Question about Kirby Ultimate G Bagged Upright Vacuum
Kirby turns on with hose attachement but not with head attachment
I used my kirby with the head attachment, two minutes later used it with the hose attachment and then went back to the normal head attachment and it won't turn on. Tried the hose attachement again and it turned on. I have no idea what is going on, but it makes a funny noise with the hose attachment and sounded fine with the head on.
  • Kirby Expert
  • 324 Answers
Front of the unit, black switch that is pressed by this plastic protrusion from hose coupling has two parts. It is because ANY generation Kirby has speeds - HIGH for vacuuming with hose and LOW for using it with nozzle.
Looks like the switch went bad (Switch HERE)
We have instructions for replacing it too.
The "funny noise" with hose throws me off a bit though. Check if there is nothing in the hose (put a nickle through it).
Good Luck
Posted on May 29, 2009
Kirby works with the brush roller head; but not the hose attachment (won't start with hose attachment)
The part of the hose that attaches to the vacuum should push on the switch on the front of the vacuum so it won't come on without the nozzle or hose attached. Inspect the hose to see if that part may be broken or not making good contact to activate the switch,
Feb 26, 2018 | Kirby Vacuums
How do i attach the hose to the vacuum so i can vacuum my vents?
Remove the vacuum head by tilting the front down slightly and pulling straight back. Attach the wand hose onto this opening by placing the small hooks of the hose on the bar beneath the opening and pushing the hose against the vacuum base. Lock the hose in place by turning the vacuum head lock from left to right so it catches the hose.
Read more: Kirby Ultimate G Instructions ' eHow.com http://www.ehow.com/how_7935766_kirby-ultimate-instructions.html#ixzz1VyB7yixm
Aug 24, 2011 | Kirby G6 Bagged Upright Vacuum
My kirby vacuum just quit when I was vacuuming my car
Your Kirby has a cut off switch in the front where your hose attaches and also on the side where your bag attaches. If the plastic prong that activates the switch broke off your hose you vac will not turn on. If you put the head back on and make sure your bag is on correctly and the machine runs, you just need a hose end to fix your problem.
Oct 08, 2009 | Kirby G4 Bagged Upright Vacuum
What parts go to a Kirby Shampooer?
There is a shampooer head with shampooer brushroll, water tank, small hose that hooks to the tank, collection tray
Need to use the Kirby shampoo. It goes down as wet suds but you pick up the suds with the vacuum when it drys. Fill tank adding 1 cap full of soap (kirby soap only) per level on the side, this attaches on the side where the bag is attached
After using the shampooer you need to reattach the vacuum bag and main brushroll nozzle as though you were just vacuuming up dirt.
Instructions:
Lift the front of your kirby up (front part with light) open the handle on the dail in the front (if epquipt), remove the power head, put on height adjustment on highest level, turn dial on front of power head until you see 2 red arrows facing each other, unlock by turning knob, power head should come right off, get shampooer out the power head for shampooer with collection tray, make sure dial is set red on red, put on front of Kirby and lock in, turn dial to green on green arrows, fill tank adding 1 cap full of soap (Kirby soap only) per level on the side, this attaches on the side where the bag is attached, line up arrow and notch and turn, to hook up hose put Kirby down to lowest level, notched end of hose hooks in on tray other end on the tank,on/off switch refers to the foam, Turn machine on to lay the foam & scrub carpet, take shampooer back off to extract the foam once it's dry.
Good luck.
Aug 20, 2009 | Kirby G5 Bagged Upright Vacuum
Can't find owner's manual. need to use my kirby g4 to inflate an air mattress. help
Remove power head and bag from motor install pig nose attachment on front where powerhead goes install hose on back where bag attaches put inflator tool on hose
Jul 06, 2009 | Kirby Vacuums
How to attach Kirby Heritage Suds-o-gun?
To use the suds-o-gun you need to convert you Kirby to blower mode. First remove the carpet head.
If you have all of the standard kirby attachments there should be a plastic cover to go over the front of the kirby where the carpet head attaches. Its round with square holes in one end. If you don't have this no biggie. Just leave the carpet head on the machine and rotate the belt to the off position so the brush rool bush on rotate. Remove the bag for the machine attach the hose where the bag was use the same end that attaches to the front on the machine. There are notches on the inside of the hose connector the fit over the tabs on the bag port. Fill the suds gun tank with shampoo and water. Attach the suds gun to the kirby hose. The suds gun nozzle is funnel shaped with wire mesh on the end. This helps to make the suds finer. Also the suds gun should have a knob to set how much suds come out when you pull the trigger. Turn on you kirby and suds away.
I hope this helps.
Feb 05, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Connecting hoses on Kirby G4
The hose attaches in place of the beater-bar head unit. To remove the head unit, lift the headlight assembly, then turn the square gray Kirby emblem counter-clockwise 3/4 of the way around until the red triangle on the square portion aligns with the red triangle on the base unit (this disengages the belt). Then flip the silver metal fastener that was underneath the headlight to release the head unit and remove the head unit. To attach the hose, simply line it up so that the safety button is engaged by the hose assembly and then use the metal fastener under the headlight to secure the hose to the base unit.
Nov 17, 2008 | Kirby Generation 3 Bagged Upright Vacuum
Kirby Ultimate D and Zippbrush
The zippbrush and shampoer are two different attachments. The Zippbrush is a small hand held device that is basically a rotating cleaning head that attaches to the hose. Connect it to the hose and the airflow starts turning the brush head, when it's running you'll hear a "zipping" sound.
Jul 08, 2008 | Kirby Ultimate G Bagged Upright Vacuum
I have lost My Kirby G5 Manual
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=11561&thid=539967
Posted by Marie1231 on Apr 23, 2008
I need to know how to use the attachments that came with the Kirby. I know how to use the shampoo/vacuum, but not the other attachments or the upholstery cleaner. Does anyone have any idea?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
1st, you need to un-hook the lever @ the top of the Kirby head, dial off the belt from the Kirby Vacuum Head using the Kirby emblem in the front of the vacuum, that also serves as a hook/spoon to dial the belt off the fan pulley. Once you have removed the vacuum head you now hook up the attachment hose to use the attachments by locking the attachment hose to the top lever. All regular Kirby attachment will fix on the attachment hose end including the spin brush if you have one with your Kirby --- using the Kirby Shampoo spray the soiled area and use the spin brush to agitate the carpet and or upholstery, try not to use to much water. If you have a Kirby shampooer – use the recovery tank on the exhaust port of the Kirby (this means that the cloth/paper bag needs to come off and install the clear recovery tank. Please refer to the Kirby owners manual for any type of trouble shooting that you might need – or please feel free to contact your local vacuum dealer in the yellow pages or contact your Kirby factory manufacturer listed below:
http://kirby.com Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 23, 2008 | Kirby G5 Bagged Upright Vacuum
Cleaning upholstery with the Kirby?
it depends on the make of the kirby you are using but most kirby systems come with a portable shampooer and special shampoo. I would not recommend using your zip brush for shampooing purposes, the zippbrush is designed to loosen up dog hair, dirt, ect. when vacuuming. to shampoo upholstery do the following: remove bag from side of machine, place hose where bag goes, remove power head from front of the machine, place air intake valve on front of machine where power head was (intake valve kinda shaped like a pig nose with small holes on end) attach portable shapooer to end of hose and fill with water and kirby shampoo spray shampoo witch is foamy looking on whatever you are shampooing, rub into fabric w/a brush and let sit till dry. when dry turn kirby back into a hand held vacuum by putting powerhead back on front of machine and putting bag back on side of machine, then vacuum furiture. (make sure it is 100% dry before you vacuum because Kirby is not a wet vac!) Hope this helped ya out a little
May 23, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
123 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
