Question about Vizio L32 32 in. LCD HDTV
Color distortion Samsung 32" tv 360 series. I had the tv for 2weeks now and now all the reds look pinkish and all distorted for all the other colors. Tried changing settings, called samsung, no solution any help?
  • 822 Answers
Go to your menu select color, select user, and adjust RGB from user. same level R-60, G-60, B-60.
Posted on May 29, 2009
What part fails to make distorted or wrong colors and over all dimmer picture on a DLP TV?
You are correct that oit is the color wheel. I wcannot give you a part number at this time because you have not supplied the model number of the set. I hope this helps.
Mar 08, 2016 | Samsung Televison & Video
Visio Strange Color/Pixel Problem As of now, every time i turn my 32" Visio HDTV (VX32LHDTV10A) on, certain areas and colors are going crazy and it has progressively gotten worse over the past...
The tv main Tuner signal board it is the causes and the problems.The board it is dying and shorting out.U have some mechanicals skills,like take things aparts and putting it back togetther again?Yes.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv main Tuner signal board for the replacement.
Jul 14, 2011 | Vizio L32 32 in. LCD HDTV
Loud humming sound on with a purplish and pinkish screen on my 50 inch dlp samsung, 5 yrs old.
Hi,sounds like you might be experimenting a color wheel problem.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.Your part # is BP96-00250A You can find it here http://www.discount-merchant.com/Samsung-BP96-00250A-ColorWheel-Assembly-p/bp96-00250a-color-wheel.htm?Click=48173 and here's the instructions to replace it : http://www.fixyourdlp.com/guides/samsung/bp96-01579a.php Have a bless one!
Apr 18, 2010 | Samsung HLN5065W 50" Rear Projection...
Vertical Distortion fix for Toshiba 32 inch TV
You have bad capacitors and possibly a vertical IC that is going bad. And check for bad grounds in and around the IC and caps!
Dec 10, 2009 | Televison & Video
Freezing, no audio/video/red circle
ONE THING YOUR CORDS ARE WACKED OUT AND THE COLOR DISTORTION SIMPLE NOT YOUR XBOX IT IS YOUR TV
Aug 17, 2009 | Microsoft Xbox 360 Console
Samsung LE26R7 4BD, approx 4 years old, colour distortions
Check all of your cables on the back of the tv and your sources such as Cable,Sat box and DVD palyer to make sure they are fully inserted into the input and output connectors. Some times Component cables will work loose and you end up with a missing color. Temprature changes can affect intermittant connections. If that does work then you have a bad Main bd.
Jul 02, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Loud humming and color is distorted
You most likely need to have the color wheel replaced,its a common problem with the samsung DLP sets.
Apr 29, 2009 | Samsung DLP HL-P5663W 56" TV
Picture distorted and blurry with color
bad convergence amp ic
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 28, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Philips hdtv color distortion
your tv has a prolem in the color circuit there is a ic that controls this circuit changing it will restore your tv to normal.since you are not a tech have a tech look at it for repairs.good luck.
Aug 03, 2007 | Samsung TXM3296HF 32" TV
Vizio L32 32 in. LCD HDTV Logo
806 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
