Question about British Telecom Jabra BT2010 Wireless Headset
Connect jabra 2010 to my toshiba satellite laptop
I have a BlueTooth (Kengsinton) adapter connected to my laptop and i can't connect jabra 2010, but jabra with my nokia phone works fine. How can connect it?
SOURCE: Problem facing with paring Jabra BT125 bluetooth with Nokia 6300 handset
http://jabra.pairx.co.uk/?l=28&pp=608
This is the tool to pair.
Njoy,
Kailash Rele
Posted on May 20, 2008
SOURCE: My Jabra BT160 won't connect to my Nokia 6103 why?
hold the on/off button and the + button for 2 min. If you fail at the first time. Try again, until you see the blue solid light. Search again in your phone, you should see Jabra bt160. Enter 0000 at the passcode. Good luck
Posted on Jun 22, 2008
SOURCE: How to use Jabra BT5010 with 2 mobile phones
how to activate bluetooth jabra
Posted on Jul 05, 2008
  • 3 Answers
SOURCE: need passcode for the Jabra 2010 bluetooth headset
its normally 4 Zero's 0000
Posted on Mar 25, 2009
SOURCE: Bluetooth stopped connecting - solid light
I followed one of the solutions that I found on your website! I deleted and added the connection on my phone again and used 0000 as the pin number.
Worked great!
Posted on Apr 09, 2009
Is this laptop Bluetooth compatible
compatible maybe.but has no bluetooth as standard. optional adapter or board required.u can connect to a mobile phone using wireless.if u r wanting to use phone to share internet connection using hotspot on phone otherwise usb lead.anything else,a bluetooth dongle to plug into usb will be cheapest and easiest option
Nov 20, 2015 | Toshiba Satellite C655-S5125
I have a toshiba satellite L655-171 system unit and i can't find the bluetooth.Is it possible not to have this kind of setting?
Hi darknuage...
You do not have bluetooth on this Toshiba Satellite L655-171 according to the spec sheet I found at this website...
But you can buy a bluetooth dongle and have bluetooth on this computer.
Please take time to rate me
http://laptops-specs.blogspot.com/2010/06/toshiba-satellite-l655-s5071.html
Bluetooth Dongle
http://www.dealextreme.com/p/super-mini-bluetooth-2-0-adapter-dongle-vista-compatible-11866
Aug 12, 2011 | Toshiba Satellite L655-S5101 Laptop
I have a toshiba l755d, how do you use the bluetooth
is your laptop Bluetooth ready or is it Bluetooth enabled?
To find out if it is Bluetooth ready go to control panel and see if you can see a Bluetooth icon anywhere if you have then just click the Bluetooth icon and it will take you through a setup wizard to connect to your phone or any Bluetooth device.
If it's not there then your laptop is most likely Bluetooth ready which means it can support Bluetooth, so you will have to buy a Bluetooth adapter which are fairly cheap.
hope this helps.
Jul 16, 2011 | Toshiba Satellite L500 Series Notebook
The Jabra A210 keeps dropping the connection between the devices.
My solution is to connect the jabra audio jack to the speaker output of my receiver. Jabra need it to detect a source. If the connection to the source is cut, jabra waits around 30 seconds and if nothing happend jabra stop the transmittion. I hope that helps.
Mar 13, 2009 | LG Jabra A210 Bluetooth Adapter for...
Jabra bluetooth adapter A210
hi,
you have to connect the jabra audio jack to the audio source, to the speaker output of your receiver for example. If jabra detects the source it will work. If you cut the connection, jabra watch for a while if something happend and than stops the transmittion. Hope that helps
Oct 26, 2008 | LG Jabra A210 Bluetooth Adapter for...
Jabra BT620 Microphone dose not work with Soft Phone on My PC
Well, I got the same problem the days before, and after some trying, I've solved.
I'm using the Toshiba bluetooth adapter, too. You see, when you want to make a new connection with your bluetooth device, you may either use the Express Mode or the Custom Mode. Go with the Custom Mode, then, there appears the Jabra BT620. After input the 0000 code, you may select the services from 3 options. There, you can find the headset or hands-free option.
Go with that, than you may have your Jabra BT620 as a microphone!
Sep 09, 2008 | Jabra BT620 BLUETOOTH STEREO HANDS-FREE...
Cant find updated drivers for vista
The solution from 2 years ago doesn't work.... It's October 2010 now... I went to Broadcomm's website and download their fix:
http://www.broadcom.com/support/bluetooth/update.php
Jul 23, 2008 | Jabra A320s Bluetooth Wireless Adapter
Adding bluetooth to toshiba laptop
Well,I'm not really an expert on Bluetooth, but let me try...
Which version of Windows are you running? If you have Windows XP SP2 or above, the Microsoft Bluetooth stack should be installed on your system. First make sure that the Kensington bluetooth adapter is compatible with the printer and the OS. From what I heard Canon sell a separate Bluetooth adapter for about $80 for this, but I'm not too sure.
Secondly, ensure that the built-in Bluetooth Stack or Software has the required Profile for your printer.
Next, put your printer in "discover" mode (see printer manual for more info ). Use the Bluetooth Connection Utility software that came with the built-in Bluetooth stack to "discover" the printer. Follow the instructions by the Bluetooth stack manufacturer on how to pair and connect Bluetooth devices to your built-in Bluetooth stack.
Please also see THIS article. although it is meant for the Logitech DeNovo keyboard, it can be used for any Bluetooth enabled devices. (Just replace the DeNovo wit your printer in the article.
But mainly, make sure that the Kensington adapter is compatible...
Hope that helps..
IrishDruid
May 04, 2008 | Toshiba Satellite A135 Notebook
British Telecom Jabra BT2010 Wireless Headset Logo
238 people viewed this question
Top British Telecom Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a British Telecom Radio Communication Expert? Answer questions, earn points and help others
