems to be holding water....
The high speed spin of a front load washer should normally do a good job of getting squeezing out the water but if there is an oversudsing condition that makes it hard for the drain pump to operate then the suds and water will just stay there. First make sure there is no actual clog in the drain line then run a load with no soap or detergent and see what happens. It's always better to use a low suds detergent with this type of machine
Mar 08, 2008 | GE WSXH208A Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
304 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
