Question about Homelite Mighty Lite Lawn Trimmer
Homelite trimmer dies every time I squeeze the handle
It will run until I squeeze the handle to use it i have the same problem. it is a homelite that is about 3 years old. it will start but when i pull the trigger it dies. i also can't put it wide open on the choke or it dies.
  • 3 more comments
  • rbfe4ch47 May 29, 2009
    i have cleaned it and have also cleaned the carb. thanks for the response back.
    it will run when at half idle and if i squeeze the trigger at half it will slowly run up. but when i close the choke it dies. exhaust doesn't seem any different than before. i didn't touch the screws, the only reason i pulled it off to clean was to fix the problems hopefully. i cleaned the exhaust port as well. put it all back together with some hope and it still did the same thing. at wits end now.
  • Samuel Charles Spriggs May 11, 2010
    I would try adjusting the air/fuel mixture screw -- even tho you didin't touch it, taking the carb off could have created a need for adjustment.
    Well, this is a classic not getting enough air or fuel issue.
    Does it run long enough to detect any difference in the color of the smoke versus the color it was when it ran well?
    Did you change the air/fuel ratio screw setting while you were working on the carburetor?
    Did you clean the carb because of this symptom or was it just routine maintenance.
    Have you cleaned the air filter lately?
3 Suggested Answers
  • 15 Answers
SOURCE: Homelite trimmer dies every time I squeeze the handle
This can also be (just did this too with my Zip Start):
1. Nasty Carb (loose screws or just funky)
2. Leaks (be they Air or Fuel Gaskets!)
3. Funky Exhaust Port
4. Fuel (check it ALL, lines, filter, tank)
5. Fuel CAP (believe it or not, they ARE vented for a reason, to PREVENT Vapor Lock)
6. The Spark Plug (if it is weak, she will act like that on the High Side, sometimes, even when Idling nicely! Double check your Plug Seat as well, where the Plug meets the Cylinder Head, if it is funky bad, clean it up, a good ground is a must!)
Remember that on a 2-Stroke, Spark Plugs take a hell of a beating on heat, or getting over-fueled (which they do, when carbs are unmaintained). And UNLIKE 4-Strokes....they have to burn OIL too! (Foul faster)
Fuel -> Fuel Filter-> Fuel Line-> Carb->
Splits here into TWO paths:
1. Fuel Bulb-> Fuel Line (Return Line)-> Fuel Tank
2. Fuel Bulb-> Carb-> Intake Port-> Piston-> Exhaust Port-> Exhaust Port Screen
Electrical:
Magneto-> Rotor Magnets (for Spark Plug, AKA- Ignition)->Spark Plug Wire->Spark Plug->Cylinder Head
Kill Switch (grounds all the above to the cylinder)
Running: (Carb, etc.)
Throttle Cable (super simple)
Carb Butterflies
Carb Seats, Carb Gaskets (air leaks/fuel leaks)
Needle Seat (Fuel Flow, Gummed UP!)
Any and ALL Fuel/Air Ports in the Carb.
Fixes: CLEAN THE CARB. I don't mean spray some WD-40 on it and call it "clean". Tear it ALL the way down (CAREFULLY!), and put her back together. Use some compressed air and Gum-Out.
NOTE: "Gasket Kits" are NOT a fix EXCEPT for leaky GASKETS!
They do NOT fix 99% of the problems: Spark Plug or Dirty Carb!
They will NOT fix "Operator Error" either!
NOTE: If it requires fuel (or a mix), it will invariably get gummed up, and nasty. Carbs are about the #1 reason ANY small engine fails, and ONLY second to people who will....not....maintain...equipment.
("Operator Error")
NOTE on Carbs: If it worked brand new without an adjusted carb (factory settings), it does NOT need adjusted now. What it needs to be is CLEANED, and put back into service. E.G.- MAINTAINED!
Posted on May 28, 2009
darth yoda
  • 4 Answers
try to adjust the air intake??
Posted on May 29, 2009
The engine cuts off when i squeeze the handle on the sprayer, what is causing this to happen?
Sounds like a bad unloader valve. Do a search on "pressure washer unloader valve symptoms". When they are faulty there will either be little pressure or it will stop an engine abruptly. The engine will not just die down as it you were turning it off. It would stop cold.
May 28, 2015 | Homelite Pressure Washer. 2700 psi 2.3 GPM...
What is the gas oil mixture for homelite sx135 trimmer
Use 32:1 with good quality 2-cycle oil. I have Used Stihl, Homelite, Poulan and Several Other 2 Cycle Trimmers in the Yard Maintenance Service and Have Found the 32 to 1 Mixture to Extend the Life of the Engine. Always Remember to Drain the Tank and Run the Engine Until the Carbuetor is Empty for Off Season Storage.
Sep 27, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite mighty lite wont stay running
the problem is in the carburetor most likely, it may be cleaned and adjusted, if not it will likely need a new carb
May 31, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite whipper wont start. Replaced the primer
check your gas and oil mix remove the plug take some carb cleaner spray in plug hole pull start replace plug pull start if it fire you mix is wrong.....Good Luck
Aug 15, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
SX-135 Homelite trimmer-carb diaphram cracked
You can go to an outdoor power & equipment type of store (Independent store). The cost is around $12-$18.
Jim
Jun 19, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite gas trimmer will not run without half choke and throttle
You need to disassemble the carb. and spray with carb. cleaner. If you need tips on how to do this, just let me know. You may need a new carb. kit as well, but we won't know that until you first perform the first step, or if the carb. parts are more than 3 years old. If they are, then go ahead and buy the carb. kit and replace the parts.
Jim
Jun 01, 2009 | Homelite Mighty Lite Lawn Trimmer
remove the muffler,disassemble it,you will find a spark arrester screen in it.it is either clogged up with carbon or partially clogged,clean all carbon off,reassemble and try again
May 28, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite mighty lawn trimmer vt26
Go to www.homelite.com then in the red area up top click on order parts, then click launch parts catalog, then scroll down and click agree and then you will need your model # then you will have a list of breakdowns that you can look at for your trimmer
Oct 26, 2008 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
769 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
