Question about Epson Stylus Pro 10000 InkJet Printer
Epson 10,000 won't print on posterboard
On the Epson 10,000 I'm trying to print on posterboard. What paper type should I choose? I tried Double weight matte and I also tried Heavy media 1, but I just get "error Printing". Any suggestions?
  • AliceL May 29, 2009
    What paper type should I choose in the print driver?
    Why am I getting a print error?
  • 94 Answers
Prints on 44" Wide paper up to 1.5mm thick
Does this help at all?
Posted on May 29, 2009
  • Richard Eisenstein May 29, 2009
    Have you tried printing a test page? Is the paper lined up correctly? Wide format printers are very squirrely about paper alignment
How do I print envelopes
Move the carrriage to the size of envelopes,
then click on start, then click on fax n printers,
then double click on your icon epson, click printer then printing preferences, and in the PAPER OPTIONS TYPE choose envelopes. Then hit Print.
Here are 2 diagrams that might help. Good Luck :o)
Oct 15, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Ref EPSON STYLUS 680 printer paper feed problems ,fails to feed paper but motor runs
try to look on the input tray maybe there are some foreign object that might block the paper,because this kind of printer has a durable pick up roller.
Sep 09, 2009 | Epson Stylus 680 InkJet Color Printer
When printing it comes out all double writing
have you tried printing on a different TYPE of paper? I have found if you use the same paper as your printer you get much better results.
Also sounds like you are low on Magenta. the double writing sounds like you need to clean the rollers with a Qtip and a small amount if alcohol. good luck
Aug 14, 2009 | Office Equipment & Supplies
Epson r350 printer does not print thick paper or inkjet paper
Hi, this printer is "clever" in that you don't adjust the thickness setting it does it itself.
It does this based on the paper type you set in the printer properties, see the table below for the different types of paper it will accept & the setting you need to use.
For this paper Select this paper type setting Plain paper, sheets Epson Premium Ink Jet Plain Paper Epson Bright White Ink Jet Paper plain papers Epson Ultra Glossy Photo Paper Epson Ultra Glossy Epson Premium Glossy Photo Paper Epson Premium Glossy Epson Premium Semigloss Photo Paper Epson Premium Semigloss Epson Glossy Photo Paper Epson Glossy Epson Matte Paper - Heavyweight Epson Double-Sided Matte Paper Epson Matte Epson Photo Quality Ink Jet Cards Epson Photo Quality Ink Jet Epson Photo Stickers Epson Photo Stickers Envelopes Envelope
Hope this is of help.
Regards
Sham
Jun 01, 2009 | Epson STYLUS R350 Photo Printer
Printer will not advance paper.
Choose the media type on print settings that is closest to the type of paper that you are using. Choose the correct paper size too. Try printing again.
Goodluck.
sherlyn c.
May 23, 2009 | Epson Stylus Photo 820 InkJet Printer
Problem Printing Sheet Paper with the Epson 9800
On the machines control panel set to sheet fed (pressing the left button will change from Sheet, roll and roll with cut). In the print settings select your paper profile. On the page setup choose sheet. In the pull down menu you should only have basic paper sizes, no custom size. choose 20x30 and try again.
let me know if this helps
Feb 02, 2009 | Epson Stylus Pro 9800 InkJet Printer
Printer problem
check the type of paper..that type that's for copiers is NOT recommended for printers.
http://tinyurl.com/6qcpgy
Aug 19, 2008 | Epson Stylus CX3810 All-In-One InkJet...
Printing
hello,
probably the printer takes his own color-profiles installed by epson.
Click on propriaties of the printer and create your own color-profile for diferent sizes.
you can take the color-profile from a smaler size and save it choosing an other size.
So You also can improove your pictures by changing the color-profile after your needs...
but then you should use the same paper , because different papers give different colors.
you can also improove the colors by choosing-on the profile-another type of paper.
i hope i could help
Oct 16, 2007 | Epson Stylus 1400 InkJet Photo Printer
Printing on heavy cardstock
HP recommends papers with ratings of at least 90 for brightness and 75 g/m2 (20 pound) weight. before u proceed....remove the rear access door to reveal the rollers.Take a slightly wet cotton cloth and wipe the rollers in the upward direction 4 times.Close the rear access door. now do as said - START -PRINTERS & FAXES -CHOOSE THE PRINTER ICON THAT HAS BEEN HIGHLIGHTED WITH A CORRECT MARK. - RIGHT CLICK - PRINTING PREFERANCES - PAPER/QUALITY TAB - CUSTOM -Create a new custom paper size that is dependable on the paper you are using - type a name & SAVE -ok -ok -try printing if the problem still insists the report back and do mention which tool you are using for the printout. if its heavy pearlized paper then i do not think th eprinter would accept it . it maintains its own standard weight to detect the paper.
Sep 23, 2007 | HP Photosmart 3310 Printer
Epson Stylus Pro 10000 InkJet Printer Logo
354 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
