Question about Bryant Heating & Cooling
Fan will not turn on and cool unit
Bryant Quantum plus with Puron, fan not running to cool the coils
  • ACSvcTechFL May 11, 2010
    Indoor or Outdoor fan
  • william simpson Aug 05, 2015
    which fan indoor or outdoor you have to be able to use and interpet a meter to make a judgement on problem
3 Suggested Answers
  • 74 Answers
SOURCE: My Bryant Quantum Plus with Puron Air Conditioner
the outside unit is cycleing on a low pressure switch you need to call for service you have a leak and the system needs to be recharged afte the leak has been fixed
Posted on Jun 17, 2010
wise_jf
  • 66 Answers
SOURCE: new t stat installed in the house but unit will
some of these thermostats have an automatic time delay of five minutes built into them. Also there are many different thermostats so this is difficult. I would first check to see that Y runs to the outside unit. Also common (probably brown wire on furnace) needs to run to outside unit. If the thermostat has a R and RC both you may need to install a jumper wire that connect the two together. There is probably a fuse in the circuit board looks like an auto fuse. I would check this first of all. (if you bumped 2 wires together while changing the t-stat you probably blew the fuse.
Posted on Jul 12, 2010
2002 4 ton Bryant air conditioner shuts off, fan still runs but not cooling is problem in the controls in the attic or in the AC unit or both?
With a non heat pump it is a simple 24 volt AC control circuit. In the attic there is a relay that is actuated via the fan control wire directly from the thermostat. On the thermostat there is an auto/man switch that controls the fan. Manual the fan runs all the time. Auto fan turns on and off with the outside compressor.
If the system is not calling for cool and the fan continues to run the fan relay is sticking. common problem. Sometimes after running for several days the relay will stop sticking if not, replace relay.
If the system is calling for cool and the compressor stops I would still expect the fan to run until thermostat tells the A/C to off. Some compressor units include a safety switch or high-pressure cut-out switch A blocked internal valve bad control board or external fan in outside unit defective no air flow in outside unit.
High pressure cut out not good,
Suggest turning temp max cool and observe. If acceptable cool and the compressor runs without interruption all is good, except for the blower in the attic. Safely check relay in attic blower circuit.
Hope this helps.
Jun 28, 2017 | Bryant Heating & Cooling
Bryant 4 ton outdoor unit coils got hot fan works Is it repairable. Thx
That's means the coils is dirty .just shut unit off and washed coil with water until clean
Furnace blowing warm air, ac overheats
Sounds like it is tripping on it's high pressure switch. This could be caused by a dirty condenser coil, overcharge of refrigerant, or non condensables in the system ( air most likely). I would get a second opinion from a repuatable company, sounds like he's trying to rip you off.
Sep 25, 2012 | Bryant Heating & Cooling
Fan runs on outside unit, but no air blows in the house
Listen for the motor if its sounds and thou its running it probably is, the indoor coil could be iced up, if so turn on the fan and turn off the cooling and let it thaw out. Check the air filter and coil that they are clean, setting the stat to low below 72 degrees would cause the coil to frezz as well. If motor is not running, it could be bad, but there are onther things that could be causing it to not run.
Jul 04, 2011 | Bryant Heating & Cooling
THE FAN IN THE OUTSIDE UNIT IS NOT WORKING. INSIDE UNIT RUNS BUT NO COOL AIR IS COMING OUT OF VENTS. IS THERE A REST BUTTON OLN THE OUTSIDE UNIT?
either the fan has went out or the capisitor for the fan is bad and needs to be replaced.if you have run the outside unit very long without the fan turning you might be replacing the compressor as well as the fan or capisitor.if the fan isnt pulling air through the cond coil outside,the compressor gets very hot very fast,and it locks down(burns up). get it looked at asap before it cost more because of other broken parts caused by the fan not working.
Sep 24, 2010 | Bryant Heating & Cooling
My Bryant Quantum Plus with Puron Air Conditioner is two years old at max used for one season. The fan spins and then I hear a click and it shuts down for a minute clicks back on the fan spins for a minute...
Jun 16, 2010 | Heating & Cooling
Bryant Legacy Air Conditioner doesn't blow out cold air
Unplug the unit with all controls off, then plug back in and wait 5 minutes before turning on switct at unit. Good luck
May 27, 2009 | Bryant 462AJC021BA Air Conditioner
Carrier air conditioner problem
My Carrier unit did the same thing. It was low on refrigerant (Puron in my unit). I am worried I have a leak somewhere. Hopefully, it is not in the coil. The service call wasn't cheap either. Puron runs around $10-15 a pound and mine took several pounds to replenish.
Aug 01, 2008 | Carrier 38CKC036 Air Conditioner
Heating & Cooling Logo
182 people viewed this question
Top Bryant Heating & Cooling Experts
christian nielsen
Dan Webster
Dan Webster
Bill Long
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
