The picture is very dark on my Philips PC camera SIC4750/27
I have all the lights on and even a lamp on behind the camera and the picture is still dark. Do I need to change a setting? If so, how? Thanks!
  • Jonny Wills
    Jonny Wills May 11, 2010
    Could you by any chance clarify what make of webcam and what software you're using to access the image that it's displaying?
  • 413 Answers
What operating system on the computer?
Windows or Mac?
XP or Vista?
Brand of webcam?
If you are using Win XP or Vista, goto Start, All programs, look for the Brand of webcam you are using.
Click on the program, there should be a set up window somewhere for adjusting the light levels.
Posted on May 29, 2009
SONY WEGA KDF-50WE655 PICTURE IS DARK MY LAMP IS ONLY 2 MONTHS OLD
Where did you buy your lamp? sounds like its not a real philips or osram. Discount merchants sells some junk lamps. If you got it there, thats your problem
Jun 13, 2016 | Sony Grand WEGA KDF-50WE655 50" Rear...
Dark picture..not bright picture
The whole point of a webcam is to be able to see the person you are speaking with, and let them see you. When the image broadcasted by your camera is too dark, the person on the viewing end won't see anything but shadows and dark shapes. Learn how to brighten your webcam image so the people you chat with can see you.
Place lamps behind and to the side of the webcam. This casts a light on your face, but the lamps will not wash out the image because they are behind the camera. Turn off lamps that are behind you. You have trouble seeing things when you are looking in the direction of the sun or a light bulb. Your webcam has the same problems. Don't make it stare at a bright light. Open up a white screen on your computer to brighten your face. The white screen will create the brightest possible light from you computer screen and help lighten your webcam image. This option is best when lamps are not available. Open up an empty tab in your Internet browser, or a blank Notepad document, and expand it to the full of your screen. Adjust your webcam settings. The settings available to you will depend on your webcam, but many of them offer a "Brightness" setting that you can increase to lighten your webcam. Open the program that came with your webcam, then look for a "Settings" or "Options" menu. Increase the "Brightness" setting until it has lightened your webcam enough.
b>
Feb 08, 2013 | Gear Head Computers & Internet
I have a philips 60pl9200d/37 the picture is fairly dark even though I've turned the brightness all the way up
The lamp can cause a dark picture if it is defective. There is an access door to the lamp. Take the lamp out and inspect it. Especially at the bottom of the center stem where you may see a bubbling of the glass. If so it is bad for sure. Other problem could be in the main board. For good price on lamp with housing go to pureglare.com and enter the model number.
Oct 24, 2011 | Philips 60PP9202 60" Rear Projection...
My phillips SPZ3000 cam is very dark at nite with the light on
Change to another camera. The problem is in your cameras ccd chip. The sensibility of that chip in your camera is not strange enough to sens the light and create the picture.
I hope you have a normal light source not a night lamp or a torch or so...
Dec 28, 2010 | Philips TV Tuner Video Capture PCI Card -...
I have a Fuji FinePix A330 camera and when I try to take a picture in the light, daylight or lamp light, lines appear through the picture. Sometimes fine lines but other times like a burst of light. This...
I have a Fuji FinePix A330 camera and when I try Problem with the Fuji FinePix A330 Digital Camera I have a Fuji FinePix A330 camera and when I try to take a picture in the light, daylight or lamp light, lines appear through the picture. Sometimes fine lines but other times like a burst of light. This just started happening recently. But when I take a picture in the dark with the flash the photo turns out fine. Any answer as to what caused this? Thanks
Dec 28, 2010 | Fuji FinePix A330 Digital Camera
Our philips dlp tv was getting a dark picture then today no picture but sound then the whole tv shut off and will not come back on do we need to replace the lamp?
Definately sounds like a bad lamp. A lot of times you can look down in the lamp and the filament will be broken or busted up. That would tell you for sure, but even if it is not visibly bad, I would definately try replacing the lamp first. I've changed many of them at our shop, and your description is definately a common symptom of a bad lamp in any dlp.
Jul 29, 2010 | Philips LX-5414 DLP TV
The picture is too dark from logitec classic cam
hi i had the same problem with mine, this can be overcome by an external light source ie, a lamp or a brighter room light, make sure that it is not facing towards a window like having the window behind you as this will then set off the light reduction setting in the camera, but light coming from behind the camera is better...hope this helps
Feb 25, 2010 | Logitech QuickCam Express Web Camera
Ihave a Philips 50PL9126D tv and I just replaced the lamp because the picture was very dark. I can see the picture but it is still somewhat dark, bright in the middle,dark at the edges. I tried to adjust...
Sounds like you may have the wrong lamp. Make sure you purchased a Philips lamp that's 100% compatible with your television model. Philips pioneered that lamp, so naturally they make 100 different types for DLPs and LCD projections.
You may have an elliptical lamp instead of parabolic. The lamp for your TV should read P22h.
Feb 04, 2010 | Philips Televison & Video
Pictures very dark even with a light meter
Digital cameras operate on a delayed shutter. Your Camera and flash are not synchronized. Try adjusting flash to a slower speed. Or the cameras Fstop value to get them insync.
If you half push the shutter the rangefinder and focus circuits kick in and will adjust to available light and give you your best picture. Do not ever push the shutter in one step. press it slightly to get the best focus and then push the last millimeter to get the picture!
Dec 29, 2009 | Fuji FinePix S3 Pro Digital Camera
Dark picture on my Philips 50" DLP HDTV
You will need to replace the lamp. That is the only thing that will cause the picture on a DLP to go dark. Please take a few moments to rate my answer. Thanks....
Nov 19, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Computers & Internet Logo
218 people viewed this question
David Payne
David Payne
