Question about Dell Latitude D600 Notebook
Dell latitude D600 battery charge light flashing
My Dell laptop's battery used to work properly and charge and show a green light flashing while charging. Now I can't get the battery to charge and when it is plugged in I am seeing the charge light flash orange quickly 4 times, followed 1 longer green light flash. The computer appears to work fine while plugged, but won't work when it is not "plugged in". IM JUST BUY A NEW BATTERY FOR MI DELL LATITUDE D610 AND WEN RUN OUT OF BATTERY DON'T CHARGE AND DON'T SHOW ANY LIGHT
  • 822 Answers
It means your battery is damaged. avoid using battery while using charger in your house. remove battery to be safe. battery is for outside or for travel only.
Posted on May 29, 2009
    President:
  • 2,559 Answers
The 4 orange flashes mean the battery is defective.
  • 52 Answers
Check the system setup (usually by hitting something like F2 or DEL when the laptop first powers on). there should be an option in there to "re-learn or "refresh" the battery. it will send it through a few charge/discharge cycles and then if the battery isn't toast it should work thereafter.
  • 197 Answers
Tried to remove battery and ac for a little while?
if that doesnt work, remove battery and ac-power.
remove the ram
put ac-power back and try to boot without ram
(do you get a beep/error?)
remove the ac again
insert the ram
insert battery
insert ac
try to boot up again.
if that doesnt work its probably a mainboard error and you need to take the computer to repair.
jilpeshpatel
  • 259 Answers
SOURCE: install dell latitude D600 keyboard on dell Latitude D500
http://support.dell.com/support/topics/global.aspx/support/product_support/product_support_central?c=us&l=en&s=gen
you have click this link and after Service Tag numberm add and collect your manul for your laptop
Posted on Mar 27, 2009
bob_computer
  • 3153 Answers
SOURCE: dell latitude D610. Screen goes black. External Monitor OK.
Make sure you have not accidentally used the FN+F5 key
That combination sets the laptop to use an external display.
If using that does not give you a display take a small torch (flashlight if in USA) and shine it at an angle on the laptop screen.
If you can see any sort of picture you would be looking at replacement of some minor parts to the laptop screen
Hope this gives you the information you need. If not add any extra information you may have and lets see if we can FixYa
Bob
Moderator
It would be very decent of you to consider the quality of our expert’s answers and judge them accordingly as you pass through FixYa.
Thank you
Posted on Mar 15, 2010
  • 3940 Answers
SOURCE: Latitude D610 PC Notebook: I am looking for the Dell Latitude D610 serial Num...
On the bottom, labeled SERVICE TAG 7 digits, numbers and letters
also located in the system BIOS
Posted on May 20, 2010
  • 10 Answers
SOURCE: DELL LATITUDE D610 DRIVERS...
You didn't say what the problem is, but if you're looking for the drivers you can go here and find all the ones you need and see which ones might need updating - http://supportapj.dell.com/support/downloads/index.aspx?c=sg&cs=sgdhs1&l=en&s=dhs
If you're having problems with your drivers, you should have a program called "Dell Quickset" or something similiar from Dell that should be pre-installed and it can do scans on your system to see what could be wrong and/or see what you might need.
Posted on Aug 19, 2010
SOURCE: Latitude D610 PC Notebook: how do i turn on my bluetooth dell latitude d610...
I CAN NOY ON MY COMPUTER D 610 BLUETOOTH.TELL ME PROCESS
Posted on Dec 09, 2010
My Dell laptop's battery charging circuit faulty.
try to remove your batt and check if laptop works fine with ac adapter alone.
if yes then put batt in then check how much charge you have if you have about 10% then update the bios immediately.
if fails then have the batt replaced.
Oct 12, 2009 | Dell Latitude D600 Notebook
Dell latitude d600 will not turn on / power on
it means not charging the battery pack, did you check the dc jack connector, or the.
charger check it if working properly, if the same problem open the laptop then check the baord
thanks
Jul 12, 2009 | Dell Latitude D600 Notebook
Go to support.dell.com and download the latest bios firmware to update it. If it still does not work then most likely it is already a hardware issue so you need to contact dell support for the hardware issue.
Jun 03, 2009 | Dell Latitude D600 Notebook
Dell latitude d600 blinking battery light
I would say its defective. Bring it back to where you bought it and show them. Bring your laptop charger also so you can show them it in action. Hope this helped.
Jan 04, 2009 | Dell Latitude D600 Notebook
Dell battery problem
Hi Roy,
Dell, apparently have had some problems with their batteries, as they called back some, including yours.
Goto Dells homepage here and goto -> a bit down this page -> Step 1: Is your battery model affected?
Hope your battery is among these, as you will be able to get a new one.
regards
/Teis
Dec 17, 2008 | Dell Latitude D600 Notebook
That usually indicates battery is beginning to go bad. Eventually it will not hold a charge and will need to be replaced.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 09, 2008 | Dell Inspiron E1705 Notebook
my suggestion is that you allow the batteries to fully recharge(which only happens when the computer is fully off, when the battery is deep discharged.
that will take around 6 to 10 hours each..
Mar 10, 2008 | Dell Inspiron E1505 Notebook
Orange and green light flash
The flashing battery light is an indication that the system is attempting to charge the battery. The orange light indicates a problem charging one of the battery cells. This usually means that the battery either needs to be recalibrated or replaced. To recalibrate the battery just use the system until the battery is dead, then recharge and repeat the process twice, after which time the battery should be recalibrated. If this doesn’t fix the flashing orange light then the battery may need to be replaced.
hope this helps
Jan 07, 2008 | Dell Latitude D600 Notebook
Dell Latitude D600 new battery won,t charge
the charger in the laptop is not functioning. pc will need repaired
Dec 28, 2007 | Dell Latitude D600 Notebook
I had the same problem, I removed the bettery while it was still plugged in, tested it, then plugged it back and and now all is fine.
Nov 02, 2007 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
1,702 people viewed this question
Alun Cox
