Question about Mitsubishi WT-42311 42" Rear Projection Television
Mitsubishi tv wt-42311
T.v. will not turn on. Green indicator light stays on for fivish seconds.  When menu and input buttons are pushed tv indicator light flashes 22 times or 2 quick flashes ten times (same thing)  What could the problem be?
  • sgomes77 Apr 30, 2008
    same problem here. tv green indicator turns on for a few seconds then just turns off. my 5 year warranty i purchased with the tv expired in january.......figures right?
    President:
  • 4,402 Answers
Convergance ic bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Dec 15, 2007
My t.v. dont stay on
First do a hard reset. Merely unplug the power cord for 4 hours, then restart it. This will correct it if the cause is corrupted soft codes.
If not, the protection circuit has captured the power management and you must have it looked at by a service tech.
Let me know if there is more.
Dont forget to rate me as fixya..
Jan 30, 2008 | Mitsubishi WT-42311 42" Rear Projection...
TV Doesn't stay on...
HI
base in your comments in your TV you have defective power oscillation circuit! and need to diagnose your TV with a qualified technician! now if you have knowlegde in electronic trouble shooting i can give you the method to fixed your TV. Thanks in Advance!!!
Nov 15, 2007 | Mitsubishi WT-42311 42" Rear Projection...
My mitsubishi 42' hd 1080 tv turns off immediately after i turn it on.The set is about 7 years old.HELP!!!!!! niteowl42
Have you acessed the power indicator error code by pressing in the menu and input buttons on the front of the set both in together and hold in for 5 seconds? The led will blink a series of blinks to indicate a 2 digit code which will repeat several times. Let me know what the blink seqience is.
May 31, 2011 | Mitsubishi WT-42311 42" Rear Projection...
When i press power the timer light flashes and the T.V. turns on and right back off.
If model number is WT-42311 do the self check the set has.
When power light comes on and then goes off, on front of set press both the Menu and Input (device) buttons at the same time and hold for at least 5 seconds and then release both buttons.
Power light will blink a two digit error code like: 2 blinks, 2 blinks, a pause and the repeat the code several times.
Let me know what the error code is and I will tell you what it means.
If this has helped you, rate this solution as very helpful as I do this here for free.
SD TECH
Oct 03, 2010 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi WT-42311. Green tinted screen, now won't stay on.
Yes,the 2 STK convergence ICS and some or all the resistors,the pico fuse are dead.U know soldering,have the soldering tools,and solders right?Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for the parts,and labors.
May 13, 2010 | Mitsubishi WT-42311 42" Rear Projection...
When I go to turn it on it clicks and then clicks off
do the self check this model has and let me know what you find:
when it shuts off press ON THE FRONT OF THE TV both the menu and input (or device) buttons at the same time for at least five seconds and release both buttons.
The power light will blink a two digit error code.
for example---2 blinks, a pause and 2 blinks (this is the most common error code)
Let me know what code you find and I will tell you what it means and what can be done.
If this helped you rate this solution as I do this here for free.
SD TECH
Dec 15, 2009 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi WT-42311
Most units give a error code "22" short protect circuit. If so check:
Q5A00
C557
and or the
convergence IC's (STK392-110) had failed and caused a diode (D522) to short
out.
If Q5A00 check bad there are other parts that have to be checked or
replaced.
Dec 02, 2007 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi wt-42311 tv wont stay on
convergance ic bad
Oct 28, 2007 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi WT-42311 42" Rear Projection Television Logo
199 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
