Question about Kenmore 44103 Side by Side Refrigerator
Kenmore side by side makes no ice
Kenmore side by side want make ice. I replaced the water filter,and the water intake valve. The water dispenser is working fine.I used my multimeter to check the voltage on the ice maker. The voltage shows 120 vt.
    President:
  • 1,136 Answers
Hi, While you had the ice maker out, did you notice if there was ice in the inlet spout to the ice maker. Sometimes they get plugged.
Do you know if the ice maker advances at all?
Because you have voltage to the ice maker, if it does not advance you will need to replace the ice maker.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on May 29, 2009
  • 52 Answers
The water line coming into the freezer may be iced up. or the motor that spins the ice "ejector" arm may be stuck. try spinning it manually (just dont force it).
My kenmore side by side is not making ice
when was the last time u change your water filter, if water is coming into the ice maker and it don,t make ice that means u have a defective ice maker, if no water comes into the ice maker check the water valve at the back of the refrigerator with an ohm meter for resistance if no resistance is present replace water valve,u should unplug water valve when checking
Jan 16, 2013 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have a Kenmore side x side. I have changed the water filter and now water is coming from the water spout when water is needed to make ice. Just prior to changing the filter I noticed water coming from...
Sounds like the dual water inlet valve on the back where the water supply is connected, has gone bad and is leaking across to the other side. It may also put water into the ice maker when you use your dispenser.
Jan 13, 2011 | Kenmore 44103 Side by Side Refrigerator
Kenmore side by side water dispenser has stopped
Most likely need to replace the water inlet valve. The water supply line should be directly connected to it. There are 2 valves bracketed together, 1 for the ice maker and 1 for the water dispencer. You will probably have to buy both valves, but want to do this anyway as the second valve will fail soon. Hope this helps.
Jun 14, 2009 | Refrigerators
Water dispenser in the door is dispensing water very very slow.
check and see if the ice is fully formed or look hollow / if hollow then run you a new water line to frig / if cubes are full then replace water valve.
Nov 24, 2008 | Kenmore 53642 / 53644 Side by Side...
KENMORE ICE MAKER STOPPED WORKING
MAKE SURE THE ICEMAKER IS ON,ON OFF BUTTON OR LEVER IN DOWN POSITION,CHECK TUBE BEHIND ICE MAKER PULL IT OUT LOOK IN IT LOOK IN FREEZER HOLE TO MAKE SURE IT'S NOT FROZE UP,CHECK WATER INLET VALVE ON LOWER BACK OF FRIG.,LOOSEN CONNECTION TO SEE IF GETTING WATER,IF WATER IS COMING OUT IT IS A BAD WATER VALVE ONLY ONE SIDE TO WATER DISPENSER IS WORKING,VALVE IS NOT OPENIBG TO ICEMAKER SIDE,THANKS-MIKE
May 29, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore side by side refrigerator
there is valve for each right at the water inlet, your valve is stuck or your coil is bad......get a new valve.
Nov 03, 2007 | Refrigerators
Kenmore 44103 Side by Side Refrigerator Logo
244 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
