Question about Mitsubishi WT-46805 46" Rear Projection Television
Mitsubishi WT 46805 ~ Picture gone..... :0(
We have the 46" Mitsubishi WT-46805 - and all of the sudden today the picture is in and out... When we turn it on - the channel information on the top left of the screen is shadowed by multiple colors - and appears rounded. If it does come on with a picture (sometimes) - the picture goes away within a few minutes - but we still have audio... We are military remote... Please advise anyone! Thanks!! my mitsubishi rear projection tv goes out and i can sometimes grab it and pull on the screen and it may work for days or minutes . what can i do
  • 6 more comments
  • ricegirl710 May 29, 2009
    sometimes it will work fine the others it will flash or flickers will you watch it then goes out it may play for awhile..so how do i fix it
    i have those at work tell me what to do and i'll try today or in the morning thanx alot we need this set
    i have the soldering gun for my tv how do i do that
  • ricegirl710 May 30, 2009
    i took the back off the set and it says its model ts 5545 and when i turn the set on there is no picture and the projectors are not on green power light is on and sound is fine it has three projectors and the three littltle tubes underneath them have just a very faint pin light in them does that make since
    thanx i'll try in the morning to look at those convrgence ic s maybe i can find and fix those
    on the convrgrnce ic what am i looking fo breaks in the solder
  • John Snow
    John Snow May 11, 2010
    Do you have a soldering iron, 45 watt, good solder, solder wick, or a friend or coworker that may have these items. If so then let me know and I will try to help. I will have to caution you on opening the back of any television.
  • John Snow
    I am not sure, but is appears by your post that you have an intermittent problem with your set. If the colors are off sometimes and not others, you may just have some intermittent solder connections in the convergence IC's.
    President:
  • 788 Answers
There are two and sometimes three very large IC’s that control the convergence in a big screen set. I think that you have two that are on the board in the center of the set. They are secured to a very large aluminum heat sink.
There are two ways to repair intermittent connections on the convergence IC’s. I usually remove the board with the convergence IC’s on them and then and solder the connections. The other method is to tilt the circuit board and solder them while still installed in the chassis.
If you remove the board and repair the connections, be careful to remember which connections need to be made when you replace the board. Mitsubishi uses a lettering system, so it should be easy.
If the problem remains after you have made the repair, it is possible that the pins on the IC’s have become loose. In this case the IC’s need to be replaced. I have seen this on several occasions.
If you choose to repair the set yourself, be very careful of the high voltage that can be stored in the capacitors, and CRT’s. This voltage can be as high as 30,000 volts.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Posted on May 29, 2009
  • 2 more comments
  • John Snow
    John Snow May 30, 2009
    You have no video going to the CRT's the faint light is fine those are the heaters. I am not sure how much I can help you via this post, with a step by step troubleshooting procedure. I would repair the convergence IC's or at least have a look at them and then go from there.
  • John Snow
    Were you able to locate the convergence IC's?
  • John Snow
    John Snow May 31, 2009
    You may not be able to see the ring cracks in the connections. Sometimes you will see them if the soldering iron heats them up they will become evident. Where you able to get the set repaired?
  • John Snow
    John Snow Jun 01, 2009
    Please update your feedback, I can't understand why you would rate this comment when you haven't got a repair. These posts and the response is all that I and others work for. I believe that I have been more that helpful.
Mitsubishi WT-46805 46 in. Rear Projection Television- No Picture
I had audio and no video. Now I cant get ant thing and the TV turns off by itself
Jul 28, 2008 | Mitsubishi WT-46805 46" Rear Projection...
Mitsubishi WT-4605 - picture going dark, comes back
Good Day, rflinker;
Please check for fluid on the TV's PCB's, look toward the front of those boards, ensure all cables are properly seated into their sockets.
Good Luck, big IRISH.
Jul 25, 2008 | Mitsubishi WT-46805 46" Rear Projection...
Mits 46805 - Replaced IC's now picture is dim!
Good Day, Nickb2b;
The IC's you installed will not cause a dark/dim picture......but I would like you to check two things:
1. Make sure you put all cables that you may have unplugged into their proper positions, the cables are marked with numbers, ensure all cables are properly seated,
2. Look for fluid on the PCB's.
Jun 21, 2008 | Mitsubishi WT-46805 46" Rear Projection...
Mitsu 46805 - No picture
this model has loose connections on the yokes remove the front speker gril and a small cover wigil the wires alittle and see if the pic comes back on if so solder the bad connections and put fresh solder on the verticl ic too
Oct 18, 2007 | Mitsubishi WT-46805 46" Rear Projection...
Good Day, Corri;
It sounds like the TV has a Circuit problem in the convergence circuit. If it comes and goes then the concern can be corrected by re-soldering the 'conv' output IC"s. A semi-minor repair and cost.
Aug 18, 2006 | Mitsubishi WT-46805 46" Rear Projection...
Mitsubishi WT-46805 46" Rear Projection Television Logo
351 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
